BobbyPaulk(at)comcast.net Guest
Posted: Sun Jul 20, 2008 5:05 am Post subject: Canopy Latch |
the new 601 XL's manufactured by AMD in Eastman, GA. are using the new latching mechanism between the seats at the rear of the console. it is much more positive and less likely to be left partly latched. if i were in the build stage i would definitely change to it.
bobby
N131BP
DO NOT ARCHIVE
Gig Giacona
Posted: Sun Jul 20, 2008 3:00 pm Post subject: Re: Canopy Latch |
Don't get me wrong, I like the new design better than the design I have with the cables. But after looking at Jay's I don't think it is any less likely than our to have one side unlatched, though you can see that it is unlatched a little easier.
The plus with it is the lack of those cables that I have little doubt will leave me latched in the plane sooner or later.
BobbyPaulk(at)comcast.net wrote: | the new 601 XL's manufactured by AMD in Eastman, GA. are using the new latching mechanism between the seats at the rear of the console. it is much more positive and less likely to be left partly latched. if i were in the build stage i would definitely change to it.
bobby
N131BP
DO NOT ARCHIVE |
601XL Under Construction
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sun Jul 20, 2008 3:20 pm Post subject: Canopy Latch |
On Sun, Jul 20, 2008 at 04:00:12PM -0700, Gig Giacona wrote:
Quote: | Don't get me wrong, I like the new design better than the design I have
I'm not sure I buy that at all. To have one side latched and one side
unlatched would require seriously deforming the canopy frame, either by
twisting or else stretching to the side - and to get the hook on the outside
of the bolt head would require a major effort to pull the latch closed,
something that would be immediately noticeable.
I do think the ability to easily confirm proper latch engagement visually or
by touch is a major advantage, since that's a lot harder with the old
design. Basically, the relevant checklist item becomes "Canopy - latch and
verify".
Quote: | The plus with it is the lack of those cables that I have little doubt will
I'd suspect that the cable tension is one of those things that needs to be
checked at annual.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Posted: Sun Jul 20, 2008 3:31 pm Post subject: Canopy Latch |
Jay, what keeps you from bumping the center knob with your elbow and opening
the canopy in flight? Is the spring strong enough to make that unlikely?
-- Craig
jmaynard
Posted: Sun Jul 20, 2008 3:41 pm Post subject: Canopy Latch |
On Sun, Jul 20, 2008 at 05:28:32PM -0600, Craig Payne wrote:
Quote: | Jay, what keeps you from bumping the center knob with your elbow and opening
Between that, and the fully-locked position being low enough that you're not
likely to get your elbow underneath it, and the fact that there's some
friction as the hooks engage, I seriously doubt it'd be an issue.
purplemoon99(at)bellsouth Guest
Posted: Sun Jul 20, 2008 5:27 pm Post subject: Canopy Latch |
Has any one seen the latch in the new Sportcruiser? Real good idea! Sound
's about like what you're talking about.. I flew in one this morning very
nice plane and very nice latching system.. simple ,to the point,and
positive Joe
Gig Giacona
Posted: Mon Jul 21, 2008 7:01 am Post subject: Re: Canopy Latch |
Deforming the canopy frame isn't that hard, at least not on mine.
I hope I only have to adjust the tension annually.
jmaynard wrote: | On Sun, Jul 20, 2008 at 04:00:12PM -0700, Gig Giacona wrote:
verify".
checked at annual.
AMD Zodiac CH601XLi N55ZC (got it!) |
