JetPilot
Posted: Sun Jul 20, 2008 7:43 am Post subject: Going to Build a Kitfox 7 Super Sport, Any suggestions ?? |
I am going to build the Kitfox 7 Super Sport with a Rotax 912-S, and tricycle gear. Are there are any mods or options that are a " Must Have " on this plane ? Any suggestions in building or that could make this the best plane possible would be greatly appreciated.
Mike
Kolb MK-III Xtra, 912-S |
rjdaugh
Posted: Sun Jul 20, 2008 11:40 am Post subject: Going to Build a Kitfox 7 Super Sport, Any suggestions ?? |
Mike,
Build it light. No carpet. No lights (unless you need lights for your
mission.) Minimal instrumentation. But get a lift reserve instrument.
Randy
Series 5 tail dragger, Series 7 firewall forward.
912s Warp Drive Taper tip.
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
mdkitfox(at)aol.com Guest
Posted: Sun Jul 20, 2008 12:04 pm Post subject: Going to Build a Kitfox 7 Super Sport, Any suggestions ?? |
Mike,
Tell us what you would like to do with the airplane? Cross country, just bum around, instrument capable/proficiency, yada, yada, yada! That way you'll get more targeted and meaningful information.
Rick Weiss
Series V Speedster
rdmac(at)swbell.net Guest
Posted: Sun Jul 20, 2008 3:05 pm Post subject: Going to Build a Kitfox 7 Super Sport, Any suggestions ?? |
Mike,
I would order the predrilled quick build wings for the Rotax 912S. It will
save you a lot of time with setting the wings for proper position.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
JetPilot
Posted: Mon Jul 21, 2008 7:20 am Post subject: Re: Going to Build a Kitfox 7 Super Sport, Any suggestions ? |
I would like to do mild aerobatics, and fly long cross country. I also need to be able to fly in areas ( not inside ! ) of thunderstorms that always build here during the daytime here in Florida, so the plane needs to be strong and agile enough to handle the bad turbulence that often comes when one flys near a storm. I plan on getting the quick build wings, but I was not sure about the wings matched to fuselage option, weather I should do this or not.
I also need a heater, and would like to soundproof as much as possible. I don't know if firewall sound proofing works well on a Kitfox ? I plan on an EFIS panel, clouds happen and sometimes an artificial horizon can save your arse Thats it in a nutshell, if there is anything else I should consider let me know.
Mike
