Zenith701801-List Digest: 23 Msgs - 07/17/08
tumates(at)gmail.com
PostPosted: Thu Jul 17, 2008 11:32 pm    Post subject: Zenith701801-List Digest: 23 Msgs - 07/17/08 Reply with quote
In Mass. all our gas is 20 proof.
Choice is not an option after politics gets involved.
On Fri, Jul 18, 2008 at 2:58 AM, Zenith701801-List Digest Server <zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)> wrote:
[quote]*
Today's complete Zenith701801-List Digest can also be found in either of the
of the Zenith701801-List Digest and can be viewed with a generic text editor
HTML Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-07-17&Archive=Zenith701801]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-07-17&Archive=Zenith701801[/url]
Text Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-07-17&Archive=Zenith701801]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-07-17&Archive=Zenith701801[/url]
Zenith701801-List Digest Archive
Total Messages Posted Thu 07/17/08: 23
Today's Message Index:
1. 02:37 AM - Re: copying holes (John Marzulli)
2. 06:38 AM - Re: copying holes (Carlos Sa)
3. 07:24 AM - Re: 10 percent ethanol in 912s (ricklach)
4. 07:49 AM - Re: copying holes (n85ae)
5. 07:57 AM - Re: Re: copying holes (Carlos Sa)
6. 08:24 AM - Re: Re: 10 percent ethanol in 912s (Bob Sturgis)
7. 08:31 AM - N73EX Is Now An Airplane (George Race)
8. 08:42 AM - Should the lists have been split? (Keystone Engineering LLC)
9. 08:44 AM - Re: Re: copying holes (Randy L. Thwing)
10. 08:48 AM - Re: N73EX Is Now An Airplane (Randall J. Hebert)
11. 09:05 AM - Re: N73EX Is Now An Airplane (Bob Sturgis)
12. 09:29 AM - Re: Re: 10 percent ethanol in 912s (NYTerminat(at)aol.com (NYTerminat(at)aol.com))
13. 10:09 AM - Re: N73EX Is Now An Airplane (John Marzulli)
14. 10:29 AM - Re: Should the lists have been split? (n85ae)
15. 11:26 AM - Re: Hole finder (Zed Smith)
16. 12:31 PM - Re: Re: Hole finder (Randy L. Thwing)
17. 12:55 PM - Re: N73EX Is Now An Airplane (kmccune)
18. 01:32 PM - More N73EX (Zed Smith)
19. 01:53 PM - N73EX Follow Up Clarification (George Race)
20. 03:06 PM - Re: More N73EX (kmccune)
21. 04:23 PM - Re: Should the lists have been split? (n801bh(at)netzero.com (n801bh(at)netzero.com))
22. 04:34 PM - Re: N73EX Is Now An Airplane (Art Olechowski)
23. 07:50 PM - Re: Should the lists have been split? (kmccune)
________________________________ Message 1 _____________________________________
Time: 02:37:53 AM PST US
From: "John Marzulli" <john.marzulli(at)gmail.com (john.marzulli(at)gmail.com)>
Subject: Re: copying holes
If you are copying the holes from the ribs, then doing back-drilling one
skin at a time should work. Otherwise, you can make a strap duplicator
easily using a few rivets and two spent hack saw blades.
GOOD LUCK and DO NOT ARCHIVE
John Marzulli
http://701Builder.blogspot.com/
http://www.GenevieveMarzulli.org/
http://www.JohnMarzulli.net/
On Wed, Jul 16, 2008 at 6:45 PM, Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
> Hello, all
How have you copied a hole pattern from one part to a new part, without
damaging (i.e., making them bigger, oval) the existing holes?
In my case, the wing ribs have already been drilled to A4 size, and I am
> going to discard the old skin.
I think the least laborious way of doing this would be to back-drill the
skin, from inside the wing.
But how do I make sure I won't enlarge the holes on the ribs?
Thanks in advance for your comments / suggestions.
Carlos
________________________________ Message 2 _____________________________________
Time: 06:38:06 AM PST US
From: "Carlos Sa" <carlossa52(at)gmail.com (carlossa52(at)gmail.com)>
Hello, Craig
This is one of the many tools out thre I didn't know existed...
If I understand it well, you place it in the hole (in my case, the rib's),
with the target piece under it (the skin), and tap it so you get an
indentation at the centre of the location where the hole needs to be?
Nice.
Thanks for writing
Carlos
2008/7/17 Craig Payne <craig(at)craigandjean.com (craig(at)craigandjean.com)>:
How about a transfer punch?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3577
Or just search www.harborfreight.com for item number 3577-2VGA.
Remember that pulled rivets do expand in their holes. So some enlargement
> of the existing holes is tolerable. I think there is something in the Zenith
construction standards about this.
-- Craig
________________________________ Message 3 _____________________________________
Time: 07:24:26 AM PST US
Subject: Re: 10 percent ethanol in 912s
From: "ricklach" <rick(at)ravengear.us (rick(at)ravengear.us)>
Hi Jeff,
What part of the country is "around Here"? I live in California and haven't seen
Ethanol yet. Has any one "out here" seen any ethanol?
Rick
http://forums.matronics.com/viewtopic.php?p=193356#193356
________________________________ Message 4 _____________________________________
Time: 07:49:01 AM PST US
From: "n85ae" <n85ae(at)yahoo.com (n85ae(at)yahoo.com)>
Can you lay the old skin on top of the new skin as a drilling template?
This would be the easiest way. Lay the new skin on a sheet of plywood,
and drill and cleco the old skin right on top of if clecoing all the way
through into the plywood. I did this with my cabin floor after I discovered
that the lines drawn by Zenith were incorrect and I had trimmed to the lines.
Every single hole matched perfectly.
I don't think you can use a hole finder on wing skins as the edge to hole
distance would be excessive.
Jeff
http://forums.matronics.com/viewtopic.php?p=193362#193362
________________________________ Message 5 _____________________________________
Time: 07:57:03 AM PST US
Subject: Re: Re: copying holes
Good idea, Jeff, but the reason I have to go through this operation in the
first place is that the original skin isn't square.
That's why I want to use the holes in the ribs as a guide. Using the skin is
not impossible, but it represents more work (I would have to reposition it
for each rib station).
(A hole finder is unnecessary, the structure is still just clecoed.)
Thanks for the comment.
Carlos
2008/7/17 n85ae <n85ae(at)yahoo.com (n85ae(at)yahoo.com)>:
> lines.
Jeff
________________________________ Message 6 _____________________________________
Time: 08:24:29 AM PST US
From: Bob Sturgis <bobefx(at)yahoo.com (bobefx(at)yahoo.com)>
Subject: Re: Re: 10 percent ethanol in 912s
Rick,=0AI live in the Los Angeles area and some Ethanol has been found in g
as here. Check with your supplier, it is not always on the pump, or it may
say "may contain Ethanol" in small print. It is here, just- not broadcast
or advertised.=0A-=0ABobefx=0A=0A=0A---
