wing tank drain valve size
iworonko(at)cox.net
PostPosted: Thu Jul 17, 2008 11:48 am    Post subject: wing tank drain valve size Reply with quote
does anyone know what thread size the wing tank fuel drain/sample valves are ? 1/8 or 1/4 ?
Eric
ElleryWeld(at)aol.com
PostPosted: Thu Jul 17, 2008 11:53 am    Post subject: wing tank drain valve size Reply with quote
1/8 inch
In a message dated 7/17/2008 3:50:07 P.M. Eastern Daylight Time, iworonko(at)cox.net writes:
Eric
f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
n85ae
PostPosted: Thu Jul 17, 2008 12:05 pm    Post subject: Re: wing tank drain valve size Reply with quote
1/8 npt
Jeff
Lynn Matteson
PostPosted: Thu Jul 17, 2008 1:25 pm    Post subject: wing tank drain valve size Reply with quote
Mine are 1/8 NPT. I plugged mine with Allen pipe plugs, and I see the
slight protrusion of the plug is beating a hole in the fabric, even
though I doubled up with a doily. If you are plugging that hole, make
sure that you apply some anti-chafe tape over the plug. (I do a
sample check at my header tank where any contaminant will eventually
wind up)
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/547+ hrs
Eric
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
iworonko(at)cox.net
PostPosted: Thu Jul 17, 2008 1:51 pm    Post subject: wing tank drain valve size Reply with quote
Thanks Lun and others for the tank drain size.
Eric
