Carb sync tools
craig(at)craigandjean.com
PostPosted: Tue Jul 15, 2008 3:35 pm    Post subject: Carb sync tools Reply with quote
Has anyone built their own synchronizer (basically a double-ended
differential manometer) instead of buy a commercial kit? How well did it
work? Looks like it should be as good (or better with the longer scale).
Something like this:
http://www.powerchutes.com/manometer.asp
-- Craig
Gtblu
PostPosted: Wed Jul 16, 2008 4:22 am    Post subject: Carb sync tools Reply with quote
Craig,
I have been using this tool for some time now and can report it is very accurate, cheap, and easy to use. Don’t rest the hoses on your windscreen as the pulses through the engine will scratch the Perspex, or Lexan in my case, but otherwise thoroughly recommended.
Geoff Bell
ricklach
PostPosted: Wed Jul 16, 2008 8:03 am    Post subject: Re: Carb sync tools Reply with quote
Hi Geoff,
What is "this Tool"? Do you mean the $1.55 home made vacuum manometer or something else? Could you please explain a little or post a picture.
Rick
Roger Lee
PostPosted: Wed Jul 16, 2008 3:00 pm    Post subject: Re: Carb sync tools Reply with quote
Hi Guys,
If you don't want to spend a bunch of money for a carb balance tool here is a picture that you can make at home. It works very well and is easy to use. At least use a decent pair of liquid filled gages.
Carb sync tool
 Filesize:  120.66 KB
 Viewed:  733 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Gtblu
PostPosted: Thu Jul 17, 2008 1:44 am    Post subject: Re: Carb sync tools Reply with quote
Rick,
I was referring to the $1.55 special as attachment in Craigs post. I used Dextron 3 as the oil inside the tubes. Very accurate and highly visible when its all happening!.
regards
Geoff
ricklach
PostPosted: Thu Jul 17, 2008 6:33 am    Post subject: Re: Carb sync tools Reply with quote
Hi Geoff,
Thanks for the clarity. I like the idea, I'll give it a try.
Rick
