Dipole antenna from co-ax
icrashrc
PostPosted: Mon Jul 14, 2008 9:36 pm    Post subject: Dipole antenna from co-ax Reply with quote
I know I've seen on the list how to make a dipole antenna out of co-ax. I just spent the last hour searching the archives and can't find the post again. Anyone remember who had that info or know where to find it?
Scott
www.ill-EagleAviation.com
George Alexander
PostPosted: Tue Jul 15, 2008 4:32 am    Post subject: Re: Dipole antenna from co-ax Reply with quote
Scott:
From Boyd Young's Web Site:
http://www.brigham.net/~byoung/antenna.html
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
mdnanwelch7(at)hotmail.co
PostPosted: Tue Jul 15, 2008 9:11 am    Post subject: Dipole antenna from co-ax Reply with quote
Scott,
It has been awhile since I've looked at the design article, but Jim Weir (of Kitplane's Magazine) has a website that has the dipole antenna, with close-up drawings and details.
Just do a search for "Aero 'lectrics". I'll see if I can find it......
Here it is: (just scroll down to the article you're after. Best regards, Mike Welch
http://www.rst-engr.com/kitplanes/index.htm
P. S. Scott builds a beautiful overhead fiberglass panel. He custom made one for me...nice stuff.
It’s a talkathon – but it’s not just talk.
http://www.imtalkathon.com/?source=EML_WLH_Talkathon_JustTalk
tlongo
PostPosted: Tue Jul 15, 2008 10:41 am    Post subject: Dipole antenna from co-ax Reply with quote
Hi Scott, this will work with any frequency you want to make a half wave
dipole for. Take the freq in mhz you want to make antenna for and divide it
into 468 and that is the correct length in feet. For instance 123.00 mhz
would be 468 divided by 123 equals 3.8 feet for your half wave. Now take 3.8
divided by 2 and you get 1.9 feet, so take 1.9 feet of wire and solder it to
center conductor of 50 ohm coax and 1.9 feet and solder to the shield of the
coax and you have a half wave dipole. If you want to make your own 1/4 wave
antenna take a 1.9 foot rod of aluminum or stainless and hook center of coax
to it and insulate that from ground when you mount it, then put shield of
coax to ground of airframe and you now have a 1/4 wave antenna that did not
cost an arm and a leg to buy. You can trim to a perfect SWR if you have a
meter but it will work fine if you just cut it to the proper length.
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.21 KB
 Downloaded:  510 Time(s)
icrashrc
PostPosted: Sat Jul 19, 2008 11:58 am    Post subject: Re: Dipole antenna from co-ax Reply with quote
Thanks to all!
George, Boyds site was the one i remembered.
Mike, Thanks for some interesting reading. And the kudos on the overhead panel. I'm glad you like it!
tlongo, I don't seem to have a program to open that file. And what type of co-ax is 50 ohm? rg-58, rg-59, rg-6, something else...?
Thanks again,
Scott
ceengland(at)bellsouth.ne
PostPosted: Sat Jul 19, 2008 5:06 pm    Post subject: Dipole antenna from co-ax Reply with quote
icrashrc wrote:
Thanks to all!
Thanks again,
Scott
-58 is 50 ohm. -59 & -6 are 75 ohm.
It should be noted that most, if not all rg-58 has a solid center
conductor. If it's installed where it doesn't move at all, it will
probably outlast you & the plane. However, if you're plugging &
unplugging from a hand-held & hang the dipole end so it can flex & move
as the plane moves, you might have problems with the center conductor
either breaking or pushing its way through the foam center insulation &
touching the shield. There are other 50 ohm coaxes that have a stranded
center conductor so they are more flexible.
Charlie
tlongo
PostPosted: Tue Jul 22, 2008 8:13 am    Post subject: Dipole antenna from co-ax Reply with quote
Hi Scott, RG58 is 50 ohm RG59 & RG6 are 75 ohm, make sure you use RG59.
winmail.dat
 Filesize:  2.71 KB
 Downloaded:  486 Time(s)
by0ung(at)brigham.net
PostPosted: Tue Jul 22, 2008 7:44 pm    Post subject: Dipole antenna from co-ax Reply with quote
Use 50 ohm coax..... the 75 ohm stuff is for cable tv. Or xmitter
designed for 75 ohm loads.
Your transmitter is designed for 50 ohm coax and matched to an antenna tuned
to a 1 to 1 match,, which is a 50 ohm impedance.
I am holding in my warm hands a piece of coax " PLASTOID CORP. RG- 58 A/U"
it is 0.2 inches in diameter, it has a braid just under the jacket, with an
insulator over the multi strand center conductor. BETTER STUFF.
If you want to go smaller..... I have some " BELDEN 8216 RG - 174 / U"
0.1 inch in diameter, also multi strand center core.... It has higher
internal losses but is good for low power and very short distances. GOOD
STUFF
There is one other but I cant remember the number off the top of my head.
Rg 222??????? It is usually brown in color and it is DOUBLE shielded and
is better suited for installations with lots of other RFI ( Radio Frequency
Interference) in the area. My best guess is 0.2 inches in diameter as
well. BEST STUFF. I considered it an over kill in my kolb.
Try to stay away from the coax with a solid core center wire unless it is
for an installation that will have no movement.
Boyd Young
Kolb MkIIIC
530 + hours
there is not any tech info on the sight..... mostly a picture and short
description.
Ham Radio Extra Class N7WFM
winmail.dat
 Filesize:  4.57 KB
 Downloaded:  803 Time(s)
rowedenny
PostPosted: Wed Jul 23, 2008 6:57 am    Post subject: Dipole antenna from co-ax Reply with quote
Boyd said,
[quote] Use 50 ohm coax..... the 75 ohm stuff is for cable tv. Or xmitter
tuned
