AOA/LRI on a 701?
craig(at)craigandjean.com
PostPosted: Mon Jul 14, 2008 10:39 am    Post subject: AOA/LRI on a 701? Reply with quote
A question for those of you flying with an AOA or LRI installed in your 701:
how useful is it? It would seem that in the 701 (with lift to burn) it would
be less important than in a more conventional aircraft.
My EFIS has inputs for an AOA probe. But the wings are closed up so I'm
wondering if it is worth the trouble to install and plumb a probe.
-- Craig
beachyjeff(at)juno.com
PostPosted: Tue Jul 15, 2008 8:36 am    Post subject: AOA/LRI on a 701? Reply with quote
I installed the Ohio LRI in my 701. It is bent back to a riduculous
degree and I still don't have it calibrated to stall at the Red/White
line. I like having it, especially in steep, slow turns and such
maneuvers, but it certainly isn't necessary in such a high lift design.
Jeff Beachy
N701N, 120 hours
Summer Spa Sweepstakes
Enter for your chance to WIN a Summer Spa Vacation!
http://thirdpartyoffers.juno.com/TGL2141/fc/JKFkuJi7UbfCglNFwxUehOC8veArkrkjLNPe1crZUoGsmlbiUjFCfI/
jetboy
PostPosted: Wed Jul 16, 2008 12:55 am    Post subject: Re: AOA/LRI on a 701? Reply with quote
I built one up from a rod of plexiglass using a long drill and a sensitive air gauge, and trialled it for a few flights.
I had to set the probe at a much lower angle than expected, and although it operated as supposed to I really wouldnt want it on my 701.
There is such a wide envelope of airspeed and AOA available and I dont see the gauge has any compensation for A/C weight and flaps down conditions, these variables have a huge effect on when and where the plane ends up.
I'd like to be more specific but having tried it out conclude its best left out of the 701 / 801 cockpit
Ralph
Ralph - CH701 / 2200a
