Very Minor Structural Failure
N111KX (Kip)
PostPosted: Fri Jul 11, 2008 5:45 pm    Post subject: Very Minor Structural Failure Reply with quote
During the pre-flight today I ran across this little failure. It's the steel rod that keeps the fabric away from the aileron torque tube. It seems to have broken away from the weld. Also noteworthy is that there is no real stress on mine as my cage is uncovered. You may want to keep an eye on this.
One of the last airframes from old Kolb.
Total time...370 hours
Years since manufacture...10 (8 years flying)
Kip
 Filesize:  330.32 KB
 Viewed:  511 Time(s)
 Filesize:  250.56 KB
 Viewed:  491 Time(s)
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
JetPilot
PostPosted: Fri Jul 11, 2008 7:03 pm    Post subject: Re: Very Minor Structural Failure Reply with quote
Thanks for the heads up Kip, it is always good to know what problem areas might be so that I can keep an eye on them. It is beyond me as to why that would break there, as you say it looks like its just to keep the fabric formed and away from the tube.
Mike
Kolb MK-III Xtra, 912-S
icrashrc
PostPosted: Sat Jul 12, 2008 2:33 am    Post subject: Re: Very Minor Structural Failure Reply with quote
By the way it fractured at the end my uneducated guess would be harmonic resonance in that tube. If your plane was covered the fabric would dampen the vibration.
The good news is because your plane isn't covered it was easy to spot on your preflight! Smile
Scott
www.ill-EagleAviation.com
planecrazzzy
PostPosted: Sat Jul 12, 2008 4:20 am    Post subject: Re: Very Minor Structural Failure Reply with quote
Since it's only for fabric.... Why don't you just take it off....?
I agree with crash....The fabric keeps it from vibrating...
Gotta Fly...
Mike & Jaz in MN
PS I noticed you called it "Structual failure"....not so
N111KX (Kip)
PostPosted: Sat Jul 12, 2008 4:32 am    Post subject: Re: Very Minor Structural Failure Reply with quote
I could have taken it off long ago but I always wanted the option to cover the cage. I'm getting the Dremel out now...
Kip
PS It's structure that failed or, structural failure.
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
planecrazzzy
PostPosted: Sat Jul 12, 2008 5:49 am    Post subject: Re: Very Minor Structural Failure Reply with quote
If you can just take it off.... Then it's not structural....
More for aerodynamics.
Gotta Fly...
Ralph B
PostPosted: Sat Jul 12, 2008 6:24 am    Post subject: Re: Very Minor Structural Failure Reply with quote
Here's another one to keep an eye on. This happened four years ago (June 04).
Ralph
 Filesize:  105.81 KB
 Viewed:  483 Time(s)
 Filesize:  112.97 KB
 Viewed:  471 Time(s)
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
slyck(at)frontiernet.net
PostPosted: Sat Jul 12, 2008 8:04 am    Post subject: Very Minor Structural Failure Reply with quote
Fatigue cracks.
If they are at a vibration node they will happen eventually.
Here's my not so humble opinion: wire feed welds are stronger,
mostly by virtue of the
high nickel alloy but also more rigid in a narrow band than gas
welding, making them
more susceptible to an earlier crack. A gas weld leaves a softer
condition around the weld
and I try to reduce this a little by sponge-water quenching. Right
after the first hard landing
I may (or may not) notice the weld joint taking a little set. After
that it has reached a happy state
of strength that will endure many more similar impacts with no
further distortion.
BB, 50% gas welded MkIII cage
(June 04).
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
21 years flying it
Kolbra 912UL
N20386
0 years flying it
http://forums.matronics.com/viewtopic.php?p=192383#192383
http://forums.matronics.com//files/joint_where_crack_is_875.jpg
http://forums.matronics.com//files/crack_196.jpg
N111KX (Kip)
PostPosted: Sat Jul 12, 2008 8:14 am    Post subject: Re: Very Minor Structural Failure Reply with quote
From the internet so it's true..."structural failure refers to loss of the load-carrying capacity of a component or member within a structure or of the structure itself..."
Now, since you gotta fly and I want to fly, let's fly and keep the thread as a suggestion to others to do a preflight, OK. Rolling Eyes
Gotta Fly...
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
