Humpback whale fins....
rlaird
PostPosted: Fri Jul 11, 2008 4:43 pm    Post subject: Humpback whale fins.... Reply with quote
Really interesting reading... maybe it'll be the next "VG" ! Smile
http://dsc.discovery.com/news/2008/07/11/wind-turbine-whale.html
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
Possums
PostPosted: Fri Jul 11, 2008 5:22 pm    Post subject: Humpback whale fins.... Reply with quote
Maybe not so much for the wings but as a new prop design??
"But the finding has lots of applications on land, too. Putting bumps across the leading edge of a wind turbine means the blades can be oriented at a higher angle to capture more of the wind without worrying about stall -- which can damage the turbines.
They are also targeting industrial fans. "We can move more air and ventilate more area with fewer blades.
The whale-inspired fans also use 20 percent less power and operate with one-fifth the noise of a standard fan, Dewar said."
 Filesize:  18.29 KB
 Viewed:  314 Time(s)
Possum
jbhart(at)onlyinternet.ne
PostPosted: Fri Jul 11, 2008 6:12 pm    Post subject: Humpback whale fins.... Reply with quote
Robert,
Similar studies are underway with wing grids that model bird wing tip
behavior at:
http://www.winggrid.ch/
Also locusts have very good lift to drag ratios due to some peculiar
striations on their wings. A technical paper can be found at:
http://www.winggrid.ch/ICAS_GROV.pdf
Jack B. Hart FF004
Winchester, IN
henry.voris
PostPosted: Fri Jul 11, 2008 7:12 pm    Post subject: Re: Humpback whale fins.... Reply with quote
So... what's the procedure to get a humpback to recover from a stall??? I wonder if they'll spin??? We have gobs of them around here and it's pretty rare to find them a crumpled mess at the end of the runway.
Dr. Fish's work has been around for a while. An article about it in SciAm helped me feel better about the VGs on my FireFly's wings... I've been wondering how they'd work on prop blades...
Henry
Firefly Five-Charlie-Bravo
