rsteele(at)rjsit.com Guest
Posted: Thu Jul 10, 2008 7:25 pm Post subject: Question about Construction Standards/rivet clearance |
I'm at the point of aligning the top skin on the wing. I'm trying
align the pre-drilled holes with the ribs, one of which isn't
perfectly aligned. The problem is the distance to the bend radius.
If I read the Construction Standards correctly as long as the rivet
hole doesn't intersect the bend radius its considered safe. Can
someone verify this or give me a correct interpretation?
Ron
carlossa52(at)gmail.com Guest
Posted: Fri Jul 11, 2008 3:58 am Post subject: Question about Construction Standards/rivet clearance |
Have you tried to gently force the rib into position?
I find that the ribs will move a good 2-3 mm sideways, specially away from the spar.
If you are uneasy with the situation, give ZAC a call.
Carlos
2008/7/10 Ronald Steele <rsteele(at)rjsit.com (rsteele(at)rjsit.com)>:
[quote] --> Zenith-List message posted by: Ronald Steele <rsteele(at)rjsit.com (rsteele(at)rjsit.com)>
I'm at the point of aligning the top skin on the wing. I'm trying align the pre-drilled holes with the ribs, one of which isn't perfectly aligned. The problem is the distance to the bend radius. If I read the Construction Standards correctly as long as the rivet hole doesn't intersect the bend radius its considered safe. Can someone verify this or give me a correct interpretation?
Ron
dvanlanen
Posted: Fri Jul 11, 2008 6:53 am Post subject: Question about Construction Standards/rivet clearance |
Ron,
Here is how Caleb at ZAC answered a similar question for me when I was installing the elevator trim cutout channel and having trouble with one of the existing holes in the elevator skin coming close to the radius of the channel:
“As long as the hole isn't in the radius it will be fine. The rivet tail can be 'overlapping' onto the radius”
Hope this helps,
Dave
Time: 08:25:10 PM PST US
Subject: Question about Construction Standards/rivet clearance
Ron
