dean.psiropoulos(at)veriz Guest
Posted: Mon Jul 14, 2008 9:37 pm Post subject: Trim servo cable routing |
Little items on the way to first flight... Installing the electric elevator
trim servo, I was planning on using the existing trim cable hole in the
elevator spar to route the 5 wire MAC cable out to the horizontal stab and
into the fuselage. But....the MAC servo jackscrew sticks out of the back of
the servo and into that hole also. There seems to be enough clearance but
I'd rather not have the jackscrew impinge on the cable and wear it through,
shorting out the trim motor. Since I'm using the Mac (Ray Allen)cable with
the tiny little wires it's probably a moot point but... Is this a non issue?
Any other routing ideas? I rather not drill any more holes in the elevator
spar web if I can help it. Thanks.
Dean Psiropoulos
RV-6A N197DM
