dan(at)familybrown.org Guest
Posted: Sun Jul 06, 2008 1:47 pm Post subject: FOR SALE: Isham RV Tool Kit with upgrades |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
For a variety of reasons, mostly relating to my being called to active
duty with the Army, I won't be able to complete my planned RV-7A.
Consequently, I'll need to sell my tools. This is the complete Isham
kit pictured at:
http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=9
This kit includes a pneumatic rivet squeezer and the popular DRDT-2
dimpling tool.
In addition, the following extras are included:
Screw-adjustable Rivet Squeezer Ram (a $70 value)
Avery Longeron Yoke (a $150 value)
Avery Thin-nose (no-hole) Yoke (a $140 value)
Avery back-rivet plate (a $50 value)
Avery flush swivel rivet set (a $40 value)
A couple of additional countersink cutters
Additional side-grip clecos (about 10 extra of each, IIRC)
That's $450 in upgrades, in addition to the Isham set. All tools are in
excellent condition. The air drill is NOT, repeat NOT included;
everything else is.
This would cost nearly $3000 for these tools ordered new. I'll take
$2500 OBO, plus shipping. If you're local to Fayetteville, NC, you can
pick up. Contact me by e-mail at dan(at)familybrown.org if interested.
Thanks for your interest!
The following tools are included:
DRDT-2 Dimpler* (email for delivery date on DRDT-2)
Pneumatic Rivet Squeezer (U.S.A.)*
3� C-Yoke Installed on Squeezer (U.S.A.)*
Adjustable Set Holder for Pneumatic Squeezer (U.S.A.)*
3X Rivet Gun with excellent teasing trigger*
EZ change spring for straight rivet sets*
EZ Change Spring for flush sets (Snap-On Ind U.S.A.)*
Swivel and Air Flow Restrictor with fine precision adjustment*
1� Diameter Flush Rivet Set (Snap-On U.S.A.)*
3/32� Cupped Rivet Set 3.5� (Snap-On U.S.A.)*
1/8� Cupped Rivet Set 3.5� (Snap-On U.S.A.)*
3/16� Cupped Rivet Set 3.5� (Snap-On U.S.A.)*
1/8� Double Offset Rivet Set (Snap-On U.S.A.)*
Back Rivet Set* (Special Small 1/2" Diameter for RV's)
Mini-Bucking Bar, 1 lb. (Snap-On U.S.A.)*
Bulkhead Bucking Bar (Snap-On U.S.A.)*
Footed Bucking Bar (Snap-On U.S.A.)*
Microstop Countersink Unit, needle-bearing, non-chattering (U.S.A.)*
#40 Countersink Bit, 3/32� (Snap-On U.S.A.)*
#30 Countersink Bit, for 1/8� & #6 Screw (Snap-On U.S.A.)*
#8 Countersink Bit, #8 Screw (Snap-On U.S.A.)*
#10 Countersink Bit, #10 Screw (Snap-On U.S.A.)*
Left Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
Right Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
Straight Cut Snips, easy to use offset type (Klein Tools U.S.A.)*
#40 Aviation Cobalt Drill Bits for 3/32� rivets, 8 each
#30 Aviation Cobalt Drill Bits for 1/8� rivets, 6 each
#27 Aviation Cobalt Drill Bit
#21 Aviation Cobalt Drill Bit
#19 Aviation Cobalt Drill Bit
#12 Aviation Cobalt Drill Bit
1/4" Aviation Cobalt Drill Bit
12� Aviation Extra Long #40 Drill Bit
12� Aviation Extra Long #30 Drill Bit
Deburr Tool, Speed Handle Type for small & large holes (U.S.A.)*
Cleco Pliers*
4 Cleco Clamps, 1/2" (Calif Assoc Prod or Zephyr U.S.A.)*
4 Cleco Clamps, 1� (Calif Assoc Prod or Zephyr U.S.A.)*
Pop Rivet Tool, Professional Heavy-Duty unit with Swivel Head*
3/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)*
1/8� Universal Cupped Squeezer Set (Snap-On U.S.A.)*
5/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)*
3/16� Universal Cupped Squeezer Set (Snap-On U.S.A.)*
Flat Squeezer Set 1/8� (Snap-On U.S.A.)*
Flat Squeezer Set 1/4" (Snap-On U.S.A.)*
Flat Squeezer Set 3/8� (Snap-On U.S.A.)*
Flat Squeezer Set 1/2" (Snap-On U.S.A.)*
3/32� Rivet Dimple Die (Springback U.S.A.)*
1/8� Rivet Dimple Die (Springback U.S.A.)*
5/32" Dimple Die*
3/16" - #10 Screw Dimple Die*
#8 Screw Dimple Die*
#6 Screw Dimple Die*
Squeezer Set Organizer*
Squeezer Set Adjustment Washers *
Stainless Steel Rule, 12�*
Unibit 1/4" - 3/4" by 1/16ths, (Klein U.S.A.)*
3 Permanent Markers, Sharpie
1/2 x 1 Reducers for 3M Wheel*
325 Cleco Fasteners, 3/32� (Calif Assoc Prod or Zephyr U.S.A.)*
175 Cleco Fasteners, 1/8� (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners, 5/32" (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners, 3/16� (Calif Assoc Prod or Zephyr U.S.A.)*
Edge Deburring Tool, Hex Swivel type*
Fluting Pliers, Smooth Flute Nylon Jaws*
Fluting Pliers, Deep “V� Nylon Jaws*
Rivet Cutter*
Air Tool Oil
Drill Stop Set of 4 with Allen Wrench*
Rivet Set DOTS, Easier than Rivet Tape
3/32� Pop Rivet Dimple Die, Springback (U.S.A.)*
1/8� Pop Rivet Dimple Die, Springback (U.S.A.)*
Hand Seamer (Klein Tools U.S.A.)*
3/32� Drive Pin Punch (Klein Tools U.S.A.)*
1/8� Drive Pin Punch (Klein Tools U.S.A.)*
Scotch Brite Hand Pads, 4 each
Rivet Length Gauge*
Rivet Shop Head Gauge, 4-piece*
Dan Brown, KE6MKS, dan(at)familybrown.org
"Since all the world is but a story, it were well for thee to buy the
more enduring story rather than the story that is less enduring."
~ -- The Judgment of St. Colum Cille
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIcTwsyQGUivXxtkERArQ5AKDXyHERioqiOx7Di9qmwK5lYRUxZwCgxTEO
1xKO82rbsPh08my6buAF1iY=
=GTub
-----END PGP SIGNATURE-----
mkaratsonyi(at)hotmail.co Guest
Posted: Mon Jul 07, 2008 11:52 am Post subject: FOR SALE: Isham RV Tool Kit with upgrades |
do you still have tools for sale?
| Quote: | Date: Sun C 6 Jul 2008 17:42:04 -0400
To: rv-list(at)matronics.com
Subject: FOR SALE: Isham RV Tool Kit with upgrades
--> RV-List message posted by: Dan Brown <dan(at)familybrown.org>
Hash: SHA1
For a variety of reasons C mostly relating to my being called to active
duty with the Army C I won't be able to complete my planned RV-7A.
Consequently C I'll need to sell my tools. This is the complete Isham
kit pictured at:
dimpling tool.
In addition C the following extras are included:
Additional side-grip clecos (about 10 extra of each C IIRC)
That's $450 in upgrades C in addition to the Isham set. All tools are in
excellent condition. The air drill is NOT C repeat NOT included;
everything else is.
$2500 OBO C plus shipping. If you're local to Fayetteville C NC C you can
3” C-Yoke Installed on Squeezer (U.S.A.)*
1” Diameter Flush Rivet Set (Snap-On U.S.A.)*
3/32” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
1/8” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
3/16” Cupped Rivet Set 3.5” (Snap-On U.S.A.)*
1/8” Double Offset Rivet Set (Snap-On U.S.A.)*
Mini-Bucking Bar C 1 lb. (Snap-On U.S.A.)*
Microstop Countersink Unit C needle-bearing C non-chattering (U.S.A.)*
#40 Countersink Bit C 3/32” (Snap-On U.S.A.)*
#30 Countersink Bit C for 1/8” & #6 Screw (Snap-On U.S.A.)*
#8 Countersink Bit C #8 Screw (Snap-On U.S.A.)*
#10 Countersink Bit C #10 Screw (Snap-On U.S.A.)*
Left Cut Snips C easy to use offset type (Klein Tools U.S.A.)*
Right Cut Snips C easy to use offset type (Klein Tools U.S.A.)*
Straight Cut Snips C easy to use offset type (Klein Tools U.S.A.)*
#40 Aviation Cobalt Drill Bits for 3/32” rivets C 8 each
#30 Aviation Cobalt Drill Bits for 1/8” rivets C 6 each
12” Aviation Extra Long #40 Drill Bit
12” Aviation Extra Long #30 Drill Bit
Deburr Tool C Speed Handle Type for small & large holes (U.S.A.)*
Cleco Pliers*
4 Cleco Clamps C 1/2" (Calif Assoc Prod or Zephyr U.S.A.)*
4 Cleco Clamps C 1” (Calif Assoc Prod or Zephyr U.S.A.)*
Pop Rivet Tool C Professional Heavy-Duty unit with Swivel Head*
1/8” Universal Cupped Squeezer Set (Snap-On U.S.A.)*
3/16” Universal Cupped Squeezer Set (Snap-On U.S.A.)*
Flat Squeezer Set 1/8” (Snap-On U.S.A.)*
Flat Squeezer Set 3/8” (Snap-On U.S.A.)*
3/32” Rivet Dimple Die (Springback U.S.A.)*
1/8” Rivet Dimple Die (Springback U.S.A.)*
5/32" Dimple Die*
Stainless Steel Rule C 12”*
Unibit 1/4" - 3/4" by 1/16ths C (Klein U.S.A.)*
3 Permanent Markers C Sharpie
325 Cleco Fasteners C 3/32” (Calif Assoc Prod or Zephyr U.S.A.)*
175 Cleco Fasteners C 1/8” (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners C 5/32" (Calif Assoc Prod or Zephyr U.S.A.)*
10 Cleco Fasteners C 3/16” (Calif Assoc Prod or Zephyr U.S.A.)*
Edge Deburring Tool C Hex Swivel type*
Fluting Pliers C Smooth Flute Nylon Jaws*
Fluting Pliers C Deep “V” Nylon Jaws*
Rivet Cutter*
Air Tool Oil
Rivet Set DOTS C Easier than Rivet Tape
3/32” Pop Rivet Dimple Die C Springback (U.S.A.)*
1/8” Pop Rivet Dimple Die C Springback (U.S.A.)*
3/32” Drive Pin Punch (Klein Tools U.S.A.)*
1/8” Drive Pin Punch (Klein Tools U.S.A.)*
Scotch Brite Hand Pads C 4 each
Rivet Length Gauge*
Rivet Shop Head Gauge C 4-piece*
Dan Brown C KE6MKS C dan(at)familybrown.org
"Since all the world is but a story C it were well for thee to buy the
=GTub
-----END PGP SIG======================
The i’m Talkaton. Can 30-days of conversation change the world? Find out now.
Posted: Tue Jul 08, 2008 5:37 pm Post subject: FOR SALE: Isham RV Tool Kit with upgrades |
i am very interested C however i dont want to low ball you C i am also a veteran of the us army (airborne infantry) and i am on a budget C i really would like to purchase your kit however my budget is $1500 plus shipping if we can make a deal i would greatly appreciate it. Michael
[quote] Date: Sun C 6 Jul 2008 17:42:04 -0400
Hash: SHA1
kit pictured at:
dimpling tool.
everything else is.
Cleco Pliers*
5/32" Dimple Die*
Rivet Cutter*
Air Tool Oil
Rivet Length Gauge*
=GT===
Use video conversation to talk face-to-face with Windows Live Messenger. Get started.
