jim-bean(at)att.net Guest
Posted: Sun Jul 06, 2008 3:49 pm Post subject: Hydraulic fluid |
Posted: Mon Jul 07, 2008 9:24 am Post subject: Hydraulic fluid |
khorton01(at)rogers.com Guest
Posted: Mon Jul 07, 2008 1:51 pm Post subject: Hydraulic fluid |
On 6-Jul-08, at 19:44 , jim-bean(at)att.net wrote:
| Quote: | I was just about to open a can of brake fluid when I noticed it is
MIL-H-5606G rather that the usual MIL-H-5606A. After Googling around
it seems that they should be compatible. Does anyone have an opinion
about whether mixing these two fluids is OK?
MIL-H-5606A is a very early version of the spec. MIL-H-5606G is a
much later version. There should be no problem mixing fluids made
with any versions of the MIL-H-5606 spec.
But, why not use MIL-PRF-83282 brake fluid? It can be mixed with MIL-
H-5606 fluid, but has the advantage of a much higher flash point. And
it isn't expensive either. I bought a quart can of Royco 782, a MIL-
PRF-83282 fluid, from Leavens Brothers in Toronto for $11.25.
Kevin Horton RV-8 (final assemby)
Ottawa, Canada
http://www.kilohotel.com/rv8
t6pilot(at)cfl.rr.com Guest
Posted: Mon Jul 07, 2008 3:50 pm Post subject: Hydraulic fluid |
Kevin:
MIL-H-5606G is the revision level of the MIL-H-5606 standard that particular
manufacturer is certifying to. No impact, meets the latest MIL-H5606
specification.
Randy
bicyclop(at)pacbell.net Guest
Posted: Mon Jul 07, 2008 8:57 pm Post subject: Hydraulic fluid |
Yeah, but if you mix the two, the flashpoint advantage is mostly lost.
The brake system should be drained and refilled with the high test
fluid. There's no need to flush it. One should probably replace the
O-rings in the calipers with Viton ones (# 218-V 1 1/4" X 1 1/2") as
they can handle much higher temperatures than the stock Nitrile O-rings.
You can get a lifetime supply of O-rings for about 10 bucks at any seal
dealer. I got the brown ones so that they don't get mixed up with
Nitrile later.
Pax,
Ed Holyoke
Kevin Horton wrote:
MIL-H-5606 fluid, but has the advantage of a much higher flash point.
And it isn't expensive either. I bought a quart can of Royco 782, a
MIL-PRF-83282 fluid, from Leavens Brothers in Toronto for $11.25.
Ottawa, Canada
