brandon.rigio(at)kodak.co Guest
Posted: Tue Jul 08, 2008 3:46 pm Post subject: FS: RV9/9A Unassembled Tail Kit + Tools + Primer + Construct |
I am putting my unassembled RV9 Empennage (VS spar match drilled) with electric trim option and everything needed to complete the kit up for sale. This includes all the hand tools needed, Sherwin Williams E2G973 primer and reducer, preview plans if wanted, and the construction videos.
This is everything needed to start assembling your RV9/9A right away. Not a single rivet pounded on this kit.
I would like $2500 for everything and need to get rid of it ASAP. If you are planning to start a kit or know someone that is please consider this or pass it along. It is everything you need to start building immediately.
Tools picture: http://server6.theimagehosting.com/image.php?img=tools.6cf.JPG
Tool List:
Pop rivet tool, Cleaveland
3 ¼” Seaming pliers
1 3/4 “ vise grip seaming pliers, Avery
Vosburg edge forming tool
Cleco pliers
Taylor 2X rivet gun, Cleaveland
Sioux 1/4" pneumatic drill
Ct. Sink cage,Avery #19360
Dimple dies #30
Dimple dies #40
Dimple dies #6
Dimple dies #8
Dimple die,female 3/8 Dia. #40
Dimple die,female 3/8 Dia. #30
#40 cupped squeezer set, I pc.
1 3/16 ct. sink cutter, 3 flute #1057,threaded
1-#30 single flute Ct. sink cutter “
1-#19 Three flute Ct sink cutter. “
1-#40 Three flute Ct. sink cutter “
1-#40 single flute Ct. sink cutter “
1-single flute deburring cutter “
1-set #40 Pop rivet dimple dies
1-set #30 Pop rivet dimple dies
1 set #4 screw dimple dies
1-back rivet set
1- Avery swivel flush set
1 Avery flat set
1-#27 3 flute Ct. sink cutter,threaded
1-flat squeezer set 1/8 X ½
1-set, 4 pcs. Plexi drills
1 Avery plastic dimpling hammer
60 Pcs. 1/8” Clecos
1-Rod end bearing tool, wrench
225-- 3/32 Clecos
1- Cleaveland C frame tool
2- Bucking Bars
Thank you,
Brandon Rigio
