shempdowling(at)gmail.com Guest
Posted: Thu Jul 03, 2008 5:21 am Post subject: Dynon draining battery? |
My aircraft battery doesnt seem to be keeping charge as well as it used
to, and its new. I am hearing a rythmic ticking at a one second
interval sometimes but not always, with the master off. I have my Dynon
D-10A wired to charge the internal battery without the master being on.
Just wondering if anyone else has heard this mysterious ticking or
noticed a battery drain with their Dynon.
Shemp
Wesley Robinson wrote:
| Quote: | EAA Chapter 731 is holding their Spring Fly-in at Hickory (KHKY) this
Saturday.
There will be an award for best RV!
See their website for more info: http://www.eaa731.org
Wesley T Robinson
RV-9A N224WR 'The Red Baron'
bill(at)vondane.com Guest
Posted: Thu Jul 03, 2008 6:12 am Post subject: Dynon draining battery? |
Check your hobbs on the dynon... does it appear to be gaining time with
the master off? If so, then you may have the dynon keep alive wired
incorrectly...
-Bill
Shemp wrote:
used to, and its new. I am hearing a rythmic ticking at a one second
Dynon D-10A wired to charge the internal battery without the master
being on. Just wondering if anyone else has heard this mysterious
ticking or noticed a battery drain with their Dynon.
Shemp
> Saturday.
> Wesley T Robinson
dbentley(at)fuse.net Guest
Posted: Sat Jul 05, 2008 5:17 am Post subject: Dynon Draining Battery? |
Yes, I’ve had the problem. I purchased one of the early Dynon models, about 6 years ago. I had it back to the company 2-3 times before first flight with several developmental issues, but received great support. During the first year of flight time, I shut down the aircraft normally one evening and as I was exiting the hangar, I noticed a light from the canopy and found that the Dynon was running (still). I manually shut it down, but found that it turned itself back on again. Knowing it would drain the battery completely, I disconnected it from the buss. After calling Dynon, they suggested that the keep alive circuit was malfunctioning. They told me I could send the unit back again for investigation, or cut the wire from the aircraft power to the backup internal Dynon battery. I did so, and have never had a problem since.
Duane Bentley
RV6 300 hours
N515DB
