daveleikam(at)wi.rr.com Guest
Posted: Mon Jun 30, 2008 7:32 pm Post subject: Rudder pedal mounting |
The instructions have you cut the F-6115 rudder pedal bearing block in half which removes material and causes the part to clamp the rudder pedal assemblies. Has anyone used spacers between the two halfs to prevent the action from being so stiff?
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
Tim Olson
Posted: Mon Jun 30, 2008 8:41 pm Post subject: Rudder pedal mounting |
It won't feel so bad when you actually get them mounted in
the plane and use your feet. Yes, by hand they feel really
stiff though.
Dave Leikam wrote:
| Quote: | The instructions have you cut the F-6115 rudder pedal bearing block in
Dave Leikam
Muskego, WI
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Jun 30, 2008 10:12 pm Post subject: Rudder pedal mounting |
I opened up the holes a bit for a looser fit. You don't need anything super precise there, and less friction is better.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Monday, June 30, 2008 8:29 PM
To: RV-10 matronics
Subject: Rudder pedal mounting
Dave Leikam
Muskego, WI
Bldgrv10450(at)comcast.ne Guest
Posted: Tue Jul 01, 2008 12:35 am Post subject: Rudder pedal mounting |
Dave
I didn't use any spacers on mine. I do however have an alternate center support bushing and mounting bracket that attaches to the stock firewall support bracket, not shown in the photo.
Feedback and questions are welcome however please be understanding, I am typing one finger / left handed from rotater cuff surgery last week.
Paul Grimstad
RV-10 450
Portland, Or.
289.45 KB |
392 Time(s) |
drfred(at)suddenlinkmail. Guest
Posted: Tue Jul 01, 2008 6:23 am Post subject: Rudder pedal mounting |
Paul :
Great looking set of pedals for the 10. Hope your recovery is
progressing well.
Fred Williams.
40515
working through the maze of wiring.
will put the windshield in with weld on and the sides with silpruf.
AV8ORJWC
Posted: Tue Jul 01, 2008 6:42 am Post subject: Rudder pedal mounting |
Wow, now that is what the factory should have designed. And the cables are concealed within the tunnel. Reminds me of building hot-rods. Is the foot pressure stiffer than stock?
Nice photo.
John Cox
RV-10 600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad
Sent: Tuesday, July 01, 2008 1:28 AM
Subject: Re: Rudder pedal mounting
Dave
Paul Grimstad
RV-10 450
Portland, Or.
jim(at)CombsFive.Com Guest
Posted: Tue Jul 01, 2008 6:58 am Post subject: Rudder pedal mounting |
I added washers (same thickness as the band saw blade) between the two parts.
No gaps and no binding.
Jim Combs ======================================================
Date: 2008/06/30 Mon PM 11:29:15 EDT
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Dave Leikam
Muskego, WI
Deems Davis
Posted: Tue Jul 01, 2008 7:04 am Post subject: Rudder pedal mounting |
So when are you going to share (i.e. market) those beauties with the
rest of us ???????
Deems
and the brake cylinders and plumbing are 'hidden' on the back side!!!!!!
ricksked(at)embarqmail.co Guest
Posted: Tue Jul 01, 2008 8:12 am Post subject: Rudder pedal mounting |
Deems,
There is one builder that should be installing a set very soon. I will be
working closely with him on the details.
Marketing effort is slowly underway, for now we are just happy to be back to
building our 10 kit and working on pedal design for the RV6,7 & 9.
Additionally, I have several pedal sets sold and we are planning a small
production run. The system cost is $1,795.
Paul Grimstad
RV10 450
Portland, Or.
Kellym
