Fuel tank sealant available
JFLEISC(at)aol.com
PostPosted: Sat Jun 28, 2008 7:11 am    Post subject: Fuel tank sealant available Reply with quote
All, I finished sealing my fuel tanks and since there is a 2 week waiting time after ordering the sealant I made sure I bought much more than I needed so as not to run out during the job. It went much smoother than anticipated and I have some left over. I have 2 unopened factory sealed pints (one RV-4 tank took me one pint) of PPG P/S 890 B-2 available with a manufacturing date of 6/08. It states a 9 month shelf life. This is the "paste type" and I applied it with a stiff brush. It has an application time of 2 hours (I mixed small batches). After much research including what I learned from this group I found this to be one of the few 'ProSeal' products to specifically list in it's tech sheet that it has the same resistance to alcohol as fuel (I like the option to run Mogas) (see the link below for the PPG tech sheet). I understand that many of the newly formulated sealants are alcohol resistant also however those that I read the tech sheets of made no specific mention of alcohol. It cost me $55 a pint and I will sell to whoever may be interested for $55 for the 2 pints plus shipping. If interested email me at jfleisc(at)aol.com (jfleisc(at)aol.com).
Jim
http://buyat.ppg.com/REP_aerospace_files/Sealants/890b.pdf
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
ceengland(at)bellsouth.ne
PostPosted: Sat Jun 28, 2008 9:36 am    Post subject: Fuel tank sealant available Reply with quote
<mailto:jfleisc(at)aol.com>.
Jim
Actually, the link you sent says:
Charlie
Doug Gray
PostPosted: Sat Jun 28, 2008 2:53 pm    Post subject: Fuel tank sealant available Reply with quote
This 'manganese dioxide cured polysulfide compound' is good ol'
Proseal.
I believe DeSoto and it's previous incarnation (whose name escapes me
for the moment) was the original manufacturer of the product. Like me
the folk in these companies have never changed jobs but have worked for
a string of different corporations.
Doug Gray
JFLEISC(at)AOL.COM
PostPosted: Sat Jun 28, 2008 4:45 pm    Post subject: Fuel tank sealant available Reply with quote
In a message dated 6/28/2008 6:55:12 P.M. Eastern Daylight Time, dgra1233(at)bigpond.net.au writes:
Proseal.
"The product"? I went to their site and under 'sealants' there are quite a few "products", all going by the name "ProSeal' (or P/S) with different suffix numbers depending on the characteristics. Its not the same number "proseal" that, for instance, Aircraft Spruce sells. Which one is the 'good ol' stuff?
Doug Gray
PostPosted: Sat Jun 28, 2008 11:06 pm    Post subject: Fuel tank sealant available Reply with quote
MIL-S-8802 Was the original specification. Manufacturers complied with
the spec or did not get the gig. My original quart cans from Vans were
marked with the Mil-STD reference.
This standard covers a number of variations, I would be surprised if the
PRC product line had variations beyond these.
I believe manufacture is limited to a small number of plants if not one
only with the real industry being repackaging the product. Hence we see
it appearing under a host of labels and package types at corresponding
markups.
Yes you are correct - it might well have been tweaked along the way
especially after the mil-stds were transferred to industry.
Doug
JFLEISC(at)aol.com
PostPosted: Sun Jun 29, 2008 6:09 am    Post subject: Fuel tank sealant available Reply with quote
In a message dated 6/29/2008 3:08:19 A.M. Eastern Daylight Time, dgra1233(at)bigpond.net.au writes:
Therein lies the issue; In my research I came across a lot of "mights, maybes, or rumors". I am also reasonably sure that they, as you say, are all if not pretty close to the same, but to be sure I went with the data sheets and very few referenced alcohol. At least with the ones that do, I have it in writing as being tested for it.
Jim
Kellym
PostPosted: Sun Jun 29, 2008 6:32 am    Post subject: Fuel tank sealant available Reply with quote
I don't know the full history of the sealant, but from a couple updates to the Mooney manuals I can ascertain that in 1966 they were spec-ing PR1221-B-4, mil spec 7502C, while by 1981 the spec changed to PR1422-B2, mil spec 8802, which remains their standard today.
Doug Gray wrote: [quote]
--> RV-List message posted by: Doug Gray <dgra1233(at)bigpond.net.au> (dgra1233(at)bigpond.net.au)
On Sat, 2008-06-28 at 20:40 -0400, JFLEISC(at)aol.com (JFLEISC(at)aol.com) wrote:
markups.
Doug
Kelly McMullen
KCHD
