Wing sling belting
Fergus Kyle
PostPosted: Wed Jun 25, 2008 1:42 pm    Post subject: Wing sling belting Reply with quote
Another cry in the wilderness.........
The original classic trailer wing slings were made from fairly
compliant black rubber which over the years has lent a tender black smudge
on the wing surfaces in my latest transport attempt. Consumed by rage and
jealousy, I ripped the offending materials from the carcass, and am now left
with bitter regret and bits of rubber - and the strange feeling I may have
been a touch venal.
I am assuming that some of the early trailer-ites may have
encountered the same disappointment and discovered a suitable replacement. I
would like to think there's a supple, strong, compliant white compound
(perhaps food belting) out there waiting to be scooped up and a thankful
discoverer just keening to share his victory information.
I've tried gleaning details from McMaster-Carr but I'm no chemist
and the technical characteristics escape me. As a result I have five feet of
intransigent, vicious brown crud in the garage waiting to chew holes in my
wings. I'll hoof it with the pinions strapped to my back first...
If you have superior knowledge and/or experience in this endeavour.
let me be the first to help distribute it. Please?
Ferg
Europa Classic A064 still bumbling ahead
jeff(at)rmmm.net
PostPosted: Wed Jun 25, 2008 2:40 pm    Post subject: Wing sling belting Reply with quote
Ferg,
I don't transport mine but I do have a wing dolly that I've left them
in for a few years while building other parts. I used 8 inch wide
strips of carpet. Good old rugged shag carpet. I still use it when I
have the wings off and it's never left a mark, It's still as strong as
6 years ago when I built the dolly.
Jeff R.
A258 - N128LJ / Gold Rush 126 hours and climbing slowly and is cooling
correctly.
On Jun 25, 2008, at 4:39 PM, Fergus Kyle wrote:
smudge
and
now left
have
been a touch venal.
replacement. I
thankful
feet of
in my
Ferg
raimo.toivio(at)rwm.fi
PostPosted: Wed Jun 25, 2008 3:04 pm    Post subject: Wing sling belting Reply with quote
Ferg,
Definetely I have not but...
I bought an used old trailer from Germany and modified it little.
Later I installed also a floor to it.
First of all I put those rubbers to the hell,
copied the wing shape and made new ones from wood.
Look at the pics, they are yellow!
Over those those wooden blocks I glued some very SOFT and THICK material.
Just to prevent rubbing the wing painting, I use gling film over the wings everytime I carry them.
That works. Hope this helps. My wings are more beautiful than new ones and I have trailered them
20 times = let is say 400 km = 250 miles.
BTW 1: there are somewhere in the USA a copy pair of my wooden blocks and I hope he is happy w them.
BTW 2: I never carry my stabilators on the trailer!!!
Cleaning: I had same problem in a different place. The door rubber seals marked my cream colour doors ugly black. I tried everything like acetone to clean the door´s inside surfaces. Nothing helped - it was like a shit on the wall. Finally somebody gave me a tip to try method "same". My doors were easily cleaned by rubbing them with just ordinary pencil (india) rubber (eraser). Try it!
Terveisin, Raimo
 Filesize:  60.6 KB
 Viewed:  358 Time(s)
 Filesize:  66.17 KB
 Viewed:  330 Time(s)
 Filesize:  89.91 KB
 Viewed:  358 Time(s)
topglock(at)cox.net
PostPosted: Wed Jun 25, 2008 3:06 pm    Post subject: Wing sling belting Reply with quote
6" conveyor belting from McMaster-Carr on my transporter, lined with......... you guessed it, carpet. Three years of to and from (when needed) and no marks on the paint.
Jeff - Baby Blue
JEFF ROBERTS wrote: [quote]--> Europa-List message posted by: JEFF ROBERTS <jeff(at)rmmm.net> (jeff(at)rmmm.net)
Ferg,
I don't transport mine but I do have a wing dolly that I've left them in for a few years while building other parts. I used 8 inch wide strips of carpet. Good old rugged shag carpet. I still use it when I have the wings off and it's never left a mark, It's still as strong as 6 years ago when I built the dolly.
Jeff R.
A258 - N128LJ / Gold Rush 126 hours and climbing slowly and is cooling correctly.
--> Europa-List message posted by: "Fergus Kyle" <VE3LVO(at)rac.ca> (VE3LVO(at)rac.ca)
been a touch venal.
Ferg
Checked by AVG.
kpaviat(at)verizon.net
PostPosted: Wed Jun 25, 2008 4:08 pm    Post subject: Wing sling belting Reply with quote
Hi Fergus! I replaced my sling material with conveyer belt material approx
.050 thick and 4 inches width to support the wing without sagging. To keep
the material from chaffing the wing surface, I first lined the sling with a
thin soft rubber material against the sling and then put a thin layer of
fine felt on the rubber. In other words, the felt contacts the wing so any
rubbing does not result in much friction or staining and the rubber material
absorbs any shock to prevent denting or deformation. You may have to adjust
the width of the metal support at the sling mounting area to allow for
thickness variations. There are numerous materials available from
McMaster-Carr. Hope this helps!
Kim Prout
ptag.dev(at)tiscali.co.uk
PostPosted: Wed Jun 25, 2008 10:49 pm    Post subject: Wing sling belting Reply with quote
Hi! Ferg
I used scrap conveyor belting but lined it with carpet by using a very
strong industrial spray on adhesive. However be careful not to make the
gap too tight or you will squeeze the wing.(lots of places have scrap
belting)
Bob Harrison G-PTAG
pr(at)dcanderson.myzen.co
PostPosted: Thu Jun 26, 2008 12:53 am    Post subject: Wing sling belting Reply with quote
Fergus,
Further to the other replies that you have had which suggest lining the
supporting medium with carpet, the trouble with carpet is that it absorbs
water if you have to trail in the rain. I now use polypropylene belt with
synthetic leather sleeve over the top. I still get a slight mark on the wing
but it is relatively easy to remove.
Roger (G-BXTD)
Fergus Kyle
PostPosted: Thu Jun 26, 2008 6:09 am    Post subject: Wing sling belting Reply with quote
To jeff Roberts, Jeff -Baby blue, Kim, Raimo and Bob,
Thanks for having taken the time to save my wings. I'm going out to
find the carpeting that fits the bill today. Think I'll slide a plate of
polyethylene next the wings, and force the clamps out a bit. Also, I found
Raimo's solution to be ideal - rub out black rubber with a rubber
eraser....... Once again, the net pays great dividends!
Cheers, Ferg
Fergus Kyle
PostPosted: Thu Jun 26, 2008 6:34 am    Post subject: Wing sling belting Reply with quote
I forgot to thank Frank Wood out in Pincher Creek alberta for having taken
the time with the others to solve my problem.
Thanks, Frank (I learned to fly at Claresholm)
Ferg
jimpuglise(at)comcast.net
PostPosted: Thu Jun 26, 2008 9:29 am    Post subject: Wing sling belting Reply with quote
Ferg-
I have gone a little differrent route. I placed the wings vertically (TE down) and covered about 10 inches of the LE and down about 24 inches with plastic. I then took 4 plies of uni about 8 inches X 48 inches and laid them over the LE to use it like a mold. I added plastic on the outside of it and taped it to assure that the UNI held fast to the shape of the wing. After cure, I cut it into two pieces 4 X 48 and used them to outline the shape of the wing on plywood. I made up two pieces from plywood and glued the UNI forms into them. I line the UNI with bubble wrap to transport the wings and it seems to work very well. For those who are having trouble with rubber getting onto your wings, the bubble wrap may ge a good solution. It is very inexpensive and can be used several times.
Jim Puglise A-283
s List [quote][b]
-------------- Original message ----------------------
Cheers, Ferg
