Guy Buchanan
matronics(at)bob.brennan. Guest
Posted: Mon Jun 23, 2008 5:55 am Post subject: New member with UK-built Model II needs parts advice |
Thanks Guy for the excellent links, does anyone have recommendations on the
springs - stainless vs standard, and the prop spinner - aluminum vs
composite?
Since my current aluminum spinner has stress cracks on ALL fitting points
and several missing pieces I am naturally leaning towards a composite
replacement. And my rusty and weak exhaust springs (steel I assume) make
stainless look attractive.
Any experience / opinions on these choices?
Bob
Lynn Matteson
Posted: Mon Jun 23, 2008 11:51 am Post subject: New member with UK-built Model II needs parts advice |
I've got a fiberglas spinner and no problems in 538 hours, and when I
need to change the springs on my Jabiru exhaust pipes, I use ordinary
cad-plated springs from the local hardware store. I get the 12" long
springs and cut to the proper length, and re-form the ends.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/538 hrs
On Jun 23, 2008, at 9:52 AM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
composite?
points
make
Bob
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Jun 24, 2008 5:29 am Post subject: New member with UK-built Model II needs parts advice |
My spinner is as black as the day it was shipped. : ) It fit right
in with my paint scheme (or the other way around), so I left it as is.
Whenever I have the lower cowl off....oil change time of 25-30
hrs....I'll look at the springs, and if any are weak, I'll change
only that one, or those that are weak. My exhaust system is so well
secured (now) that the springs don't really do much. They never
break, and the fact that I have chosen to wrap the joints (between
exhaust pipe and muffler) with a heat-proof tape (Spruce #09-31500),
I think the heat that would cause them to weaken or break is reduced,
so they last a pretty long time. I don't think I've changed any of
them in 50-75 hours. I don't even safety wire them. Stainless would
probably be better, but in my case "if it ain't broke....."
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Define "need to change the springs" please Lynn - does that mean
"broken" or
"rusted" or "change interval is due"? Mine are rusted and one is
broken and
hanging on by the safety wire. If stainless is as strong and do their
"spring" thing as well why use anything else?
I agree with the fiberglass spinner - especially in front of a Jabiru
cowling which is good-looking to begin with. Let me guess - white
spinner
and white cowl with fancy colored lettering? My M2 has J3 cub
yellow with
black go-faster stripes and the big radial cowling. With a 3-blade
wood prop
and gloss black spinner I think mine is darned good looking too
Except
for the cracks in the spinner....
Bob
183.83 KB |
402 Time(s) |
N369LM |
