New member with UK-built Model II
matronics(at)bob.brennan.
PostPosted: Sun Jun 22, 2008 9:42 am    Post subject: New member with UK-built Model II Reply with quote
I would like to introduce myself to this group, I have been monitoring it for several days and am impressed with the wealth of knowledge and helpful Kitfox owners out there. First a tiny bit about me - I got my PPL in the US many years ago, training on a Tomahawk and doing business flying in Cherokees mostly. I moved to the UK for a while and recently got the urge to fly again - bought my Kitfox and trained for a full NPPL (EU equivalent of a PPL) to rebuilt my skills and make the full transition to the Kitfox. My model 2 was built in the UK in 1991 and was in good shape when I bought it, with about 800 hours on the airframe and less than 100 hours since a rebuild on the 582.
I moved back to the US a while ago and brought my Kitfox over in a 20ft container. I haven't flown it here yet and have several questions that will hopefully put it back into top shape first.
Most important question - the inboard leading edge of the flaperon has a steel rod that appears to have been held in with some putty, no doubt a bad repair. The problem is that the rod is the length of the flaperon, it is loose and slides easily, and the putty must have loosened sometime during taking the wings off and putting them back on. After a run-up &taxi and a post-flight inspection I discovered the putty had fallen out and the rod was extended into the flaperon linkage potentially locking the controls. Thank goodness it was only a run-up!
My question(s) - is this a known problem? How should the end of the flaperon be sealed - it appears the port one has bent-over metal possibly epoxied in place? Should that steel rod be loose, and if not how should it be secured? What's the proper repair given that the end of the flaperon is now open?
Thanks in advance,
Bob
Lynn Matteson
PostPosted: Sun Jun 22, 2008 10:09 am    Post subject: New member with UK-built Model II Reply with quote
It sounds like the steel rod is an attempt to balance the flaperon?
Or is it actually a steel tube? A steel tube is used within the
flaperon...they call it the flaperon spar...and the flaperon hinges
pivot on it. But you say it is a rod, so my guess is an attempt to
balance the flaperon...got any pictures?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/530 hrs
Thanks in advance,
Bob
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Sun Jun 22, 2008 11:07 am    Post subject: New member with UK-built Model II Reply with quote
Hi Lynn - thanks for the quick response.
I have taken and attached 2 pix for you, being new to the list I hope it
works. The steel rod (PIC1) is about 3/8" solid steel and is 1/2 the length
of the flaperon, In the picture I laid it on top for you to see. PIC2 shows
it protruding from the leading edge where it should be inside and secured.
The flaperons do not have the counter-weights to stop vibration as I have
seen on other older models, however part of the UK annual airworthiness test
requires the airplane to be flown at Vne (100mph for my model 2) and there
was no hint of vibration or anything other than perfect operation of the
flaperons.
BTW that wasn't your Jabiru 2200 Speedster at the Cub Haven fly-in 2 days
ago was it?
Bob
 Filesize:  153.47 KB
 Viewed:  586 Time(s)
 Filesize:  178.66 KB
 Viewed:  571 Time(s)
Tom Jones
PostPosted: Sun Jun 22, 2008 11:46 am    Post subject: Re: New member with UK-built Model II Reply with quote
[quote="matronics(at)bob.brennan."]
Bob, the steel rod in the Flaperon is a UK modification to balance it. Here is a link to a service letter that describes it along with some other information about your flaperon system.
http://www.kitfoxaircraft.com/support/service_bulletins/sb9.htm
You can find all the Kitfox service letters and bulletins on the Kitfox factory web site http://www.kitfoxaircraft.com/ click on Technical FAQ.
Tom Jones
Classic IV
Ellensburg, WA
PostPosted: Sun Jun 22, 2008 12:35 pm    Post subject: New member with UK-built Model II Reply with quote
Thanks Tom, that explains the steel rods (I checked, there is one in the
port wing as well) and the wing patches on all 10 hangers for the aluminum
reinforcement brackets. It will also allow me to answer the inevitable "you
don't have the counter-weights installed(!!??)" that I get every time
another Kitfox owner sees my plane.
I can't however find an installation document for the UK fix and am not sure
how to re-secure the loose rod and seal the end it is coming out of, and
ensure the other one doesn't come loose in flight.
Bob
Jim Shumaker
PostPosted: Sun Jun 22, 2008 5:09 pm    Post subject: New member with UK-built Model II Reply with quote
Bob
The UK fix is not a factory fix and the securing of the rods is frought with problems. The counter weights as supplied by the factory will be more secure and lighter. Will also save you having to answer those questions about why you don't have them. Wink
Jim Shumaker
Jim Shumaker
Lynn Matteson
PostPosted: Sun Jun 22, 2008 5:18 pm    Post subject: New member with UK-built Model II Reply with quote
That has almost got to be an early attempt to balance the flaperon,
but there are others who may know for sure.
Nope, that wasn't mine. I was originally going to fly to Lock Haven
with a group of guys from Ohio and lower Michigan, but I opted for a
trip to Virginia instead, and that got washed out by my recent prop
problem, (which by the way is not a problem any longer...knock on wood).
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
hope it
the length
PIC2 shows
secured.
I have
airworthiness test
and there
of the
flaperons.
2 days
ago was it?
Bob
Lynn
N369LM
Sbennett3(at)aol.com
PostPosted: Sun Jun 22, 2008 5:48 pm    Post subject: New member with UK-built Model II Reply with quote
In a message dated 6/22/2008 9:20:10 PM Eastern Daylight Time, lynnmatt(at)jps.net writes:
Didn't you mean "knock on prop"? Smile
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
Lynn Matteson
PostPosted: Mon Jun 23, 2008 4:33 am    Post subject: New member with UK-built Model II Reply with quote
Oh, no, never knock on my prop...the splinter might fall off! Then
I'd have to balance it by taking an axe to the other end and
then........
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
used cars.
Lynn
N369LM
