Doing it the proper way!!
airspeedx3(at)yahoo.com
PostPosted: Thu Jun 19, 2008 1:48 pm    Post subject: Doing it the proper way!! Reply with quote
You'll need a Private or sport...
Got it!!
You'll need Airworthiness
Working on it...got the paperwork!
He'll have gone over your Weight and Balance... And he'll tell you he wants it in the FRONT 51% of the CG RANGE ( Better recovery )
Yup!!
> You'll need a Tailwheel endorsement ( Around 10 hrs )
Okay.
Then , Last but not least , you'll need 5 hrs in a "LIKE" aircraft ( varies )
Can we log this simultaneous in the "Tailwheel endorsement plane"?
I SWEAR .... If you do all of this , You will have NO PROBLEM
flying your plane.... ( Just give it extra Left Rudder on take-off )
As it should be!!!! Good advice. I shall follow it. Mike Welch
Gotta Fly...
Mike & "Jaz" in MN
planecrazzzy
PostPosted: Thu Jun 19, 2008 2:22 pm    Post subject: Re: Doing it the proper way!! Reply with quote
More than likely...
When you get a GA Tailwheel endorsement....
The closest thing would probably be a J-3
That's NOT a "LIKE" aircraft...
The plane "I" got mine done in was a two seat "T-Bird"
Close enough.... it was a pusher...
I got my endorsement in a PA-12.....it was fun..
One day "it" was down..., We went up in the J-3.
it was fun , but I was up there for business... I was a little cramped
and I had to "Perform" Short take-off or landings...and other maneuvers
"I" was too cramped in the J-3....it was a waste of time for me....(6' 1")
One other note... At the FAA place , you should also get the book (free)
AC NO: 90-89A....This is the Test Flight Handbook...
It explains what your first 40 hrs of flying should be covering....
From Airport selection.... to everything else...
Gotta Fly...
Mike & "Jaz" in MN
 Filesize:  34.72 KB
 Viewed:  265 Time(s)
