sidsel.svein(at)oslo.onli Guest
Posted: Wed Jun 18, 2008 4:45 am Post subject: Fuel tank dimensions |
I am considering a new tank - I don't like the prospect of a crack when flying over Norwegian terrain - - - - - . Will in case make it higher than the original to compensate for less width (so as to get it into the fuselage after cutting open the cockpit module top) and in order to get more long range fuel capacity.
Before I remove the existing tank, I wish to evaluate tank material, dimensions and design details as far as possible, and only make small adjustments after taking actual measurement of the available space.
I have received a sketch with dimensions from EA2004, but they cannot confirm that it is an as-built drawing. The problem is that the volume calculated on the basis of this sketch is about 20% larger than what our tanks actually contain.
If anyone has a tank not yet installed, I would appreciate very much to receive the dimensions A to E as marked on the attached sketch - in millimeters or inches. Note: Measurement E should be taken close to the centerline, not in way of the recesses for the aileron quick-connects at the sides. I have blacked out the dimensions received from Europa, in order not to mislead anyone.
Best regards,
Svein
LN-SKJ
Tank_w-o_dimensions.pdf |
283.88 KB |
334 Time(s) |
hagargs(at)earthlink.net Guest
Posted: Wed Jun 18, 2008 7:10 pm Post subject: Fuel tank dimensions |
Svein:
It sounds like you are doing almost exactly what I am planning to do. A little higher and a little narrower. It doesn't give too much extra capacity however. I was going to use the bottom of the door sills as my upper limit. So that gives about 2 inches or so. One thing I was contemplating on doing was making a square box section to extend into the baggage bay just over the hump in the middle possibly a 10 X 10 X 8 inch volume about 13 liters in addition to raising the lid.
Here are the dimensions I have in inches: A = 11.00 B = 10.50 C = 15.50 D = 12.00 E = 8.25 Top front = 41.00 Top back = 40.25 Top along seam = 41.125
Inside saddle back = 7.125 Inside saddle front = 6.75
Steve Hagar
A143
Mesa, AZ
Posted: Wed Jun 18, 2008 9:07 pm Post subject: Fuel tank dimensions |
Hi Steve,
Suppose that this mightn't be a great idea, but has anyone considered
cutting the top of the seat back area and simply fiber glassing in the
whole area. My aircraft, (LongEze for example) have the tanks made out
of fiberglass. I bet with a but of care you could expand the capacity
even more.
Just a thought.
Paul
Posted: Wed Jun 18, 2008 10:26 pm Post subject: Fuel tank dimensions |
Steve,
Thank you very much for measuring the dimensions I asked for, plus some in addition. Can you explain where you measured the "inside saddle back" and "inside saddle front"?
Regarding the square box section extending into the baggage bay just over the hump in the middle: I am afraid that this would reduce the transverse strength of the cockpit module (CM) too much. Admittedly, much of the forces from the wings' lift and drag are equalized between them by the cross bar just aft of the CM, but I will not take any risk here.
Cutting off the CM top and refitting it (at same level or higher) will not compromise the aircrafts structural strength. My plan - if I go ahead with it - would be to lift the top at least 4 inches (probably more) to maximize the volume, and make the head rests so that the shoulder belts will go back from my shoulders at an up angle of 35 degrees (ref. previous discussions the spine compression and European VLA seat belt rules).
Best regards,
Svein
craigb(at)onthenet.com.au Guest
Posted: Thu Jun 19, 2008 12:48 am Post subject: Fuel tank dimensions |
I am doing the same as you suggest Svein, and have allowed for it when building the CM and the fuel system. Now that the top of the fusealage
is bonded on, the top of the seats is coming off and i am lifting it up 110mm, one reason is to fix the seat belt issue, the other is to
allow for a second tank sitting on top of the main tank, total volume is 28 litres, giving almost 100litres total, it fills from the return line
on the engine and is set up to be an independant reserve tank, so any fuel in there has already been filtered by the main gascolator. and is then
run through a second gascolator between the reserve tank and the fuel selector. When the reserve tank is full it overflows back into the main
tank. Tank is 1.5mm alloy wrapped in glass using vinyl ester resin, which is what the glasair's are made from and they run wet wings with no lining
(according to a builder I visited)
craig
[quote] --
Posted: Thu Jun 19, 2008 1:35 am Post subject: Fuel tank dimensions |
Craig,
That is a very interesting solution, if I understand you correctly:
- You have the original Europa tank inside the CM
- You cut the head rests off
- On top of the CM you then place the independant reserve tank
- On top of this (probably bonded to the CM) comes low head rests, height adjusted for good angle of the shoulder belts
- The independant top tank feeds the engine (via suction side of electric fuel pump), so that if you should experience a crack in the original tank you still have 28 litres of fuel
- Topping off the independant tank by the fuel return is ingenious - you then avoid dumping unused fuel at the rate of about 9 litres per hour (that's how much goes through the return line even with the very narrow orifice in the line) through a cracked original tank
Questions:
- How will you fill up the top tank before flight - through the standard filler neck somehow, or through a filler opening on its top?
- Wrapping of the alloy tank by vinyl ester resin: I assume this is how you will build the extension of the seat back and the CM back/sides and the new top, plus the new headrests. Will you wrap it closely to the alloy tank to add strength, and make this new "box" tight so that you have an extra barrier in case the alloy tank should spring a leak somehow (I assume so, since you will use vinyl ester which should stand up well agains gasoline)?
- How does vinyl ester bond to the epoxy used in the original CM structure (I am totally ignorant on this, so I am not implying any doubt)?
- Have you done the design of the alloy tank and its fuel in/out connections yet, and figured out how to make the new headrests, etc.?
I think your solution is much better than tearing out a working original tank before it cracks (if it ever does), and would be a nice winter project (when are we ever declaring our airplanes "completed"?!).
Best regards,
Svein
Posted: Sat Jun 21, 2008 11:10 pm Post subject: Fuel tank dimensions |
Svein, yes the wrap of the alloy tank was as you suggested to add a second layer of sealing and make the tank stronger as well. I started
making a totally vinyl ester tank, but had concerns about mounting the
fittings into the tank and getting a good seal. The plan was to allow filling
through the "overflow" from the reserve back into the filler neck above
the main tank inlet, and also if desired the reserve pump could be turned
on during filling, or before, to fill the reserve from the main, as in theory
the main should still have fuel in it. The reserve pump i have will pump
15 litres a minute in free state and up to about 35 psi if restricted which
will fill the reserve quickly either way.
As for the seats and the headrests etc I reuse the original and glass it back on with a slight reduction in width front to back
to maintain the angles. I dint believe it is possible to get a good bond
between epoxy and vinyl ester resin so I have i the reserve tank "captive" between the main tank and the seat top.
Given the reserve tank is long and not very tall, the tank has baffles
to stop the fuel running from side to side if it is less than full.
Its not quite as much fuel as the plug in long range tank Europa sell
but it is close, and it should meet the requirements of only drawing fuel
from one tank at a time that some countries have.
Visit - www.EuropaOwners.org
