michaega(at)verizon.net Guest
Posted: Tue Jun 17, 2008 1:35 pm Post subject: average water temp of 912/914 |
Somewhere I miss what the average operating water (coolant) temp is on the 912/914. Yes, the manual and things I read gives lowest start temp, hot start temp and max temp. But I would really like an average. 180f, 190f, 200f ??? Or would just say 180f to 220f is a good number to keep it in?
George
gfmjr_20(at)hotmail.com Guest
Posted: Wed Jun 18, 2008 2:10 pm Post subject: average water temp of 912/914 |
Mine run 150-170 depending on time of year. Today, ambient was 70 F and water temp was 165 F
George May
601XL 912s
| Quote: | Date: Tue, 17 Jun 2008 14:31:24 -0700
Subject: average water temp of 912/914
.ExternalClass DIV {;} Somewhere I miss what the average operating water (coolant) temp is on the 912/914. Yes, the manual and things I read gives lowest start temp, hot start temp and max temp. But I would really like an average. 180f, 190f, 200f ??? Or would just say 180f to 220f is a good number to keep it in?
George
xEngines-List
A>
| The i’m Talkathon starts 6/24/08. For now, give amongst yourselves. Learn More [quote][b]
Posted: Thu Jun 19, 2008 10:06 am Post subject: average water temp of 912/914 |
Thanks for the info! I don't have the Rotax spider expansion tank and made my own water spider coming into one 1" pipe then into a 1" (in/out at 90 degree) in-line filler neck and cap with built in thermostat system. I planning on putting an 180f thermostat in it and 16 lbs cap. The cap is 1.1bar (16lbs) and Rotax latest recommendations is 1.2bar. Still looking for the 1.2bar that will fit my application.
George
Posted: Thu Jun 19, 2008 11:34 am Post subject: average water temp of 912/914 |
I believe the thermostat I'm using and rotax recommends is 165 F
George
601XL 912s
[quote] Date: Thu, 19 Jun 2008 11:03:47 -0700
Subject: Re: RotaxEngines-List: average water temp of 912/914
.ExternalClass DIV {;} Thanks for the info! I don't have the Rotax spider expansion tank and made my own water spider coming into one 1" pipe then into a 1" (in/out at 90 degree) in-line filler neck and cap with built in thermostat system. I planning on putting an 180f thermostat in it and 16 lbs cap. The cap is 1.1bar (16lbs) and Rotax latest recommendations is 1.2bar. Still looking for the 1.2bar that will fit my application.
George
Roger Lee
Posted: Fri Jun 20, 2008 1:53 pm Post subject: Re: average water temp of 912/914 |
180F-220F is very normal for this time of year. If you are using a 50/50 coolant then 248F is max. In the winter it might be lower in the 165F range. In the winter the warmer the better (i.e. 180F-220F)
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
