ernieandjane(at)naxs.net Guest
Posted: Mon Jun 16, 2008 9:25 am Post subject: Buying? 601HD w/ Subaru EA82 |
I'm looking at a 601 HD w/Subaru EA82 and belt PSRU drive-advertised as 750# ew; 1250# gw and GSC 3 blade 68"prop. Any comments and/or questions that I should ask the seller would be appreciated.The plane is in and registered in Canada, near Windsor, Ont. If I buy, could we do all the paperwork there and I fly it to my home (airport) in VA? before US registration? and new N number? Or do the paperwork there and trailer it (thru customs) to VA? Does the plane have to have a new AW inspection? And will this inspection be similar to the final inspection of any newly finished E-AB? Or could the seller (or his agent) fly it to my VA airport (GDY or 6V3) and do the paperwork here? This (or the trailer) would probably be the best option for me if is legal. Any comments will be appreciated. I know several other engines are being used in the 601's. Is this Subaru a sensible and practical installation for this plane? It has only the header fuel tank- 15 or 16 gals so might be nose heavy?(Larry McFarland, what say you???) The plane and engine have been together since "day one" year 2000.I had not thought about this before,but---Would most of you be comfortable flying(over the Appalachians) with single ignition? (Maybe there are some attitude adjustment pills for that single ignition problem??) BTW, I have flown a 601 HD with Rotax 912 about 30+ hours including first flight and it is about the best compromise for Sport Pilot compliant, looks, speed, economy, flying qualities, (must be tri-gear) 2 seats, cross-country, and local just "plane" fun flying and I hate to let this one get away, trying to avoid as many problems as possible and will be grateful for any help. Thanks in advance. Reply to the list or e-mail me---your choice.
Ernest Deel (aka Ernie)
ernieandjane(at)naxs.net (ernieandjane(at)naxs.net)
Posted: Mon Jun 16, 2008 12:15 pm Post subject: Buying? 601HD w/ Subaru EA82 |
Hi Ernie,
The EA82 is an overhead cam driven engine that has less similarity with
the push rod type EA81 engine. The EA82 was a total redesign valve train
is probably belt-driven like the EJ22. The parts may not have much
shared or in common with the EA81. I don’t have any issues with a good
working single ignition system, but the Nippondenso ignition is
expensive and frail. It’s easily replaced with a heavier and more
bulletproof set of components that cost lots less. Dual ignition is
easily added. The 601 can take an EA81, but not the heavier EJ22, so I’d
be curious what the EA82 does weigh. You might try this link to get some
comparisons to the models.
http://en.wikipedia.org/wiki/Subaru_EA_engine#EA-82
The re-drive would be of interest, because some I’ve seen are a shade
less than satisfactory. You’re lucky it’s a belt drive in any case.
The other two issues are carburetors and cooling. What kind of cooling
system is he using? Is it internal or external and does it work well on
hot days?
Does it have Bings, or a basic carb or throttle body or what? I’d be
reluctant to buy a fuel-injected type simply for its complication.
Given that the plane has been flying since 2000, it probably has most of
the technical adjustments worked out. I’d ask the seller if there are
limitations or problems that have been found. Don’t fall in love with
the 601 without having seen all of it digitally or in-person as that’s a
recipe for disappointment. Being an HD, it would easily fly over the
mountains and provide good balance with full fuel and one person with
gear. The fuel system should be carefully considered as well. Hope for
two electric fuel pumps at the firewall and a gascolator because the
Subaru generally doesn’t have a mechanical one.
I would think you could buy the aircraft, fly it to the U.S. on it’s
registration, then re-register and apply for new N-numbers given the
airworthiness is, or should be, transferable. If not, the FAA can steer
you on that issue.
If there’s anything I can help you with, don’t hesitate to ask. You can
reach me on other detail off-line anytime at larry(at)macsmachine.com
<mailto:larry(at)macsmachine.com>
Best regards,
Larry McFarland
Ernest Deel wrote:
| Quote: | I'm looking at a 601 HD w/Subaru EA82 and belt PSRU drive-advertised
ernieandjane(at)naxs.net <mailto:ernieandjane(at)naxs.net>
dbortol
Posted: Tue Jun 17, 2008 6:18 am Post subject: Buying? 601HD w/ Subaru EA82 |
Hi Ernie,
I know that on my Canadian license I can fly a Canadian registered aircraft in US airspace, but I can not fly a US registered aircraft. I believe these rules are reciprocal, so bottom line, check it out with the FAA first.
Dino Bortolin
On Mon, Jun 16, 2008 at 4:12 PM, LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)> wrote:
[quote] --> Zenith-List message posted by: LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
I would think you could buy the aircraft, fly it to the U.S. on it's registration, then re-register and apply for new N-numbers given the airworthiness is, or should be, transferable. If not, the FAA can steer you on that issue.
