occom
Posted: Mon Jun 16, 2008 3:12 am Post subject: turtledeck input please |
The original builder of my model IV did not use the folding T'deck arrangement. Instead he used the sides and a large single sheet of fairly heavy lexan. I like the idea of doing away with the leaky hinge arrangement but I wonder if there are not some improvements possible on the arrangement I have now.
I'll attach a photo if I can but the setup has the large section attached with only four physical mountings and several feet of velcro. I wonder if a smaller window made of much thinner and lighter lexan and surrounded by aluminum might not prove superior and lighter.
274.4 KB |
347 Time(s) |
henrysfork1(at)msn.com Guest
Posted: Mon Jun 16, 2008 4:01 am Post subject: turtledeck input please |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Dave I did away with the whole turtle deck section and went with one piece of aluminum attached with small screws. It seemed to me to be another source of radiant heat in summer. It works fine too.
Dee Young
Model II
N345DY
Lynn Matteson
Posted: Mon Jun 16, 2008 4:36 am Post subject: turtledeck input please |
I used the LP Aeroplastics domed turtledeck. It utilizes the original
metal framework, but does away with the hinge and the potential water
leakage. I'm sure John McBean sells them, or something similar. The
dome helps strengthens the 'deck and avoids flutter.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/530 hrs
On Jun 16, 2008, at 7:09 AM, Dave wrote:
| Quote: | The original builder of my model IV did not use the folding T'deck
and lighter.
<Pic of plane Sept 11-06 013.jpg>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jdmcbean(at)kitfoxaircraf Guest
Posted: Mon Jun 16, 2008 6:57 am Post subject: turtledeck input please |
We also supply a one piece Lexan turtledeck that is now standard in the kit.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dave
Sent: Monday, June 16, 2008 5:09 AM
Subject: turtledeck input please
Checked by AVG.
6/16/2008 7:20 AM
Guy Buchanan
Posted: Mon Jun 16, 2008 8:57 am Post subject: turtledeck input please |
At 04:09 AM 6/16/2008, you wrote:
| Quote: | | I wonder if a smaller window made of much thinner and lighter lexan and surrounded by aluminum might not prove superior and lighter. |
Mine was built thin and light and the only detraction is that the thin transparency doesn't remain flat, it tends to sag, which is unaesthetic. There is also a lot of weight in the joints between the plastic and aluminum and amongst the aluminum. You might save weight with all thin lexan, domed or wrinkled for stiffness. I'll see if I can remember to weigh mine.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
