chris(at)southernskies.ne Guest
Posted: Thu Jun 12, 2008 4:18 am Post subject: Much foward stick on climbout |
Hello Listers,
I could use some advice regarding elevator and/or engine mount "trim".
While being pretty new to the Kitfox (1 year, 38 hrs experience) I enjoy the plane very much after learning the rudder pedal dance. I am wondering if something can be adjusted on the elevator or the engine mount.
During full power climb out I have to push that stick way forward to maintain even 55 mph airspeed. Once levelled to cruise I still need to push forward (or pull up on the flap handle about half way).
Would a little more down thrust (shim the engine mount on the top) help? What about adjusting the elevator- I have plenty of up or down travel available - never run out while flying or landing.
Once the power is cut, I have to pull back a good bit to maintain 50 on approach or for glide- manual says that part is normal.
All of this may be perfectly normal but I wanted to check with the experienced KF flyers.
My Kitfox was bought after a ground loop by the previous owner and there were some repairs made. Maybe something didn't get rigged correctly?
I use a very long 2 blade wooden climb prop due to a very short field. Climbs great but very low cruise speed- around 70.
Any comments would be appreciated, on or off line
Chris Bowles
KF 3 N727PD
Rotax 582
pwmac(at)sisna.com Guest
Posted: Thu Jun 12, 2008 5:00 am Post subject: Much foward stick on climbout |
One of the Skystar tips way back when was to have multiple holes in
the front elevator attachment in order to fine tune the elevator
angle to deal with the issue you have..
Paul
At 06:16 AM 6/12/2008, you wrote:
Hello Listers,
Chris Bowles
KF 3 N727PD
Rotax 582
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Jun 12, 2008 5:07 am Post subject: Re: Much foward stick on climbout |
| Quote: | | During full power climb out I have to push that stick way forward to maintain even 55 mph airspeed. Once levelled to cruise I still need to push forward (or pull up on the flap handle about half way). |
Chris,
Definitely not normal to have to push stick to climb. Some questions come to mind real quick:
Where is the leading edge of the horizontal stab mounted? Most are as high as they can get it?
Where is the center of gravity when you fly?
Can you measure the thrust line of the engine compared to the wing?
For what it's worth. My classic four climbs at 60 mph hands off with full power, 6200 rpm, CG 12.5 inches, 72 inch warp prop.
Just a tiny bit...about 1/2 inch up flap handle... to trim hands off level at 5800 rpm.
CG limits are 10.2 to 16 inches so this example is with CG nearer the foreword limit.
Leading edge of horizontal stab is in the middle hole. As near as I can measure engine thrust line is about 1 or 2 degrees down compared to the bottom of the wing root rib. Don't quote me on the thrust line as my measuring method was crude.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Thu Jun 12, 2008 7:10 am Post subject: Much foward stick on climbout |
At 05:16 AM 6/12/2008, you wrote:
| Quote: | During full power climb out I have to push that stick way forward to
This part is not normal. My stick forces change very little between
climb and cruise.
| Quote: | Would a little more down thrust (shim the engine mount on the top)
I would check the thrust vector and shim it to 0 vertically. I like
the performance and diminished thrust trim response that gives. I
would check your decalage. (Angle between wing and horizontal stab.)
I minimized mine by raising the horizontal leading edge as much as possible.
| Quote: | Once the power is cut, I have to pull back a good bit to maintain 50
This is normal.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Posted: Fri Jun 13, 2008 3:58 am Post subject: Much foward stick on climbout |
Thank you all for the tips. I forgot to mention that I have a BRS behind the co-pilot seat. Not sure how any weight could be moved forward- if this is a CG issue- perhaps the ELT battery, it is behind the seat also. Battery is in engine compartment. I did not build the plane but checked the builders log regarding CG and that all looks o.k. The BRS was added afterward but there is no other option to mount it. The header tank is behind the seats also. I'm a lightweight pilot at 160 lbs. With a passenger its not as pronounced.
I'll do another CG check but I suspect the thrust line or rigging is at fault.
The prop is a 2 blade Tennessee Propeller 72x44- somewhat lighter than the 3 blade Ivo that was damaged in the groundloop by the previous owner.
The engine was removed and sent for overhaul so perhaps when it was put back in something didn't get installed the way it was- if there is any down angle to it in the first place.
I did move the forward attachment bracket on the horizontal stabilizer in the uppermost hole already but still need plenty of forward stick when climbing. If I were to let go of the stick during climb the plane would quickly pitch up and likely stall (haven't tried it....) it scares me a bit and I would like to fix it.
Chris Bowles
KF 3 N727PD
Rotax 582
Posted: Fri Jun 13, 2008 5:05 am Post subject: Much foward stick on climbout |
Yes I bet the cg is not optimum and is worth checking.
Options :
- Bigger main battery - heavier
- Remove the BRS not much use for it on a slow plane. - lighten up
the plane & move the cg fwd.
- Move the elevator. Drill another hole . If no room take it off and
add metal to provide more room for the next hole. These items are
common fixes discussed over the years.
The elevator and heavy battery are mods that degrade the performance.
Lighter weight will help performance more than you think.
IMO. I would not mess with the engine mount.
Paul
Chris Bowles
KF 3 N727PD
Rotax 582
Tom Jones
Posted: Fri Jun 13, 2008 6:08 am Post subject: Re: Much foward stick on climbout |
| Quote: | Thank you all for the tips. I forgot to mention that I have a BRS behind the co-pilot seat. Not sure how any weight could be moved forward- if this is a CG issue- perhaps the ELT battery, it is behind the seat also. Battery is in engine compartment. I did not build the plane but checked the builders log regarding CG and that all looks o.k. The BRS was added afterward but there is no other option to mount it. The header tank is behind the seats also. I'm a lightweight pilot at 160 lbs. With a passenger its not as pronounced.
I'll do another CG check but I suspect the thrust line or rigging is at fault. |
Chris, with the above information I now lean heavily toward an adverse aft CG being the problem. If I am understanding the chart on the BRS web site, one mounted behind the seat is heavy enough to move the CG aft.
http://brsparachutes.com/files/Documents/BRS%20Retail%20Price%20List%20June%2008.pdf
Given the history of modifications to the airplane you should re-weigh it to be sure.
Edited to remove the 80 pounds. I see now the BRS is not near that heavy. But still recommend you re-weigh the airplane.
Classic IV
Ellensburg, WA
thesupe(at)hotmail.com Guest
Posted: Fri Jun 13, 2008 6:44 am Post subject: Much foward stick on climbout |
I just looked in the Aircraft Spruce catalog, and the cannister packed 1050 lb BRS weighs 28 lbs and the soft pack weighs 24 lbs. Just my opinion, but shouldn't you do a weight and balence so you know for sure. Planes somehow get heavier as they age (like a lot of wives) (fortunatly not mine) and adding 24 or 28 lbs at once is quite a change. I think the FAA regs probably would require the W/B also with that much change. Jim Chuk Avids, kitfox 4 Mn
[quote] Subject: Re: Much foward stick on climbout
Date: Fri, 13 Jun 2008 07:08:44 -0700
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
Chris, with the above information I now lean heavily toward an adverse aft CG being the problem. If I am understanding the chart on the BRS web site (over 80 pounds for a 1050 model) one mounted behind the seat is heavy enough to easily put the CG behind the aft limit of a kitfox.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=187729#187729
Instantly invite friends from Facebook and other social networks to join you on Windows Live™ Messenger. Invite friends now!
Tom Jones
Posted: Fri Jun 13, 2008 7:31 am Post subject: Re: Much foward stick on climbout |
I edited my post above to remove the 80 pounds weight of the BRS. I was confused by their chart. I was thinking the three systems were three parts of one system so I added them all together. Not so.
Classic IV
Ellensburg, WA |
kitfoxmike
Posted: Fri Jun 13, 2008 1:14 pm Post subject: Re: Much foward stick on climbout |
before you do anything, you must do a weight and balance. Once you are done with that, than we can help you. Make sure and give us the specs from the weight and balance.
kitfoxmike
Posted: Fri Jun 13, 2008 1:16 pm Post subject: Re: Much foward stick on climbout |
Oh and if you didn't know, the weight and balance is done with dry weight. No fuel and no extras like luggage.
dave
Posted: Fri Jun 13, 2008 4:59 pm Post subject: Re: Much foward stick on climbout |
DO a W & Balance.
and /or remove the BRS -- then re weigh.
try it without the BRS.
don;t want to stir a controversy on BRS but I will say that I won't fly a pane that needs a chute unless it strapped to me and I am doing test flights.
I notice you move your horizontal stab up a notch ? I have flown Kitfox with it too low after float removal and it does give a little pull. Kitfox control are very light overall though.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
kitfoxmike
Posted: Fri Jun 13, 2008 7:12 pm Post subject: Re: Much foward stick on climbout |
No way, leave the BRS on when doing the weight and balance, it is part of the aircraft. Chances are you have too much tail weight. Besides you need to know what your current problem is. Sorry to say this, but the BRS is a must if you have a 2 stroke. I'm going to catch heck now.
dave
Posted: Sat Jun 14, 2008 2:14 am Post subject: Re: Much foward stick on climbout |
Mike ,
That I meant in above message -- do W & B first .........
Then if too far aft remove the BRS and try it .......... if the Cof G become in range again then remove it and test fly it.
As far as the 2 stroke comment -----what ever .......... 99% of all engine failures stem from the operator .. 912s die too as do any engine.......... most issues are fuel related. My Kitfox has 470 hours on the last engine i put in June 2006 and that is my 3rd engine in this plane.
And furthermore I would certainly rather land engine out in control that with a BRS taking you were it wants to . Kitfoxes make good gliders.
Dave
Catz631(at)aol.com Guest
Posted: Sat Jun 14, 2008 2:48 am Post subject: Much foward stick on climbout |
Chris,
What you could do,as I did,is to install an elevator trim tab. I too have the classic 4 with the BRS behind the seat. I am much heavier than you and have the stab adjusted to the bottom hole vs the top. I was getting an arm like "Popeye" holding back pressure on landing. I also had to hold a little forward pressure on take off and in cruise which I solved by installing a little bungee device on the stick (as I once had in a Tailwind)
Finally I said enough of this mickey mouse stuff and I ordered an elevator trim system from Highwing LLc .I installed the "hat" switch on the stick and I can now take off , cruise and land almost hands off. No more elevator pressure. It is the best improvement I have done on the aircraft. I feel your pain !
Dick Maddux
Fox 4-1200
Pensacola,Fl
Vote for your city's best dining and nightlife. City's Best 2008.
Posted: Sat Jun 14, 2008 2:58 am Post subject: Much foward stick on climbout |
My Fox 4 has the BRS behind the co pilot also and my battery is on the inside of the firewall (pilot compartment side). I weigh 230 lbs (I know lard ass) I am running the 912 which is somewhat heavier than the 2 stroke I believe.
I just did a weight and balance a month ago and I am comfortably within the cg limits and no way to get out of limits without exceeding gross (which I won,t do)
Dick Maddux
Pensacola,Fl
shinco(at)bright.net Guest
Posted: Sat Jun 14, 2008 5:12 am Post subject: Much foward stick on climbout |
kitfoxmike wrote:
http://forums.matronics.com/viewtopic.php?p=187836#187836
Checked by AVG.
WOW,Mike that Hurts,,Steve Shinabery N554KF KF2 with the mighty 582
Float Flyr
Posted: Sat Jun 14, 2008 3:55 pm Post subject: Much foward stick on climbout |
I wouldn’t say you’ll catch heck... But if your plane needs to have a BRS to be safe then you have the wrong plane. One of the nice things about the ‘Fox is it lands pretty nice deadstick. It may be of some use in the case of a mid air incursion. In such a case the BRS itself may be damaged. If you have felt safe flying without the BRS then pull it and gain the weight advantage and help your balance situation which sounds to be seriously aft.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
Going 912, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
20724 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
EMAproducts(at)aol.com Guest
Posted: Sun Jun 15, 2008 1:13 pm Post subject: Much foward stick on climbout |
Fellow builders Happy Fathers Day!
I was glad to see that some of you gave good information re the forward stick on climbout~~
As a 25,000 hour pilot I attribute a lot of my non scary experiences to always doing a weight and balance prior to every flight in a new aircraft, be it a Pitts S-2, Aeronca C-3 or a new to me homebuilt. The cause of many accidents is improper weight and balance because the pilot didn't do it correctly ~~ and have a flight advisor or another pilot double check your work. A tail heavy aircraft is nothing less than dangerous. Some certified aircraft will NOT recover from a spin if 1/4 " aft of approved CG. This is from an FAA Test pilot that was doing spin testing several years ago. If I recall his comments correctly 3 times out of 5 recovery was normal, other two they had to pop the spin chute. Limits are critical ~~We have enough accidents in our homebuilt aircraft without these type of flights.
Talk to someone who has flown an aircraft of same make and model. Get them to go over your data, insure all parameters are correct, including your currency prior to that first flight. If it doesn't feel right ~~Something is probably wrong. I've flown three KitFox, with Honda & Rotax of different power engines, they all flew fantastic, trim was excellent on all.
Elbie Mendenhall
CFI since '62
EAA Flight Advisor
Posted: Mon Jun 16, 2008 4:42 am Post subject: Much foward stick on climbout |
Thanks again for the info. I will do a new W&B and add some weight somewhere in the front if needed - the only option here appears to be a lead block under the engine mount or a heavier prop. Can't take anything away in the rear and don't feel like removing the BRS- it seems like a great option in case of a structural failure or mid-air. Seems to me a BRS is like an airbag in a car- you'll likely never need it but the one time you did need it it was good to have. I don't want to add to the discussion about the merits of having a parachute in the first place- it's a personal choice maybe.
Once established the CG within limits and problem still exists it seems the trim tab would be a great addition.
Chris Bowles
KF 3 N727PD
Rotax 582
| Quote: | Time: 03:48:44 AM PST US
Chris,
pain !
Dick Maddux
Fox 4-1200
Pensacola,Fl
