Monowheel Tailwheel fairing
ward.t(at)xtra.co.nz
PostPosted: Wed Jun 11, 2008 2:58 am    Post subject: Monowheel Tailwheel fairing Reply with quote
Hi there,
Has anyone made an effective tailwheel fairing protection cap. I have found the damage on the fairing leading edge has been quite substantial.
Any ideas of a fix?
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
CHRISTCHURCH 8052
NEW ZEALAND
Ph :64 03 3515166
Mob: 021 0640221
email:
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Tim_Ward.vcf
 Filename:  Tim_Ward.vcf
 Filesize:  384 Bytes
 Downloaded:  256 Time(s)
paul.the.aviator(at)gmail
PostPosted: Wed Jun 11, 2008 5:02 am    Post subject: Monowheel Tailwheel fairing Reply with quote
Hi Tim,
I think Ramio was experimenting with some tail wheel fairing
protection. He might be worth a try.
Regards, Paul
raimo.toivio(at)rwm.fi
PostPosted: Thu Jun 12, 2008 11:01 am    Post subject: Monowheel Tailwheel fairing Reply with quote
Paul - you remember correct.
Maybe that is because we belong to the same club: EEC (Europa Electrocute Club).
BTW my name is Raimo not Ramio...
Tim - after one single take-off from gravel I lost plenty of tail wheel painting.
That is because a prop is a powerful sandduster.
I have a dark painted fairing so it was immediately ugly looking.
The fairing is also very weak - so after many gravel take-offs I assume whole fairing will broke.
I covered itīs front surface by 3M 08210 film anti-abrasion = car body adhesive tape.
It is designed to protect carīs surface against little stones & sand hit in critical places.
It is transparent - so almost invisible and so my fairingīs colour is still "black cherry".
If you have white (like all "good" builderīs have) fairing, it is even more important to protect because you cannot see those hits so easily.
The film cover is very strong but when it starts to broke, it is easy to see and tape it again.
I use same material in the sides of the undercarriage to prevent rubbing when trailering.
Also I taped those areas where the doorsīs shooting bolts will hit if forget them into locking position when closing the doors. Almost all Europas have lost the painting in those areas (except my Europa Wink ).
Raimo
OH-XRT, voluntary grounded so far (fucken lightning strike tried to beat me but did not succeeded
