Technique For Pull Riveting In Tight Places
dvanlanen
PostPosted: Tue Jun 10, 2008 11:23 am    Post subject: Technique For Pull Riveting In Tight Places Reply with quote
I came across a great suggestion in an EAA "Hints For Homebuilders" video
clip for pulling rivets in tight places by using a small homemade "wedge"
between the rivet and the gun. Go to the following link, then scroll down
to "Pull Riveting In Tight Places"....
http://www.eaa.org/video/homebuilders.html?videoId=1568084461
The nice thing about this approach is that you do not need to modify the tip
on your riveter. However, the example was filmed on a Sonex project, where
the head of the rivet does not need to be formed to a dome-shape during the
pull, as we do on our Zenith aircraft. Has anyone successfully used this
technique on their Zenith project, and if so, how did you mirror the
required dome-shape in the wedge for properly forming the rivet? I had my
rivet tips modified by the factory when I was there for the rudder workshop,
but I wasn't present when they did it, so I don't know how it was done. I
do not have any machining tools, if that is what is needed. Any help /
suggestions would be appreciated.
Dave Van Lanen
Madison, WI
601XL - tail nearing completion
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.84 KB
 Downloaded:  533 Time(s)
bryanmmartin
PostPosted: Tue Jun 10, 2008 12:16 pm    Post subject: Technique For Pull Riveting In Tight Places Reply with quote
I domed my own heads by chucking the head in a drill motor and
spinning it while grinding with a small grinding stone in a Dremel
tool. You could probably do the same with the wedges.
video
"wedge"
scroll down
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
Peter Barthold
PostPosted: Wed Jun 11, 2008 1:07 am    Post subject: Re: Technique For Pull Riveting In Tight Places Reply with quote
Hi Dave,
I knew about the technique with the wedge shaped nosepiece. So far, I never had to use it. Maybe the 601 does not have the crammed spaces a sonex has?.
However, the concave shape of your riveter nosepieces is not hard to do.
Look here:
http://www.petersprojekt42.de/tipsntricks.htm
keep on building
Peter
601HDS
wings in progress
