Trailing edge material
l.morris(at)tx.rr.com
PostPosted: Tue Jun 10, 2008 8:45 am    Post subject: Trailing edge material Reply with quote
Was looking thru some parts boxes and came across a package labeled "trailing edge material ,vertical stab" part # 11078.201. Having already done that area,I went back to find out where it went. I could'nt find that part # on the inventory list so I'm assuming that isn't used on the speedster model andthe factory forgot to remove it from the kit. Could someone confirm this? Leon Morris/Classic 4 Sptr/65%/Flower Mound,TX
Lynn Matteson
PostPosted: Tue Jun 10, 2008 3:16 pm    Post subject: Trailing edge material Reply with quote
Leon-
What does the material look like? I searched my Parts List and
Packing Lists and could not find that number.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/528 hrs
Lynn
Kitfox IV-Jabiru 2200
N369LM
thesupe(at)hotmail.com
PostPosted: Tue Jun 10, 2008 7:01 pm    Post subject: Trailing edge material Reply with quote
Just guessing, but is that the foam used to close up the gap between the verticle stabalizer and the rudder? Jim Chuk Avids, Kitfox 4 Mn
[quote] From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Trailing edge material
Date: Tue, 10 Jun 2008 19:14:08 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Leon-
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> --> Kitfox-List message posted by: <l.morris(at)tx.rr.com>
_-==============================================
Now you can invite friends from Facebook and other groups to join you on Windows Live™ Messenger. Add them now!
PostPosted: Wed Jun 11, 2008 7:36 am    Post subject: Trailing edge material Reply with quote
Lynn, it was foam material wraped and labeled and in one of the boxes.It wasn,t listed on any of the parts list. Leon Morris
---- Lynn Matteson <lynnmatt(at)jps.net> wrote:
Leon-
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
PostPosted: Wed Jun 11, 2008 9:32 am    Post subject: Trailing edge material Reply with quote
Picture is worth a thousand words.... Is this what you are asking about? (yellow foam on back of vert. stab) Jim Chuk  Avids, Kitfox 4 Mn
PS don't mind the mess in the garage!!
Date: Wed, 11 Jun 2008 11:33:40 -0400
Subject: Re: Trailing edge material
> Leon-
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> > labeled 'trailing edge material ,vertical stab' part # 11078.201.
Instantly invite friends from Facebook and other social networks to join you on Windows Live™ Messenger. Invite friends now!
 Filesize:  147.58 KB
 Viewed:  427 Time(s)
PostPosted: Wed Jun 11, 2008 2:09 pm    Post subject: Trailing edge material Reply with quote
Thanks, that's what I thought it was.My speedster has some other fiberglass piece. Guess I don't need it. Leon
---- Jim_and_Lucy Chuk <thesupe(at)hotmail.com> wrote:
Picture is worth a thousand words.... Is this what you are asking about? (yellow foam on back of vert. stab) Jim Chuk Avids, Kitfox 4 MnPS don't mind the mess in the garage!!> Date: Wed, 11 Jun 2008 11:33:40 -0400> From: l.morris(at)tx.rr.com> To: kitfox-list(at)matronics.com> Subject: Re: Trailing edge material> >
https://www.invite2messenger.net/im/?source=TXT_EML_WLH_InviteFriends
Fox5flyer
PostPosted: Thu Jun 12, 2008 6:14 am    Post subject: Trailing edge material Reply with quote
What mess? That looks like an operating room!
On Wed, 11 Jun 2008 17:26:40 +0000, Jim_and_Lucy Chuk <thesupe(at)hotmail.com> wrote:
Re: Trailing edge material> > --> Kitfox-List message posted
by: <l.morris(at)tx.rr.com>> > Lynn, it was foam material wraped and labeled
Morris> ---- Lynn Matteson <lynnmatt(at)jps.net> wrote: > > --> Kitfox-List
message posted by: Lynn Matteson <lynnmatt(at)jps.net>> > > > Leon-> > What
does the material look like? I searched my Parts List and > > Packing
Lists and could not find that number.> > > > Lynn Matteson> > Kitfox IV
Speedster> > Jabiru 2200> > Status: flying w/528 hrs> > > > > > > > > > On
Jun 10, 2008, at 12:43 PM, <l.morris(at)tx.rr.com> wrote:> > > > > -->
Kitfox-List message posted by: <l.morris(at)tx.rr.com>> > >> > > Was looking
thru some parts boxes and came across a package > > > labeled 'trailing
edge material ,vertical stab' part # 11078.201. > > > Having already done
that area,I went back to find out where it > > > went. I could'nt find
that part # on the inventory list so I'm > > > assuming that isn't used on
the speedster model andthe factory > > > forgot to remove it from the kit.
Could someone confirm this? Leon > > > Morris/Classic 4 Sptr/65%/Flower
Mound,TX> > >> > >> > >> > >> > > > > > > > >-==========================>
