Header tank venting
cffd(at)pgrb.com
PostPosted: Sun Jun 08, 2008 8:18 am    Post subject: Header tank venting Reply with quote
A header tank certainly will allow a steep approach without fear of
unporting the fuel port at the rear of a wing tank (even a one gallon header
would work).
How do you vent the header tank if air gets into it when a wing tank gets
unported?
Chuck D.
N701TX
n85ae
PostPosted: Mon Jun 09, 2008 5:20 am    Post subject: Re: Header tank venting Reply with quote
Not sure what you mean, the header tank vent goes from the top of the
header to the top of one of the main tanks. The nice thing is you can
be turning and banking, etc. The header can be getting intermittent
feed, but still provide a constant source of fuel for the engine.
Jeff
