Lynn Matteson
Posted: Fri Jun 06, 2008 8:42 am Post subject: Slow flying... |
I just flew my personal best (or is that worst?) slow ground speed,
covering the ground at an amazing 9 mph. The wind was about 220° (at) 7,
according to the local (JXN) ATIS, but up at 3000' MSL, it was about
37kt, according to Ft. Wayne, IN "winds aloft" reports. At any rate,
I was being blown at 162mph GPS groundspeed (108mph airspeed) toward
the east, when I decided to turn back and see how slow I could fly
groundspeed into the wind. I was at 3000 MSL, heading about 250°, and
I started slowing the plane down. I kept the same 3000 altitude until
I got the groundspeed down to 20 mph, then I started to lose
elevation....about 125fpm on the VSI. I kept throttling back until it
got down to 9mph groundspeed, 55mph airspeed, and I quit playing
games when I got down to 2700' MSL. This was with no flaps, and I
think the rpm was about 1900 at that point...not paying too much
attention to that detail.
I've heard about people flying backwards, and I was pretty close to
that, but chickened out before I got over my head. Has anybody slowed
their Kitfox to a negative groundspeed? I'm not trying to claim any
records, but it would be informative to know if anybody has slowed
more than this, and what problems, if any, should one look out for
doing this.
Lynn
Model IV Speedster, 2200 Jabiru with 520+ hours
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
n85ae
Posted: Fri Jun 06, 2008 9:19 am Post subject: Re: Slow flying... |
I once bounced on takeoff because my plane got airborne so fast that
the mains were off before I realized it, and I pushed the stick forward
a bit to lift the tail and the already flying mains hit the ground. It was
about a 20KT headwind straight down the runway.
Jeff
wingnut
Posted: Fri Jun 06, 2008 10:24 am Post subject: Re: Slow flying... |
| Quote: | I've heard about people flying backwards, and I was pretty close to
doing this. |
I've never flown backwards but I've gotten close to zero with no loss in altitude. I was in the middle of a long cross country at 8000ft when I noticed my ground speed was pushing 150. I just did a 180 and trimmed for level flight at 50mph. I don't see why you'd have to look out for anything in particular though. You could be flying backwards at 100mph but as long as there's no turbulence and your airspeed is above stall then you're OK right?
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Lynn Matteson
Posted: Fri Jun 06, 2008 10:59 am Post subject: Slow flying... |
It seems that way to me, Luis.
Lynn
On Jun 6, 2008, at 2:24 PM, wingnut wrote:
| Quote: | You could be flying backwards at 100mph but as long as there's no
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=186535#186535
N369LM |
n981ms(at)yahoo.com Guest
Posted: Fri Jun 06, 2008 11:01 am Post subject: Slow flying... |
I did. Smooth air but strong wind at about 3500 ft. Flaps out just to see how slow it would go. Very near stall so I was concentrating on airspeed, altitude, and groundspeed. The groundspeed started to go up and my passenger said "hey we're going backwards".
Maxwell Duke
S6/TD/IO240
Dublin, GA
--- On Fri, 6/6/08, Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | From: Lynn Matteson <lynnmatt(at)jps.net>
Subject: Slow flying...
Date: Friday, June 6, 2008, 12:39 PM
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
doing this.
Lynn
josandt(at)verizon.net Guest
Posted: Fri Jun 06, 2008 11:14 am Post subject: Slow flying... |
Years ago there was an article (I think it was in Sport Aviation... can't be sure) about a guy who flew backwards down the runway at a local airshow at about 10 kts... it was thought at the time the article was written to be the only guy to have accomplished the feat (at least at a public event).
doing this.
<<I've never flown backwards but I've gotten close to zero with no ...>>
John Sandt, Kitfox 7 project, Ridgecrest, CA
Michel
Posted: Fri Jun 06, 2008 11:19 am Post subject: Slow flying... |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Not a Kitfox, Lynn, but in our club, a Rans S5 took off from runway 36 and did a traffic pattern without changing heading! At about 800 ft, it went backward and landed on the same runway with the nose still pointing to the north.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
dave
Posted: Fri Jun 06, 2008 1:14 pm Post subject: Re: Slow flying... |
| Quote: | I got over my head. Has anybody slowed
their Kitfox to a negative groundspeed |
Yes I have flown my Kitfox backwards. You GPS will not show a negative number though. You have to look at the ground in relatation to your strut or your landing gear to see it . Next Time I will take a movie for you.
winds here over 20 knots on ground today maybe higher up higher --maybe I will try to break away today for a backwards flight aloft ?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Fri Jun 06, 2008 1:18 pm Post subject: Slow flying... |
Was the "backwards flying" just an observation, or did you see a
reading that was negative? I'm not doubting you, I'm just curious if
your GPS or whatever instrument would show a negative speed.
Lynn
On Jun 6, 2008, at 2:59 PM, W Duke wrote:
| Quote: | I did. Smooth air but strong wind at about 3500 ft. Flaps out
backwards".
Maxwell Duke
S6/TD/IO240
Dublin, GA
7, according to the local (JXN) ATIS, but up at 3000' MSL, it was
about 37kt, according to Ft. Wayne, IN "winds aloft" reports. At
any rate, I was being blown at 162mph GPS groundspeed (108mph
airspeed) toward the east, when I decided to turn back and see how
slow I could fly groundspeed into the wind. I was at 3000 MSL,
heading about 250°, and I started slowing the plane down. I kept
the same 3000 altitude until I got the groundspeed down to 20 mph,
then I started to lose elevation....about 125fpm on the VSI. I kept
throttling back until it got down to 9mph groundspeed, 55mph
airspeed, and I quit playing games when I got down to 2700' MSL.
This was with no flaps, and I think the rpm was about 1900 at that
point...not paying too much attention to that detail. I've heard
about people flying backwards, and I was pretty close to that, but
chickened out before I got over my head. Has anybody slowed their
doing this. Lynn Model IV Speedster, 2200 Jabiru with 520+ hours
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
N369LM |
Lynn Matteson
Posted: Fri Jun 06, 2008 1:22 pm Post subject: Slow flying... |
Ok, Michel....that's pretty dramatic proof of backwards flying. I had
a friend say he took off on a runway, lifted up a bit, and found
himself looking at the spot he departed from....the start of the
runway. Thanks...
Lynn
On Jun 6, 2008, at 3:15 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
Cheers,
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
Lynn Matteson
Posted: Fri Jun 06, 2008 1:39 pm Post subject: Slow flying... |
How did I just KNOW that you'd have done it, Dave : )
On Jun 6, 2008, at 5:14 PM, dave wrote:
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=186576#186576
N369LM |
skyflyte(at)comcast.net Guest
Posted: Fri Jun 06, 2008 2:15 pm Post subject: Slow flying... |
I have flown backwards too! I took off, flew streight ahead for about 10 minutes, decended and landed on the departure end of the runway I departed! Not in my Kitfox, but a weight shift Quicksilver in the early days of ultralighting.
Mike
Model II N490MC
[quote] --> Kitfox-List message posted by: Lynn Matteson
> --> Kitfox-List message posted by: "dave"
> winds here over 20 knots on ground t oday m > h [quote][b]
helili(at)chahtatushka.ne Guest
Posted: Fri Jun 06, 2008 2:39 pm Post subject: Slow flying... |
Rearward flight, or flying backwards, is no chore at all. Ask any helicopter pilot.
John Hart
KF IV
Wilburton, OK
Retired US Army Helicopter pilot
Guy Buchanan
Posted: Fri Jun 06, 2008 2:40 pm Post subject: Slow flying... |
At 09:39 AM 6/6/2008, you wrote:
| Quote: | I'm not trying to claim any
doing this.
Well. . . landing will be a little tricky.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
temco(at)telusplanet.net Guest
Posted: Fri Jun 06, 2008 3:16 pm Post subject: Slow flying... |
Dave
You are quite right the GPS will not register backwards --- but all you have
to do is look at it and it will tell you that you have now turned 180
degrees and going at some speed ""Backwards"" As you accelerate from
backwards it will again swing towards you heading. Nuf said.
Ted
DO NOT ARCHIVE
SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Fri Jun 06, 2008 3:17 pm Post subject: Re: Slow flying... |
Here's a Husky flying backwards.
http://www.youtube.com/v/c99ZHZw97rU&hl
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel |
Lynn Matteson
Posted: Sat Jun 07, 2008 9:34 am Post subject: Slow flying... |
I think you're right, Guy....let's see....mains first, then gently
touch the tailwheel, allowing it to caster around, then stick in gut
to plant the tail...no problem!
Hmmmmm....come to think about it, go-arounds would be a bitch!
Lynn
On Jun 6, 2008, at 6:35 PM, Guy Buchanan wrote:
> doing this.
Guy Buchanan
San Diego, CA
N369LM |
Float Flyr
Posted: Sat Jun 07, 2008 12:57 pm Post subject: Slow flying... |
Lynn:
My instructor had me do the flying backwards while training (C172N).. We were about 5000’ over the field when we pulled the airspeed back to bout 60 and sure enough slowly but surely we drifted backwards enough that it was easy to see. On regular intervals he would have me slow the plane down and hang on the prop at full throttle until it stalled.
Wind at the ground was close to 30 and I certainly wouldn’t have been flying solo that day.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
| Description: |
| Filesize: |
7.29 KB |
| Viewed: |
12255 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Sun Jun 08, 2008 7:45 am Post subject: Slow flying... |
Interesting to hear all the various tales of backwards/reverse
flying, here and in person. Sure opens ones eyes to the various
aspects of putting something up into the elements...thanks folks.
Probably better not to try landing backwards with floats though, eh
Noel. Oh wait a minute, here comes Dave to tell us he's done it! : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/528 hrs
On Jun 7, 2008, at 4:54 PM, Noel Loveys wrote:
| Quote: | Lynn:
Noel Loveys
N369LM |
Scotty(at)dembones.net Guest
Posted: Sun Jun 08, 2008 8:08 am Post subject: Slow flying... |
Hi all
I'm a long time "lurker" here.
Unfortunately Something happened Friday to a very close family friend that
is quite along the line of this thread and I just have to share it with you.
http://www.adn.com/news/alaska/story/429625.html
Scott Hutson
Avid Model C
Rans S9
Mooney
Walla Walla Wa
