lamprey(at)infocom.co.ug Guest
Posted: Sat Jun 07, 2008 11:11 pm Post subject: Wheels up landing... |
My condolences to Jos... I really do think it will happen one day to anyone with a monowheel.
I have just done the same, with my classic here in Uganda. Details are: Classic with 912UL, warpdrive ground adjustable, I've flown 500 hours in her. After a series of circuits, let the gear handle down halfway to slow down, and forgot the final movement and lock. Landed on soft grass, even softer underneath from recent rain... big bang, prop shatters, slide to halt... with instant recognition of the problem and feeling like complete idiot...
As usual, it the trail of events, having flown 60 hours in the previous 3 weeks in a Cessna 182 with gear safely welded down!... general fatigue and just not with it.
Minimal damage to the airframe, wiped off the transponder antenna, the fuselage flap fairings are slightly grazed. When we raised it with a hoist, wheel came down a locked quite normally, and all inspection so far says the undercarriage / engine frame is OK. On 'landing' the wheel went it to be supported by the throttle box, and that will need some work (do Europa have these or do I have to fabricate a new one as in the old days?).
The engine is the problem, it has the slipper clutch, but the gearbox sounds pretty graunched on turning the prop. So, I have to get the Rotax specialist up from South Africa (3000 km away) to go through the whole thing - big expense!!. Apparently you cant use the warpdrive hub again, but at least I have spare blades.
Can anyone with similar experience tell me what else I should look for on the general inspection...?
Many thanks, and greetings to all the fraternity.
Richard Lamprey
carl(at)flyers.freeserve. Guest
Posted: Sun Jun 08, 2008 2:16 am Post subject: Wheels up landing... |
Hi Richard - sorry to hear of your mishap.
Just a personal observation but I feel that lowering the gear halfway is a habit that may have contributed towards your expensive landing. Its a nuisance but I have always lowered and locked the undercarriage down well before getting onto finals (ie: downwind leg). The lowering of the gear prompted by using the checklist in the circuit and a final confirmation of gear locked down on turning finals (and catch locked in gate).
But then I have only logged 200 hours to your 500 so it may happen to me yet.
I have smashed a prop (same as yours) due to a groundloop but luckily the engine was idling and all that was required was a check on the gearbox - fortunately the UK Rotax agent is only 30 miles away. I didnt have to replace the prop hub, just the blades. Nearly 180 hrs flown since the ding and no problems.
Im surprised your gearbox appears to have sustained so much damage. I thought the point of the slipper clutch was to prevent this.
Again comiserations,
Carl Pattinson
G-LABS
paul.the.aviator(at)gmail Guest
Posted: Sun Jun 08, 2008 9:20 am Post subject: Wheels up landing... |
Hi All,
I have over a thousand hours of retract time, but in a single pilot
operation I still wonder when my turn to leave the gear up will come.
So, with all that said I am becoming more interested in what systems I
can put in place to minimize a gear up landing. Once I got the
oportunity to get some time in an Airforce 3 axis simulator for a
KC135. One thing that really impressed me were the voice alerts at 50
and 30 feet generated from a radar altimeter.
While systems like this are getting beyond the scope of home builders,
I was wondering if anyone has had good experience with ultrasonic
based devices that can perhaps measure 10 feet off the ground.
I am thinking that taking inputs from manifold pressure, airspeed,
gear microswitches and some altitude input and feeding them into a
simple micro controller could generate a nice warning system.
With that said there are plenty of examples of two pilot operations
ignoring gear up warnings, but having an additonal system in my
aircraft would be nice.
I'd be interested in peoples input and ideas. If as a group we can
come up with an approach I would be prepared to build and program a
suitable micocontroller.
Paul
Posted: Sun Jun 08, 2008 9:35 am Post subject: Wheels up landing... |
Paul McAllister a écrit :
| Quote: | I'd be interested in peoples input and ideas. If as a group we can
Paul and all,
A couple of microswitches in series on the throttle lever and gear to
trigger a horn when the throttle is retarded and the gear up works very
well.
FWIW,
Best regards,
Gilles
http://contrails.free.fr
Posted: Sun Jun 08, 2008 11:41 am Post subject: Wheels up landing... |
Hi Gilles,
Yes that was my original thought too. My Comanche had a similar
setup, but once I still found myself turning from base to final with
the gear up after a distraction from the Control Tower who were trying
to advert a mid air.
Would it have worked when I finally closed the throttle? The Comanche
like many aircraft with a higher wing loadings liked to be landed
carrying a little power. I could imagine a scenario where I wasn't
warned until I was in the flair which would have been very late.
Still thinking about it. Thanks for the idea, keep them coming.
Paul
Posted: Sun Jun 08, 2008 11:48 am Post subject: Wheels up landing... |
| Quote: | Would it have worked when I finally closed the throttle? The Comanche
How about setting the switch at 10 % power or so ?
Best regards,
Gilles
Posted: Sun Jun 08, 2008 1:53 pm Post subject: Wheels up landing... |
Hi Jos
Thx. for sharing your experience.
Wayne and I built a 5 pound, 3/4 hp 4 foot flying wing. To make it make it
more manageable on landing we installed articulatable NASA Leading Edge
droop. Worked great, but if you touched down with droop down, it would
break the Sullivan actuator/s. Thus we modified the transmitter with a
simple button, when you flare, push button and droop retracted.
My feathers were severely ruffled after the second time I forgot to
retract. On a good day I would be just about following the aerocraft, but
could get behind it very easy. Needless to say I spent plenty of time
changing actuators! First was to have Wayne remind me to retract on flare,
spent time replacing actuators. Made a checklist and stringent procedure,
spent time replacing actuators. Slightest thing not go perfect as
anticipate and could forget to retract.
I can make a direct comparison to forgetting to drop Europa gear.
"When" I forget to drop Europa gear, we made what is a pretty structural
up stop for swing arm:
http://www.europaowners.org/modules.php?set_albumName=album216&op=modload&name=gallery&file=index&include=view_album.php
Installing an adjustable pressure switch driven by pitot (purchased from
Europa, what they use for stall warner) to liven things up below lets say
70 knots, and a switch for each outrigger and a switch for lever down
latch. Will drive a bright LED aimed at pilots eyes, and probably a stick
shaker. Stick shaker will be a mini cell phone style mini motor with
offset weight. If all is well will get 3 green LEDs.
Here is a how we ran wires for outrigger switches:
http://www.europaowners.org/modules.php?set_albumName=album217&op=modload&name=gallery&file=index&include=view_album.php
Will not get green LED unless outrigger latch is ready to take some abuse
without collapsing.
BTW installed a lever downlatch spring to make sure latch stays down:
http://www.europaowners.org/modules.php?set_albumName=album215&op=modload&name=gallery&file=index&include=view_album.php
My Undercarriage mounting frame had things undercenter! Anyone with a
monowheel best make sure you have overcenter by at least 1/16" up to bout
3/32"
Hi Paul
"I was wondering if anyone has had good experience with ultrasonic
| Quote: | based devices that can perhaps measure 10 feet off the ground."
Can's say we have good experience, but some experience:
http://www.europaowners.org/modules.php?set_albumName=album236&op=modload&name=gallery&file=index&include=view_album.php
Ron Parigoris
Posted: Sun Jun 08, 2008 2:25 pm Post subject: Wheels up landing... |
Gilles Thesee wrote:
That's exactly what our leader, (Burt Rutan) drew up in the Long EZ
plans, for the same reason.
Graham
<Gilles.Thesee(at)ac-grenoble.fr>
Paul and all,
very well.
FWIW,
Best regards,
Checked by AVG.
raimo.toivio(at)rwm.fi Guest
Posted: Sun Jun 08, 2008 2:33 pm Post subject: Wheels up landing... |
Paul and all,
well.
FWIW,
Best regards,
Gilles
I have a similar system with high bright red and yellow leds + a horn.
Works well but I am sure if mentally loaded enough ALL the warnings are useless.
Automatic gear lowering is the only answer (!) then but what happens if...
Raimo (fixed gear makes life too easy)
