Main landing gear
John75142
PostPosted: Tue Jun 03, 2008 2:47 pm    Post subject: Main landing gear Reply with quote
I am in the process of installing axles to the main gear. Plans show welding a 3/4" bolt to a plate that is then bolted via 4-1/4" bolts to the outside of the main gear.
What would be wrong with welding the bolt to the plate head and all then bore the 3/4" hole through the main and install the welded piece from the inside of the main in the same fashion 4- 1/4" bolts that will also mount the brake caliper.
Seams this would offer a bit more support.
Any help welcome.
John (Scratch building 701)
Kaufman, Tx
John Short
