carl(at)flyers.freeserve. Guest
Posted: Sat May 24, 2008 10:29 am Post subject: Help! Mod 52 or 74 |
Does anybody have a kit for either Mod 52 or Mod 74 (with the tie bar
assembly) that hasnt been fitted yet
I need the dimension of the W34 mushroom end which fits inside the steel
tube tie bar. To be precise I need to know exactly how long the shaft is
that protrudes from the rear of the mushroom flange - preferably in mm but
inches would be OK.
The reason is that I may have drilled the inboard holes through the tie bar
in the wrong place - dont ask how this came about , its a long story. I
believe the dimension should be 2" or 51mm but im hoping it is nearer 55mm.
As mine is now glued in place I cant check my own dimensions without ripping
everything apart (which I may have to do anyway if it is seriously out).
Carl Pattinson
G-LABS
craigb(at)onthenet.com.au Guest
Posted: Sat May 24, 2008 1:33 pm Post subject: Help! Mod 52 or 74 |
My W34 reads as 53.85mm from the end of the tube to inside of flange (the
outside being the face that goes
against the side of the fuse)
Posted: Sat May 24, 2008 3:27 pm Post subject: Help! Mod 52 or 74 |
<craigb(at)onthenet.com.au>
(the
outside being the face that goes against the side of the fuse)
craig...if I understand you correctly, you have either a very short
tube or a bad case of fuselage obesity for which there is no known
cure...Fred
believed to be clean.
Posted: Sat May 24, 2008 4:02 pm Post subject: Help! Mod 52 or 74 |
Yeah i put a car jack in there to give me the wide body mod the fast way
only joking
vgunn(at)platinum.ca Guest
Posted: Thu May 29, 2008 9:02 pm Post subject: Help! Mod 52 or 74 |
why did you BAN me?
i dont talk much but WHy?
skyward
Posted: Fri May 30, 2008 3:06 am Post subject: Help! Mod 52 or 74 |
Umm Not me mate
craig
