jskiba(at)icosa.net Guest
Posted: Wed May 28, 2008 9:11 pm Post subject: Bridge Diodes use |
Okay, if you use the bride diodes to power a device from two power sources.
Which one will carry the load?
Or will they both share the load in some way?
I thought I read or heard someplace that the power source with the higher
voltage takes the load but how much? All of it?
I hope this question makes sense.....
For example if a device draws 10 amps and is powered by bridge diode with
power source 1 at 13.8 volts and power source 2 at 13 volts
Will source 1 take the whole load all 10 amps ?
Or will they share it in some fashion and how do you calculate that ?
I ask since I want to make sure I do not over load my two power source
config.
Jeff.
nuckolls.bob(at)cox.net Guest
Posted: Thu May 29, 2008 2:32 am Post subject: Bridge Diodes use |
At 12:05 AM 5/29/2008 -0500, you wrote:
| Quote: | I thought I read or heard someplace that the power source with the higher
correct
| Quote: | I hope this question makes sense.....
config.
Diodes used in this manner are not intended to
be load sharing devices. Their only function is
to make sure the load has voltage from at least
one source AND to prevent backfeed of energy from
a good source into a failed source.
Thus they are electrical ISOLATION.
( -Thomas Paine 1776- )
Posted: Thu May 29, 2008 7:12 am Post subject: Bridge Diodes use |
| Quote: | | Jeff,I assume that you have two power sources so that if one fails, then the other will carry the load. If that is true, then each circuit should be designed to carry the full load. |
Joe
_________________ Joe Gores |
Posted: Wed Jun 04, 2008 5:49 am Post subject: Bridge Diodes use |
At 11:10 AM 5/29/2008 -0400, you wrote:
| Quote: | Jeff,
Correct.
Posted: Wed Jun 04, 2008 6:42 am Post subject: Bridge Diodes use |
Yes I do have two power sources (one with 90 amp capacity and one with 20 amp) and would plan on each being able to carry the load.However if Both are powered, from all the posts I read,the power source with the Higher voltage will take ALL the load correct ?I ask since the two sources are not of the same capacity, aka during "normal ops"I would want to use the large capacity source to power the device connected to the diode.then if it fails the small device will pick up the load (with the help of extra battery capacity) until I can bring the load down on the smaller buss.Hope that makes sense :-)or am I missing something ?Jeff> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > <nuckolls.bob(at)cox.net> > > At 11:10 AM 5/29/2008 -0400, you wrote: > >>Jeff, >> >>I assume that you have two power sources so that if one fails, then the >>other will carry the load. If that is true, then each circuit should be >>designed to carry the full load. > > Correct. > > Bob . . . > [quote][b]
Posted: Wed Jun 04, 2008 6:25 pm Post subject: Bridge Diodes use |
At 09:24 AM 6/4/2008 -0500, you wrote:
| Quote: | Yes I do have two power sources (one with 90 amp capacity and one with 20
Correct.
| Quote: | I ask since the two sources are not of the same capacity, aka during
"normal ops"
| Quote: | Hope that makes sense
I guess I don't understand your architecture. Did you
start with one of the Z-figures?
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Jun 05, 2008 6:21 am Post subject: Re: Bridge Diodes use |
| Quote: | Note 24. When you have critical loads that you would like
to accommodate with dual power sources, the 4-diode
bridge rectifier offers an easy to acquire, easy to mount,
easy to wire solution. The figure for this note illustrates
which terminals are used. Figure Z-19 shows one example
of how the device is used.
If your critical system draws more than 4 but less than 8
amps, the diode bridge should be mounted on a metallic
surface for heat sinking. If the loads are heavier, say 8 amps
up to the 25 or 30 amp rating of the device, perhaps a finned
heat sink is called for. (Aeroelectric Connection Note 24). |
But let's be careful out there. Remember that a 25A Full Wave Bride is made up of four 12.5 Amp diodes. One must never make the mistake of thinking you can use it for 25A currents in a power-source-selecting circuit like Z-19. Bigger diodes are required.
"In times of rapid change, experience could be your worst enemy."
---Jean Paul Getty
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Thu Jun 05, 2008 10:15 am Post subject: Bridge Diodes use |
At 07:21 AM 6/5/2008 -0700, you wrote:
> heat sink is called for. Consult the membership of the
> AeroElectric List for guidance in these special cases.
True! When I picked the bridge rectifier assembly for
it's mechanical considerations (easy mounting, fast-on
tab connections) the smallest device that came in that
package was a 25A rated, full wave rectifier. 35A
devices also come in that package. See:
http://aeroelectric.com/Pictures/Misc/s401-25.jpg
It didn't occur to me then that a builder would find
a practical application that would 'overload' the device
electrically. As you've accurately pointed out, there
are applications other than e-bus normal feed-path
circuits that could begin to load one of these critters
to it's rated limits. Referring to an exemplar
data sheet . . .
http://aeroelectric.com/Mfgr_Data/Semiconductors/gbpc12.pdf
. . . it's not clear but should be understood by
the astute reader that only 1/2 of the components of
a bridge rectifier are 'working' at any given time
on alternate half-cycles of the incoming AC
waveform. The data sheets don't offer a continuous
duty rating for single devices. In practice, I suspect
the individual devices can be used at more than 1/2
the ratings for the total package. It's a matter of
getting the heat out.
From the neophyte builder's perspective, limiting
continuous current on a single device to 1/2 the
rated current for the whole device is a no-brainer
conservative approach that will not disappoint.
But keep in mind that ANY semi-conductor loaded
to it's maximum continuous ratings dissipates
heat . . . energy that must be removed through
the mounting surfaces for the device. Further,
no matter how large the ratings for any
device - if the installation does not also take
care of the heat generated. 10A of current flowing
in a 100A rate part can smoke the device!
There's nothing electrically 'magic' about the
diode bridge rectifier illustrated above. It was
originally suggested for its convenience of
installation into systems that originally placed
very low demands on its electrical abilities . . .
no large concerns for rejecting heat. However,
as one considers pushing the practical limits
for this or any other device, close attention
to ratings, limits and installation is called
for.
Thanks for bringing this up Eric.
longg(at)pjm.com Guest
Posted: Fri Jun 06, 2008 6:03 pm Post subject: Bridge Diodes use |
Wow, thanks - of course that is nice to know information before you buy the B & C 25A
Diode and heat-sink which conservatively carries 12.5 A continuous.
I know, read b4 you buy.
Ok, then I need to go bigger. Can I melt the diode off the B & C heatsink to re-use?
Looks like BR's are relatively cheap.
All about Bridge Rectifiers
http://hyperphysics.phy-astr.gsu.edu/Hbase/electronic/rectbr.html#c2
Where to buy...
$5.00 in the UK
35A job
http://www.reuk.co.uk/Buy-35A-Bridge-Rectifiers.htm
Here's an 80A job for $6.50
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360059397300
With this 80A (conservatively 40A capacity unit) does my little 20A Ebus load need a heat-sink? Do I need to fear voltage
collapse if this thing is only getting 14V ?
Glenn
Eric M. Jones
Posted: Tue Jun 10, 2008 6:16 am Post subject: Re: Bridge Diodes use |
More on Diodes and FWBs:
On B & C Diode Installation sheet they state that "Heatsink must dissipate 0.6 X Amps = Watts. Example For 20 Amp Essential Bus, 0.6 X 20 = 12 Watt Heatsink".
But this is wrong and points out a common fallacy regarding diodes:
With two resistors in parallel, the resistance of the combination is 1/2.
With two MosFets in parallel, the Rds(on) of the combination is 1/2
When using two (or any number of DIODES in parallel, the combination of the Vf's is still only Vf. B & C didn't understand this, and thus the dissipated wattage is twice what is stated. And remember--this bridge rectifier will ONLY handle 12.5 Amps with an infinite heatsink and NO margin when used in a source-selecting configuration.
This brings me back to my tired old point that anyone using regular diodes need to re-evaluate their choice. I have sold MANY HUNDREDS of PowerSchottkys to builders who understand this. For Z-19 etc. builders, check out the IXYS DSS 2x61-0045A Dual Power Schottky Rectifiers. 30A on each leg. I sell these with heatsink and Y-jumper, etc., but you can buy your own.
Before being concerned by the higher price--consider the savings in the much smaller, lighter heat sink, the higher performance, and the FAR LOWER COST OF OWNERSHIP.
Someday my friend Bob will abandon this FWB stuff and go with Schottky Diodes. But I guess you can't get them at Radio Shack.
---Jean Paul Getty
Power_Deuce_Schottky_ Manual.pdf |
49.35 KB |
1513 Time(s) |
113 Brentwood Drive
(508) 764-2072
etienne.phillips(at)gmail Guest
Posted: Tue Jun 10, 2008 8:34 am Post subject: Bridge Diodes use |
| Quote: | >On B & C Diode Installation sheet they state that "Heatsink must dissipate 0.6 X Amps = Watts. Example For 20 Amp Essential Bus, 0.6 X 20 = 12 Watt Heatsink".
In my experience, I have never come across a 12W heatsink. Nor a 1W or 1000W heatsink.
A heatsink is chosen appropriate to the temperature rise above ambient the casing of the device can tolerate, or what the spec-sheet says. A single machined-bolt head can dissipate 12W without any additional cooling, however only when it reaches 200 degrees C (thumbsuck). If you can only tolerate a 1degC increase in temperature, the heatsink required to dissipate 12W will be the size of a large desk.
So, a specsheet specifies the heatsinking requirements in [degrees above ambient]/[Watt], or specifies the maximum allowable temperature. So consider an ambient of 23degC, a maximum of 100degC, and we have calculated that the device will need to dissipate 10W. That gives us a requirement for a 7.7deg/Watt heatsink, which can be ordered accordingly.
I understand the calculations relating to dissipation of heat, and IIRC a Schottky diode, with a forward bias voltage of 0.2V rather than the 0.6~0.7V of a regular diode, dissipates 1/3 the energy for a given current. However, there are always other considerations that have not been touched in this discussion (such as thermal robustness, vibration tolerance, ease of mounting), some of which are the same for both Schottky diodes and for normal ones, and others which will draw very clear lines in the sand precluding one or both from certain applications.
Posted: Tue Jun 10, 2008 9:05 am Post subject: Bridge Diodes use |
Eric,
Thanks for the information. On Saturday I hooked up the B & C diode with
heat sink attached for a 6 hour load test (Z-19). I turned on 15 amps
worth of stuff to see if it would start smoking or something of the
sort. Initially it got 30-35 C but later cooled down below 30 C for the
duration of the run. No adverse behavior to report. If my load gets any
higher I'll be over the Schottky fence.
The Schottky device certainly looks more robust and if it runs cooler, I
may be the next fan.
kuffel(at)cyberport.net Guest
Posted: Tue Jun 10, 2008 4:09 pm Post subject: Bridge Diodes use |
Eric,
Am loath to get between you and Bob when discussing electrons but
don't understand what you said about bridge diode heat
dissipation. If one diode is running 20 amps with a forward
voltage of 0.6 then it generates 0.6 x 20 = 12 watts of heat.
If two diodes in parallel are carrying the same 20 amps then the
current is split between the two diodes, with each having more or
less half the load with a total of 20 amps between them. So each
diode is generating about half of 12 watts with a total
generation of still only 12 watts not 24.
What am I missing?
Tom, AL7AU
mprather(at)spro.net Guest
Posted: Tue Jun 10, 2008 4:47 pm Post subject: Bridge Diodes use |
I'm with you Tom..
The only thing I'd add is that a diode has a pretty sharp knee in it's I-V
curve - where it's "resistance" goes from looking high (small change in I
for a large change in V) to where it's "resistance" looks low (large
change in I for small change in V).
If two unmatched devices are used in parallel, process differences between
them can cause one of the devices to turn on (forward bias) before the
other, and carry noticeable more current in that operating region.
Since significantly more voltage than the knee voltage is available in
this application, we can be fairly confident that both devices will be
fully forward biased, and the power drop should be fairly equal.
It's also likely that both devices come from the same fab lot (and wafer)
and so their electrical properties are probably essentially matched.
Matt
<kuffel(at)cyberport.net>
Eric,
What am I missing?
Tom, AL7AU
Eric M. Jones
Posted: Tue Jun 10, 2008 5:57 pm Post subject: Re: Bridge Diodes use |
| Quote: | Eric,
What am I missing?
Tom, AL7AU |
Tom et al.
If either one or two or a hundred conventional diodes is sharing the load, they still dissipate Vf X A. Where A is the current through the device; in this case the Full Wave Bridge (FWB) or Schottky Module.
The important point is that Vf is not reduced by putting parts in parallel. (But it is increased by putting parts in series....)
(True, each diode carries less current, but the package is what we bolt to the heat sink. In fact you can distribute the heat dissipation by distributing the parts, and this is done on some designs, since small parts have greater surface area per volume, so they might not need a heat sink at all.)
| Quote: | If one diode is running 20 amps with a forward
voltage of 0.6 then it generates 0.6 x 20 = 12 watts of heat. |
If pigs had wings!....The error I pointed out is the claim that a B & C FWB, when wired so that two diodes are parallel, would have a Vf of 0.6. It does not; the Vf is often 1.2 maybe, and someone incorrectly assumed that the diodes being in parallel made the Vf sum 0.6. The very best conventional FWB diodes are 0.9Vf at 10A for each diode (you can't buy these at Radio Shack), so it dissipates (2X0.9X10A=) 18W VERY BEST CASE., and 24W worst case if the diodes are Vf=1.2.
By the way, FWB packages are just four diodes wired up to four terminals and epoxy potted in a little box. You could make your own, but it's easier to abandon the concept entirely.
Hope this doesn't scramble it more.
For a successful technology, reality must take precedence over public
relations, for Nature cannot be fooled.
-- Richard P. Feynman
[/quote]
113 Brentwood Drive
(508) 764-2072
sportav8r(at)gmail.com Guest
Posted: Tue Jun 10, 2008 6:34 pm Post subject: Bridge Diodes use |
So you're saying that any given diode (of the four) in a conventional, inexpensive potted FWB rectifier has a Vf typ of 1.2V? That's news - very bad news. I always thought 0.6V was closer to average, per Si diode, and about half that for Ge diodes. Learned something today.
-Bill B
On Tue, Jun 10, 2008 at 9:57 PM, Eric M. Jones <emjones(at)charter.net (emjones(at)charter.net)> wrote:
[quote] --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
> Eric,
> What am I missing?
> Tom, AL7AU
Tom et al.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=187299#187299
Posted: Tue Jun 10, 2008 7:03 pm Post subject: Bridge Diodes use |
I believe a normal Si diode has a Vf around 0.6V - 0.7V.
http://en.wikipedia.org/wiki/Diode
A bridge rectifier would normally be wired so that two diodes are in
series. However, many of these bridge rectifiers are built to allow
access to all four nodes of the circuit.
http://www.vishay.com/docs/88612/gbpc12.pdf
This datasheet indeed shows a Vf of 1.1V - used as a rectifier. I'm
pretty sure this is measured across the + and - terminals - two diodes in
series.
I believe it has been proposed that these rectifiers be used to feed the
E-bus by shorting across two of the diodes and paralleling the other two,
and a Vf = 0.6V.
I missed the original reference to the B&C guidance that paralleling
dropped the Vf. Please post that if you have it..
Matt-
<emjones(at)charter.net>
> Eric,
> What am I missing?
> Tom, AL7AU
Tom et al.
sink at all.)
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Posted: Wed Jun 11, 2008 12:29 am Post subject: Bridge Diodes use |
Eric,
Still don't follow you.
I said:
<< If one diode is running 20 amps with a forward voltage of 0.6
then it generates 0.6 x 20 = 12 watts of heat. If two diodes in
parallel are carrying the same 20 amps then the current is split
between the two diodes .. each diode is generating about half of
12 watts with a total generation of still only 12 watts not 24. >>
You said:
<< If either one or two or a hundred conventional diodes is
sharing the load, they still dissipate Vf X A. >>
Agreed. But each diode is carrying a smaller fraction of the
same total amps so the total example heat generated remains 12
watts. Put algebraically:
Let Vf x A = 12 Watts
Let 3 diodes in parallel carry the same total current so
Vf1 = Vf2 = Vf3 = Vf
a1 + a2 + a3 = A
Then
(Vf1 x a1) + (Vf2 x a2) + (Vf3 x a3) = Vf x (a1 + a2 + a3)
= Vf x A = 12 watts
<< Vf is not reduced by putting parts in parallel. >>
Never said it did reduce Vf. (I've always used 0.7V for silicon
and 0.3V for germanium in my minimal design work but a Vf of 0.6V
is close enough also for this discussion.) I did say it reduced
the current carried by each individual part.
<< but the package is what we bolt to the heat sink. >>
But the package in your example is still only generating 12 watts
of heat, not 24. See below.
<< claim that a B & C FWB, when wired so that two diodes are
and 24W worst case if the diodes are Vf=1.2. >>
As Matt says, a Vf of 1.2 is only true when the FWB is wired up
as a full wave rectifier. Then there are indeed two diodes
working in *series* for each half cycle with a Vf of about 1.3V.
Perhaps, you might be referring to the fact the forward voltage
drop across a single diode increases from the turn-on voltage
value with increasing current. This can get above 1 volt at high
currents. But your use of 0.6V clearly made the discussion at
the turn-on voltage point not the Vf at high current. The
situation is the same whether we talk about Vf at turn-on current
or Vf at high current as long as we remain consistent.
And as an aside, putting diodes in parallel brings us lower on
the current scale for each device and closer to its turn-on
voltage. In other words, putting diodes in parallel lowers
(slightly) the total heat generated for the same total current.
In parallel, each diode still has it's original Vf and since they
are in parallel they don't add voltages. Whether there is 1 or
100 diodes in the package, they are still only carrying the
original example 20 amps total with a voltage drop between the
input terminal and the output terminal of one Vf since there is
only one diode drop between the terminals no matter how many
diodes are wired in parallel in between.
<< FWB ... You could make your own, but it's easier to abandon
the concept entirely. >>
Not claiming to be a FWB fan for this application. Just don't
see how running 20 amps total across one diode drop doubles the
heat generated when another diode is added to share the same
current. Under this logic, 8 diodes in parallel would generate
96 watts, 16 would generate 192 watts, etc. which is obviously
not what you mean to imply.
Basically, do not see how wiring diodes in parallel causes their
forward voltage drops to add together as you seem to be saying.
Tom, AL7AU
bob(at)bob-white.com Guest
Posted: Wed Jun 11, 2008 6:07 am Post subject: Bridge Diodes use |
If you look up single silicon diodes in the 10 A to 20 A current rating
on Mouser or Digikey, you will find the Vf is 1.1 Volts or higher for
most of them. For example, a 1N3210 (a 15 A unit) is 1.5 V at 15 amps.
Look up a 1N4007 rated at 1 amp. Vf is 1.1V. Eric is right on the
money on this. He is just saying you can't use 0.6 Volts for Vf because
you have two 1.2 volt devices in parallel.
Bob W.
On Wed, 11 Jun 2008 02:25:10 -0600
The Kuffels <kuffel(at)cyberport.net> wrote:
Eric,
a1 + a2 + a3 = A
Then
= Vf x A = 12 watts
Tom, AL7AU
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/cables/
Eric M. Jones
Posted: Wed Jun 11, 2008 7:09 am Post subject: Re: Bridge Diodes use |
| Quote: | If you look up single silicon diodes in the 10 A to 20 A current rating
Bob W. |
Yeah...What HE said...! Thanks, Bob White.
I can't in any reasonable time answer some previous posts, but there are a couple issues that seem to confuse some people:
The FWB when used as Bob N. and B & C recommends uses two diodes in parallel. The watts dissipated by the part at 20A is WORST CASE 1.2 x 20=24Watts.
The Vf of a diode is a strongly influenced by current. A diode can be 0.7 Vf at zero Amps, and 1.0 Vf at 10A and 1.2 Vf at 12.5. For this you have to read the data sheet. What?! Radio Shack doesn't supply one?! Then just guess and hope you're right. Double up on the life insurance, too.
--Jean Paul Getty
113 Brentwood Drive
(508) 764-2072
