Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Wed May 28, 2008 8:30 am Post subject: Aero-net Reuse... |
Hello Listers,
What is the common opinion on the reuse of those aero-nuts with the
little nylon insert? Seems like once you use one and take it off the
strength of the nylon isn't as good any longer. Is there a
"recommended" number of uses for them?
Matt
_________________ Matt Dralle
Bruce(at)glasair.org Guest
Posted: Wed May 28, 2008 8:52 am Post subject: Aero-net Reuse... |
Use once and throw away.
Bruce
www.Glasair.org
sbuc(at)hiwaay.net Guest
Posted: Wed May 28, 2008 9:43 am Post subject: Aero-net Reuse... |
Matt Dralle wrote:
Hello Listers,
Matt
Matt, the rule-of-thumb I've always heard is as long as the nut still
has enough resistance that you can't thread it on the bolt by hand it is
still serviceable.
Sam Buchanan
seiders(at)bellsouth.net Guest
Posted: Wed May 28, 2008 3:20 pm Post subject: Aero-net Reuse... |
Ditto, Sam.
Dick
At 01:39 PM 5/28/2008, you wrote:
Matt Dralle wrote:
>Hello Listers,
>the strength of the nylon isn't as good any longer. Is there a
>Thanks,
>Matt
still has enough resistance that you can't thread it on the bolt by
hand it is still serviceable.
Sam Buchanan
Release Date: 5/28/2008 7:20 AM
baremetl(at)gvtc.com Guest
Posted: Wed May 28, 2008 3:50 pm Post subject: Aero-net Reuse... |
People with wood props commonly use the elastic stop nuts. I believe that
most (like me) don't change them every time the bolts are retorqued. It
would sure be a lot of trouble and expense.
Ivan Haecker -4 (with wood prop!) 1458 hrs. S. Cen. TX
AV8ORJWC
Posted: Wed May 28, 2008 4:30 pm Post subject: Aero-net Reuse... |
Doing it and making it right are two entirely different questions.
Paragraph 7-64 f. addresses nylon nuts. Aviation safety can be
expensive. They progressively wear and fail to provide the purpose of a
nut, which is retention. I see it all the time. They most often do not
pass inspection criteria.
Common opinion is what Matt asked for so I will say many things in
Experimental are "penny wise and pound foolish". It is amazing the risk
one will take to save a few pennies. From a Quality Control perspective
it is "Use a new one every time" or check the torque...that is the
trouble. When penny pinching, they will often hold torque 1-3 times
then are trash. I often find nuts being used on experimentals that are
shot and reused by operators that don't have the baseline knowledge
found in the AC43.13.
John Cox
Nylon_Locking_Nuts.pdf |
28.67 KB |
252 Time(s) |
Posted: Wed May 28, 2008 9:09 pm Post subject: Aero-net Reuse... |
John,
Would you care to provide the inspection criteria you allude to when you say
that you commonly find nuts on experimentals that are shot and should not be
reused? I find that 99% of the nuts used on my rv-4 are not covered in Table
7.2 of AC43.13-1B.
Sincerely,
H. Ivan Haecker -4 1458 hrs. S. Cen TX
wskimike(at)mchsi.com Guest
Posted: Thu May 29, 2008 4:55 am Post subject: Aero-net Reuse... |
The Navy hardware manual doesn't allow reuse of these nuts on any critical
system like flight controls. Otherwise check the run-on torque for that
specific nut. I think the Navy goes overboard on this issue because if the
nut was installed properly and not overtorqued, the run on torque usually is
good for two or three times. I personally would replace it on critical
systems after one re-use.
Mike
Posted: Thu May 29, 2008 7:35 am Post subject: Aero-net Reuse... |
At 05:24 PM 5/28/2008 Wednesday, you wrote:
| Quote: | Doing it and making it right are two entirely different questions.
Thank for all the great feedback, everyone!
Matt
