mrspudandcompany(at)veriz Guest
Posted: Mon May 26, 2008 4:37 am Post subject: Faraday Cage |
I recently heard that all aircraft to be flown IFR must have a Faraday Cage in the structure. In other words it must be surrounded with a conductive material in the skin. This is to conduct static electricity.
Does anyone know anything about this?? Or is it another myth? If there are any regulations, can you please point me to them.
Thanks for your input.
Roger
bobf(at)feldtman.com Guest
Posted: Mon May 26, 2008 5:03 am Post subject: Faraday Cage |
myth
bobf
W5RF
On 5/26/08, ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote: | Quote: |
Roger --> ht/forums.matronics.com" target="_blank" onclick="return top.js.OpenExtLiution" target="_blank" onclick="return top.js.OpenExtLink(window,event,== [/b] |
henador_titzoff(at)yahoo. Guest
Posted: Mon May 26, 2008 7:31 am Post subject: Faraday Cage |
Roger,
I am willing to bet that you did NOT hear that from an FAA guy. I have never read that in the FARs. Just because I've never read it, though, doesn't mean it doesn't exist; however, I 've never heard it before, and there are many aircraft manufacturers out there like Cirrus, Diamond, etc. who have never it either. My experimental airplane is a composite fiberglass/foam airplane, and it's never heard of it. I will be very surprised if anyone on this email list will be able to quote a FAR that says so.
Sounds like a good myth in the making to me.
Henador Titzof
----- Original Message ----
From: ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net>
Sent: Monday, May 26, 2008 8:33:19 AM
Subject: Faraday Cage
Roger
Roger,
Henador Titzof
Roger
Posted: Mon May 26, 2008 8:04 am Post subject: Faraday Cage |
Henador,
I am not surprised!! I had never heard of this until a couple of days ago, and I have been around for quite some time
Roger
Roger,
Henador Titzof
Roger
[quote] [b]
Bruce(at)glasair.org Guest
Posted: Mon May 26, 2008 8:38 am Post subject: Faraday Cage |
Yes and no. In the certified world there are more hurdles needed to be jumped than in our experimental neighborhood. I believe that in order for a certified airplane to be IFR legal, it must be able to take a lightning strike with minimal damage. The e-glass manufacturers do this by imbedding a copper/aluminum mesh in the skin of the aircraft. While this might be a 'Faraday Cage', it's purpose is to provide an electrical path for a lightning strike.
This is only an issue with glass airframes.
Bruce
www.Glasair.org
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
AV8ORJWC
Posted: Mon May 26, 2008 8:40 am Post subject: Faraday Cage |
Time to add St Elmo's Fire to the discussion and the principals of an Air Capacitor.
All aircraft should address an effective path to discharge Static buildup. It is when they arc through a control surface hinge or bearing that it will get your attention. That is long after it exceeds the aeroelectric discussion pool. I have some great pictures of composite surfaces that were fried for lack of a dissipator wick and an effective circuit path.
I think it’s a myth like flying with aluminum foil on your head.
John Cox
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS
Sent: Monday, May 26, 2008 5:33 AM
Roger [quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?AeroElectric-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon May 26, 2008 12:45 pm Post subject: Faraday Cage |
In a message dated 05/26/2008 11:06:18 AM Central Daylight Time, mrspudandcompany(at)verizon.net writes:
| Quote: | | I recently heard that all aircraft to be flown IFR must have a Faraday Cage in the structure. |
Seems I recall the Beech Starship had copper mesh in its skin for this reason, which was another co$tly headache towards eventual certification.
Mark
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
_________________ From The PossumWorks... |
rtdin
Joined: 16 Mar 2008 Posts: 46 Location: Florida panhandle
Posted: Mon May 26, 2008 1:00 pm Post subject: Faraday Cage |
It sure looks like they intended that when they wrote FAR Part 23. Go to the FAA home page and click on FAR 23.867 (c) (2).
Bob Dingley
(http://food.aol.com/tyler-florence?video=4&?NCID=aolfod00030000000002) [quote][b]
walter.fellows(at)gmail.c Guest
Posted: Mon May 26, 2008 1:04 pm Post subject: Faraday Cage |
This seems to be a requirement for certified aircraft, for example the
DA 20 is not certified for IFR flight and does not have the cage but
the DA 40 is and does have the cage. The Columbia had to add the cage
in adapting the ES to the certified Columbia. The farady cage for
composite aircraft is created with a copper or aluminum mesh in the
outer layer of the shells, electrically bonding the parts of the
exterior together (such as aileron to wing skin), adding a ground
plane and electrically isolating the control tubes and cables from the
cockpit. You can read more about it in Martin Hollmann's book Advanced
Aircraft Design.
On Mon, May 26, 2008 at 5:33 AM, ROGER & JEAN CURTIS
<mrspudandcompany(at)verizon.net> wrote:
Roger
rampil
Posted: Mon May 26, 2008 1:43 pm Post subject: Re: Faraday Cage |
Metal mesh in the wing skin does not constitute a faraday cage.
Different purpose and different design
Posted: Mon May 26, 2008 1:47 pm Post subject: Faraday Cage |
Part 23 deals with certified aircraft. Experimental aircraft, such as the wooden one, which I am building, are not required to meet these specs. That being said, it is not a bad idea to try to build an aircraft that is as safe as possible.
Roger
rjquillin
Posted: Mon May 26, 2008 2:43 pm Post subject: Faraday Cage |
At 13:56 5/26/2008, you wrote:
| Quote: | It sure looks like they intended that when they wrote FAR Part 23. Go to the FAA home page and click on FAR 23.867 (c) (2).
Bob Dingley |
Is "that" a Faraday Cage you refer to?
I fly a certified AC that is also certified for IFR. TC is A18CE.
It's tube and fabric.
Sure no cage around me.
[url=http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/0/712e485b8e0b06c185256687006f0fb7%21OpenDocument&ExpandSection=-1&Highlight 3.867#_Section1] [/url]Sec. 23.867
Part 23 AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND COMMUTER CATEGORY AIRPLANES
Subpart D--Design and Construction
Electrical Bonding and Lightning Protection
Sec. 23.867
[Electrical bonding and protection against lightning and static electricity.]
(a) The airplane must be protected against catastrophic effects from lightning.
(b) For metallic components, compliance with paragraph (a) of this section may be shown by--
(1) Bonding the components properly to the airframe; or
(2) Designing the components so that a strike will not endanger the airplane.
(c) For non-metallic components, compliance with paragraph (a) of this section may be shown by--
(1) Designing the components to minimize the effect of a strike; or
(2) Incorporating acceptable means of diverting the resulting electrical current so as not to endanger the airplane.
Sure don't see any implied cage here, just bonding of metallic components if there are any, unless you care to argue (c)(2) can be satisfied with a cage. Acceptable? Humm... That will vary by ACO.
Ron Q. [quote][b]
rtdin
Posted: Mon May 26, 2008 5:46 pm Post subject: Faraday Cage |
Re: "Faraday cages" on Bellanca aircraft. It does in fact have a tube structure around the entire fuselage and all components are bonded to each other. Same as Pipers and Stinsons. It also was grandfathered by being first certified under CAR 3 pre WW2. Like wise the DC3 does not comply with FAR 25 either. Grandfathered and still legal. Ya'll be careful around those t-storms in wooden airplanes and avoid them by 20 miles.
I used to fly a lot of hard IFR in Sikorsky 76's and took a few hits. Its forward fuselage (with fuel tanks) is a composite structure. Certified under FAR 29. The stroke travels back through the semi monocoque metal aft fuselage, through the composite hor stabilizer and out through the static wicks. All composite structures have that mesh stuff imbedded. All structures are bonded to each other. If not, the radome or the f.g. tail fairing would be blown to little pieces.
Old Bob
