Allegro 2000 CG
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
bear_creek_lsa(at)bellsou
PostPosted: Sat May 24, 2008 6:02 am    Post subject: Allegro 2000 CG Reply with quote
Wondering what you folks are getting for the 2005 Allegro 2000 Aircraft
CG. This is the Xt measurement in the flight manual.The factory built
aircraft which I measured/weighed differed from the original aircraft
paperwork. Weight(not surprisingly) as well as measurements both differed.
Terry
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
aerosiam
PostPosted: Mon May 26, 2008 8:48 am    Post subject: Re: Allegro 2000 CG Reply with quote
Attached is Thom Riddles weight and balance excel
My 2005 Allegro 100hp came with the CG just slightly forward of the forward limit so I fitted a 2.2lb weight in the tail. As you can see from the excel, 2 pilots full fuel and baggage gives 29%
Forward limit is an 85lb pilot. Even putting 44lb baggage in the equation (max 22lb), it gets nowhere near the rear CG limit. Empty is 10 inches, 1 inch forward of the forward limit
Paul
W&B tail weight.xls
W&B Allegro 2000
 Filename:  W&B tail weight.xls
 Filesize:  24 KB
 Downloaded:  764 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
