peteohms
Posted: Mon May 26, 2008 6:41 am Post subject: KT-76a transponder problem |
While flying through class c airspace, a controller reported that my transponder was squaking the wrong code. Is there a simple solution to fixing this?
Pete
Hell Paso, TX
jdubner(at)yahoo.com Guest
Posted: Mon May 26, 2008 8:48 am Post subject: KY 97a transponder problem |
Pete,
I didn't know there is a KY-97A. But assuming your transponder has the
familiar four switches (and not a keypad or pushbuttons): about the only
simple thing you can do without opening the unit is to cycle the code
select switches through their entire ranges a few times.
Switch contacts can oxidize (and fail to make contact) if they're not
actuated occasionally and many of us leave our transponders with "1200"
set for long periods of time.
Best,
Joe
Lewiston, ID
On 05/26/2008 07:41 peteohms wrote:
Pete
Hell Paso, TX
peteohms
Posted: Mon May 26, 2008 9:09 am Post subject: Re: KT-76a transponder problem |
That makes sense. I'll cycle thge switches. This plane sat for a couple years before I bought it
Pete
Kitfox III
