bear_creek_lsa(at)bellsou Guest
Posted: Sat May 24, 2008 6:02 am Post subject: Allegro 2000 CG |
Wondering what you folks are getting for the 2005 Allegro 2000 Aircraft
CG. This is the Xt measurement in the flight manual.The factory built
aircraft which I measured/weighed differed from the original aircraft
paperwork. Weight(not surprisingly) as well as measurements both differed.
Terry
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
aerosiam
Posted: Mon May 26, 2008 8:48 am Post subject: Re: Allegro 2000 CG |
Attached is Thom Riddles weight and balance excel
My 2005 Allegro 100hp came with the CG just slightly forward of the forward limit so I fitted a 2.2lb weight in the tail. As you can see from the excel, 2 pilots full fuel and baggage gives 29%
Forward limit is an 85lb pilot. Even putting 44lb baggage in the equation (max 22lb), it gets nowhere near the rear CG limit. Empty is 10 inches, 1 inch forward of the forward limit
Paul
W&B tail weight.xls |
24 KB |
797 Time(s) |
