Rhonda(at)bpaengines.com Guest
Posted: Fri May 23, 2008 11:52 am Post subject: How to Tell if You have ECI/Superior Cylinders |
I’ve had a few inquiries about whether or not customers’ engines may be affected by the proposed Superior/ECI service bulletins. Some of you may not know which types of cylinders were used on your engine. If your engine builder provided you with a detailed parts list, you should be able to distinguish which manufacturer made your cylinders by reviewing the nomenclature. ECI Lycoming replacement cylinders have an AEL in front of them, and Superior Lycoming replacement cylinders have an SL. If you have purchased a kit engine from BPE, only Lycoming OEM cylinders were used.
If your engine builder did not provide you a detailed parts list, you can easily identify which cylinders you have by looking at the rocker box boss above the exhaust port for the AEL, SL or Millenium insignia. Hope this information is helpful to at least some of you!
Everyone have a safe and enjoyable holiday weekend!
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
