peteohms
Posted: Sun May 25, 2008 1:06 pm Post subject: King KY 97a problem |
I have a King KY 97a in my Kitfox. We had a heavy sandstorm where it is parked of 50 mph winds. When I went flying a day or two after the windstorm, the radio on receive sounded unsquelched. I can't find a squelch on the radio. I believe it is automatic. I think somehow the electrical buildup on the antenna from the sandstorm did something to the radio. Anyone out there know any solutions?
Pete
El Paso, TX
jetboy
Posted: Sun May 25, 2008 2:55 pm Post subject: Re: King KY 97a problem |
The squelch is opened by pulling out the volume knob. I suspect you've left it clicked out.
If not, you can check the internal setting which is a small screwdriver adjustment via a hole on the top cover "SQ" there is another adjustment for signal level squelch too. These holes are normally covered by s sticky label.
Ralph
_________________ Ralph - CH701 / 2200a |
peteohms
Posted: Sun May 25, 2008 3:06 pm Post subject: Re: King KY 97a problem |
| jetboy wrote: | The squelch is opened by pulling out the volume knob. I suspect you've left it clicked out.
Ralph |
Thanks Ralph, The volume knob is probably it. I'll let you know.
