Show us your panel!!
jlfernan
PostPosted: Thu May 22, 2008 5:05 am    Post subject: Show us your panel!! Reply with quote
I originally started the "Show us your finished Kitfox" and received a great response. Thanks guys! Now I'm looking for panel shots. One thing I'm looking for is instrumentation. I'll be using a Rotax 912 and want to see how people are monitoring their engines. I'm not real wild about the EIS engine monitors, they don't seem very intuitive to me and want to see what others have done..
Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/
kcozik(at)cablespeed.com
PostPosted: Thu May 22, 2008 5:40 am    Post subject: Show us your panel!! Reply with quote
Here is my Kitfox and my new Sport Cruiser. The Kitfox has Dual Dynons, Garmin 327
transponder, Icom radio and 396 gps. The SC has dual Dynons, Garmin 330 modes s
transponder, Trutrak auto pilot and a Garmin 430.
Kevin C
Kitfox 6-7
914 Turbo
Czech floats
Lansing Michigan
On Thu May 22 9:05 , 'jlfernan' <jlfernan(at)bellsouth.net> sent:
Jorge Fernandez
Supersport
Waiting on delivery
http://forums.matronics.com/viewtopic.php\?p=184339#184339
 Filesize:  233.1 KB
 Viewed:  714 Time(s)
 Filesize:  222.92 KB
 Viewed:  731 Time(s)
Don Stevenson
PostPosted: Thu May 22, 2008 6:05 am    Post subject: Show us your panel!! Reply with quote
Hi All, Here are a couple of shots of my panel, I have this project up for sale right now, needs about 200 hrs. work to finish, if anyone is interested please contact me off list, Thanks, Don
Don Stevenson
Caledon Ontario Canada
905-838-5283
shericom(at)rogers.com
jlfernan <jlfernan(at)bellsouth.net> wrote:[quote] --> Kitfox-List message posted by: "jlfernan"
Jorge
 Filesize:  81.36 KB
 Viewed:  713 Time(s)
 Filesize:  76.3 KB
 Viewed:  736 Time(s)
Guy Buchanan
PostPosted: Thu May 22, 2008 9:43 am    Post subject: Show us your panel!! Reply with quote
Kevin,
Nice panel! What's the thing that looks like a pump base
down by the left stick?
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Thu May 22, 2008 9:49 am    Post subject: Show us your panel!! Reply with quote
Thanks Guy. That's the parker hand pump for the float amphib gear.
Kevin
Series 6-7
914 Turbo
Czech floats
Lansing MI
On Thu May 22 11:01 , Guy Buchanan <bnn(at)nethere.com> sent:
Kevin,
Guy Buchanan
San Diego, CA
FlyboyTR
PostPosted: Thu May 22, 2008 11:14 am    Post subject: Re: Show us your panel!! Reply with quote
Attached are pictures of our Vixen's panel. Please note the comments on the attachment.
Travis Very Happy
The Magellan EX-10X has been replaced and my Fujitsu, P1610 XP Tablet (powered by Anywhere Map) now sits in its place. The turn and bank indicator (bottom left) has been replaced with the TruTrak autopilot.
 Filesize:  224.35 KB
 Viewed:  708 Time(s)
 Filesize:  214.02 KB
 Viewed:  636 Time(s)
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
tstaley(at)centurytel.net
PostPosted: Thu May 22, 2008 1:45 pm    Post subject: Show us your panel!! Reply with quote
Looks like a Garmin 195 attached to your panel. How did you do this?
Nice looking job.
LeRoy
kirkhull(at)kc.rr.com
PostPosted: Thu May 22, 2008 2:48 pm    Post subject: Show us your panel!! Reply with quote
Close up of the flight inst
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dacha
Sent: Thursday, May 22, 2008 4:39 PM
Subject: Re: Show us your panel!!
Nice looking job.
LeRoy
 Filesize:  52.81 KB
 Viewed:  696 Time(s)
PostPosted: Thu May 22, 2008 2:50 pm    Post subject: Show us your panel!! Reply with quote
Classic 4 panel still under construction with no radios yet
Nice looking job.
LeRoy
 Filesize:  126.15 KB
 Viewed:  643 Time(s)
Guy Buchanan
PostPosted: Thu May 22, 2008 8:16 pm    Post subject: Show us your panel!! Reply with quote
Here's mine! Basic VFR. The best thing about it is the EIS! How's that for a difference of opinion! The only other "unique" thing is the Becker transponder. I paid a little extra for a minimum weight unit; as you can see, I have a major in minimum weight, with a minor in aesthetics. (The original builder had a T&B and VSI which I didn't install because I didn't think I'd ever use them and I saved a little weight.) By the way, the panel's carbon with a wood veneer clear coated with semi-gloss Sterling.
[img]cid:7.1.0.9.0.20080522210309.017d1780(at)nethere.com.0[/img]
Guy Buchanan
San Diego, CA
 Filesize:  97.36 KB
 Viewed:  743 Time(s)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
Travis,
It's beautiful! What engine monitor do you have? And what's
the round LCD instrument under the transponder?
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Fox5flyer
PostPosted: Fri May 23, 2008 2:35 am    Post subject: Show us your panel!! Reply with quote
Very nice interior, Guy. Quite a departure from the conventional Kitfox.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 370+ TT
- Joseph Joubert
FlyboyTR
PostPosted: Fri May 23, 2008 2:48 am    Post subject: Re: Show us your panel!! Reply with quote
Guy,
Thanks. …glad you like it! The engine monitor is from Vision Microsystems: http://www.visionmicrosystems.com/ Model # VM1000. I’ve been very pleased with it and it monitors everything (including all four cylinders CHT/EGT) plus fuel management. With such precise monitoring, I can run lean of peak when at altitude (the Continental IO-240 Fuel Injected engine does very well with Lean of Peak).
The round instrument under the transponder is a Rocky Mountain Encoder: http://www.rkymtn.com/ It handles the Mode C altitude encoding. The following info is also available visually/digitally; VSI, ASI, Altitude, Barometer (adjustable), Density Altitude, Pressure Altitude, True Airspeed, Outside Temp, Speed Alarms (Flaps, Gear, Stall, etc). It provides an enormous amount of info in a very small space.
Travis Very Happy
Travis Rayner
Mobile, AL
ADI-II Autopilot
occom
PostPosted: Fri May 23, 2008 2:48 am    Post subject: Show us your panel!! Reply with quote
Here's the pan[img]cid:001f01c8bcc2$314a9d70$6600a8c0(at)ogri[/img]el from C-FOYT.
 Filesize:  75.53 KB
 Viewed:  655 Time(s)
henrysfork1(at)msn.com
PostPosted: Fri May 23, 2008 4:16 am    Post subject: Show us your panel!! Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> [img]cid:008701c8bcce$618a0820(at)yourulcuxrpjzf[/img][img]cid:008801c8bcce$618c5210(at)yourulcuxrpjzf[/img] Photo E-mail [url=http://photos.msn.com/Viewing/Album.aspx?PST=8nK2AN1B!1JmZao!iR2Cw5qDXpd9q4EaA9jBY!9TqYJgBt1x2BFYU*7*kYjB7TgtoeAEpIrdNZpNNKDrGhJMlw%24%24]Play slideshow[/url] | [url=http://photos.msn.com/viewing/Photos.aspx?pi_Type=SlideshowTask&Task=Download&stppData=&pi_ImagesOnly=1&Folder=nBuRgwTGIGgOPXBotYNhUqyQU5geGhi!pWG7YI!F0Xs%24&User=heRNVFXLFsP4sUsjhgDQrXZxB138qlNG&pi_NoLogin=1]Download images [/url]
[url=http://photos.msn.com/Viewing/Album.aspx?PST=8nK2AN1B!1JmZao!iR2Cw5qDXpd9q4EaA9jBY!9TqYJgBt1x2BFYU*7*kYjB7TgtoeAEpIrdNZpNNKDrGhJMlw%24%24][img]cid:008901c8bcce$618c5210(at)yourulcuxrpjzf[/img][/url]
KF II
Dee Young
N345DY
This MSN Photo E-mail slideshow will be available for 30 days.
To share high quality pictures with your friends and family using MSN Photo E-mail, join MSN.
 Filesize:  842 Bytes
 Viewed:  23961 Time(s)
 Filesize:  1.11 KB
 Viewed:  23964 Time(s)
 Filesize:  5.91 KB
 Viewed:  23968 Time(s)
n981ms(at)yahoo.com
PostPosted: Fri May 23, 2008 4:24 am    Post subject: Show us your panel!! Reply with quote
Here is mine. I spent many hours with epanel builder. This left only minutes to hours fiddling with placement on the actual metal.
Maxwell
FlyboyTR <flyboytr(at)bellsouth.net> wrote:
[quote]--> Kitfox-List message posted by: "FlyboyTR"
Guy,
 Filesize:  486.38 KB
 Viewed:  651 Time(s)
 Filesize:  119.54 KB
 Viewed:  707 Time(s)
pulsair(at)mindspring.com
PostPosted: Fri May 23, 2008 4:43 pm    Post subject: Show us your panel!! Reply with quote
Dave,
Where did you get your kickpanels? Jeff Classic IV Ktzr
 Filesize:  75.53 KB
 Viewed:  572 Time(s)
occom
PostPosted: Sat May 24, 2008 9:16 am    Post subject: Show us your panel!! Reply with quote
If you meant the carpet (normal plastic indoor outdoor) the panels are .020 cut to follow the tubes with about 3/4" extra. They are riveted through the firewall to stainless 1/2" "L" stiffeners from below the footwell bend in the firewall and "stitched" to the frame tubes with tie wraps the carpet is glued to the aluminum and the extra folded over to give a finished edge.
Not my creation it was done by a gentleman in New Brunswick, Glen McGuigan.
----- Original Message -----
[quote] From: jeff puls (pulsair(at)mindspring.com)
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Friday, May 23, 2008 9:32 PM
Dave,
 Filesize:  75.53 KB
 Viewed:  594 Time(s)
