jrstone(at)insightbb.com Guest
Posted: Wed May 21, 2008 6:33 pm Post subject: Cockpit cooling |
Hey Guys,
My cockpit air comes from a two inch scat going from a hole in the upper rear baffle on the left/center side, same side as my oil cooler, and then goes to a firewall mixer valve which allows heat muff air to be mixed with it. My complaint is, this air is too warm on a day that is 75 degrees or warmer. I have a Naca vent under the right wing that brings in cool outside air but it goes only to the rear seater. I would like to change the front seat set up and leave the rear seat the way it is. My question is, has anyone put a 2" hole in the forward horizontal baffle, in front of number 2 cyl and pulled the air down and aft to the mixer valve on the firewall? Or, has anyone just tied a scat hose along the top of the engine from the aft baffle to the cowl opening in front of number 2 cyl. in an effort to catch the air before it warms up.
My setup is similar to John Harmon's, and he told me years ago that it works fine for him, so I assumed if it works in the Bakersfield desert, it will work in Louisville. Perhaps my setup is not as similar to John's as I think.
TIA,
Jim Stone
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
bluebird266(at)dslextreme Guest
Posted: Wed May 21, 2008 8:29 pm Post subject: Cockpit cooling |
At 07:31 PM 5/21/2008, you wrote:
Bakersfield is a dry HEAT!! Ha ha!
You have that muggy heat!
Check with 2nelson(at)prodigy.net Greg nelson. He has a nice set up that I was going to do but never did
Harry
[quote]Hey Guys,
TIA,
Jim Stone
fred.laforge(at)verizon.n Guest
Posted: Wed May 21, 2008 8:39 pm Post subject: Cockpit cooling |
Jim, I tried air off the back of the engine plenum on my RV-4,,,, Too warm. I would recomend a NACA vent. and thick insulation on firewall and under your feet.
baremetl(at)gvtc.com Guest
Posted: Wed May 21, 2008 8:59 pm Post subject: Cockpit cooling |
Jim,
I had a similar set up on my rv-4. The air was taken off the rear baffle and run into the cockpit. It was ok until it got hot in the summertime. It was really bad when I slowed down in the pattern.I changed the set up and extended the tube forward across the top of the crankcase to the left opening in the front of the cowl. That was much better. I now measure only a 3-4 degree increase in temperature compared to the rear vent outlet which comes from under the wing. I terminated the scat tube with an aluminum end to dress it up visually up front. With a 540 engine instead of a 320 the heat picked up may be more especially due to the longer length. I plan to do the same on my rocket if I ever can finish it.... I can get pictures if you need them.
Ivan Haecker rv-4 1455hrs. S. Cen. TX
fairlea(at)amtelecom.net Guest
Posted: Thu May 22, 2008 3:41 am Post subject: Cockpit cooling |
Jim
I pick up my pilot air from a hole in the leading edge. There is room to get an opening in the faring between the wing and the fuselage. The air goes through a hole in the fuse and the hose then goes up the back of the #2 bulkhead. There is lots of cool fresh air from this location.
Tom Martin
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Jim Stone
Sent: May 21, 2008 10:31 PM
To: rocket-list(at)matronics.com
Subject: Cockpit cooling
Hey Guys,
TIA,
Jim Stone
| Quote: | | http://www.matronics.com/Navigator?Rocket-List |
Checked by AVG.
Checked by AVG.
Posted: Thu May 22, 2008 5:36 am Post subject: Cockpit cooling |
Hey Ivan,
I think your plan may be the easiest to try first. If pics are not to difficult, please send me a few. In particular, I would like to see the scoop or forward end of the scat tube and how it sits in the intake.
Thanks for your help,
Jim
smokyray(at)yahoo.com Guest
Posted: Thu May 22, 2008 5:58 am Post subject: Cockpit cooling |
My very early (96') HR2 was set up with rear engine baffle cockpit fresh air when I bought it. For the SE USA, it was completely inadequate. I had an AE friend look over the fuselage sides and located the best high pressure area for Vans style NACA ducts and installed one on either side of the Fuselage with Hysol structural epoxy(no rivets). They are ducted inside via 2" SCAT to large aluminum eyeball vents from Acft Spruce. I also vented the rear baggage compartment into the aft fuselage by cutting 4-3" holes in the rear baggage access door and putting screen door screen behind the holes. "You can't get air in without getting it out".
Now at cruise speeds the airflow through the vents will nearly "peel paint". I like it!
Rob Ray
HR2
--- On Thu, 5/22/08, Tom Martin <fairlea(at)amtelecom.net> wrote:
Subject: RE: Cockpit cooling
Date: Thursday, May 22, 2008, 6:38 AM
Jim
Tom Martin
Subject: Cockpit
cooling
Hey Guys,
Louisville . Perhaps my setup is not as
TIA,
Jim Stone
Checked by AVG.
Checked by AVG.
Posted: Thu May 22, 2008 3:33 pm Post subject: Cockpit Cooling |
Jim,
Here is a picture that I have readily available. I'm not sure how to send to the list, so if the picture doesn't come through, send me your e-mail address and I can send it directly to you. If you need more detail, I can take more pictures this weekend.
Ivan Haecker
670.92 KB |
424 Time(s) |
Posted: Thu May 22, 2008 4:14 pm Post subject: Cockpit Cooling |
I got the pic, thanks Ivan.
Jim
Posted: Sat May 24, 2008 7:04 pm Post subject: Cockpit cooling |
Tom,
So the air comes in a hole, does the air flow into a duct at the hole or after it comes thru the side of the fuselage? Just trying to picture it. I like this idea more than installing NACAs on my new paint. Do you have a pic or two?
Jim
Vince Frazier
Posted: Mon May 26, 2008 5:56 pm Post subject: cockpit cooling |
SNIP jim, I haven't had Vinces problem on my HR2. My AE buddy stressed location was
critical in getting large volumes of cool air, which I do.
RR SNIP
Rob and others,
I certainly don't dispute that the wingroot vents get plenty of air. They do. So do the NACA vents on the fuselage sides. However, both of those locations are 10+ degrees F hotter than the NACA scoop under the wing. 10 degrees doesn't sound like much, but when it's already 85F and 90% humidity, it is miserable.
Having just returned from vacation and a cross country drive from Los Angeles to Indiana, via Death Valley where it was a comfortable 110F and <10% humidity, I think I can safely assume that it is the humidity that makes Indiana and Kentucky uncomfortable compared to anywhere in the western U.S. or Canada. It gets blazing hot out west, but without the humidity, it's nowhere near as uncomfortable as it gets here.
My whole point here is that the underwing NACA scoops are measurably cooler... so why not enjoy the cooler air instead of the hot fuselage air if you're making a change or building anew. It's a mistake that I won't make again!
Vince
_________________ Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
T.gummo(at)verizon.net Guest
Posted: Mon May 26, 2008 8:40 pm Post subject: cockpit cooling |
Boy am I P_SSed.
Vince, you drove right by my house and you didn't stop to say hello.
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
larry(at)ncproto.com Guest
Posted: Tue May 27, 2008 6:01 pm Post subject: cockpit cooling |
Jim/Vince,
No arguments here, I live in Central FL where humidity is manufactured and exported! I inspected an RV4 for a friend recently that had the under wing NACA ducts (1 each side) for cockpit cooling. The right side went to a rear eyeball vent in the stickwell, the front had a unique snorkel duct that pointed forward from just aft of the main spar.
The airflow inflight was excellent, equal to or better than my setup and even worked on the ground. Also unique was his Grob Sailplane/Extra 300 canopy sliding vent in the front cockpit ala Tony Bingelis' RV3. It also worked very well.
Very Cool
RR
--- On Mon, 5/26/08, Frazier, Vincent A <VFrazier(at)usi.edu> wrote:
Subject: cockpit cooling
Date: Monday, May 26, 2008, 8:51 PM
Jim, I haven't had Vinces problem on my HR2. My AE buddy stressed
location was
RR
Rob and others,
again!
Vince
Posted: Tue May 27, 2008 6:36 pm Post subject: cockpit cooling |
Hey Rob,
Doesn't that snorkel pick up exhaust fumes?
Jim
Posted: Wed May 28, 2008 6:27 am Post subject: cockpit cooling |
Jim,
The RV4's under wing NACA ducts were about mid-fuel tank 6" behind the spar. Both SCAT tubes entered the fuselage under the floorboard aft of the spar. For front cockpit air he simply built a periscope/snorkel out of the floorboard with an eyeball vent on the end of it(slightly in the way for rear seat pax). You could point it forward or aft, he had it forward. The rear duct had an eyeball vent in the rear stickwell.
My HR2's fuselage NACA ducts work very well with no warm air issues although they are AOA critical. At approach airspeeds they are almost ineffective. At cruise however, Hurricane warnings are in effect:) Personally, I think the underwing vents are a great idea and hide any holes under the bottom, free from rain, and detracting from the beauty of the HR2. Mine however were easiest for me on an already flying airplane...
Ronnie said he could install them for you in one day, need a FL vacation?
RR
--- On Tue, 5/27/08, Jim Stone <jrstone(at)insightbb.com> wrote:
[quote] From: Jim Stone <jrstone(at)insightbb.com>
Subject: Re: cockpit cooling
Date: Tuesday, May 27, 2008, 9:33 PM
Hey Rob,
Jim
