toaster73(at)embarqmail.c Guest
Posted: Tue May 20, 2008 5:19 pm Post subject: Fuse and Breaker - one bus |
I have been lurking here for a few years trying to absorb the power of
aeroelectric but I am having trouble jumping from the schematics to the
physical configuration.
I am having trouble with the physical configuration of my RV-10 electrical
system design. I am trying to draw up a Z-13 style system but I think I
want my E-Bus to have a breaker for trim, flaps etc but the rest I want to
use a fuse block. What would be a good way to combine the fuse and breaker
block into one bus? Just run same gage wire to the e-bus primary and
alternate feed to the fuse block and split off from block with same gage
wire to the bar for the breakers?
thanks in advance
Chris Lucas
RV-10 #40072
vaughnray(at)bvunet.net Guest
nuckolls.bob(at)cox.net Guest
Posted: Tue May 20, 2008 7:37 pm Post subject: Fuse and Breaker - one bus |
At 09:16 AM 5/20/2008 -0400, you wrote:
breaker block into one bus? Just run same gage wire to the e-bus primary
and alternate feed to the fuse block and split off from block with same
gage wire to the bar for the breakers?
thanks in advance
The e-bus is for things that you need during the en-route
mode of flight to maximize utilization of a limited resource.
If you're planning Z-13/8, then the e-bus can be easily
configured to handle an endurance load of 8 amps.
The idea is that when the airport is in sight that you
can bring the main bus back on for using the battery to
run anything on the main bus using a battery that's held
completely in reserve for approach to landing.
What's your rationale for breakers on these two systems?
Runaway disconnect? Breakers are exceedingly poor substitutes
for master disconnect systems . . . if indeed runaway is
a high order probability for creating a hazard. It's
probably easier to design a system that can't run away.
In other words, trim is an exceedingly low duty-cycle
load that runs happily from the e-bus . . . Flaps too
for that matter . . . but they aren't needed until approach
to landing and could stay on the main bus. I guess we
need to understand your concnerns.
Posted: Thu May 22, 2008 6:24 pm Post subject: Fuse and Breaker - one bus |
Thanks Bob. I see your point and will continue along those lines you
describe. I have been thinking I may want to see an indication of a failure
on certain items by seeing that breaker button pop out. Is that really
something I need to see or know or do I use another indicator like a light?
-Chris
Posted: Thu May 22, 2008 6:29 pm Post subject: Fuse and Breaker - one bus |
Vaughn,
I had an MGB and am familiar with the Prince of Darkness. Your right I
probably should not be doing wiring - to me this is the coolest part of the
project when its done, but the worst to figure out and build. I am a
mechanical guy through and through.
-Chris
