rveighta(at)earthlink.net Guest
Posted: Wed May 21, 2008 4:44 pm Post subject: Pre Flight Problems |
Listers, I'm hoping to make the first flight of my RV-8 in the next few days, but I have a couple of problems I need to sort out first.
- With the Batt & Avionics Master on, the manifold pressure needle pegs when the radio xmit button is
pressed. Any ideas about what could be causing this?
- With the Batt Master On, before engine start, the fuel pressure gauge is at zero; as soon as I hit the
boost pump it climbs to around 30psi and stays there during engine run (with the boost pump turned off)
What is normal fuel pressure for an engine with carburetor with the engine running? (Can't find this
in my engine manual).
Walt Shipley RV-8a Flying, RV-8 soon to be flying
rnewman(at)tcwtech.com Guest
Posted: Wed May 21, 2008 5:20 pm Post subject: Pre Flight Problems |
Walt, It sound like your MP gauge and or sender are sensitive to the
radiated or conducted fields from your comm transmitter. Perhaps a poor
ground connection on the sender or the gauge. Another possibility is a poor
shield connection on the antenna wire between the radio and the antenna. I
had significant trouble with some BNC connectors where the shield was making
intermittent contact to the outer shell of the connector. This caused all
kinds of problems.
Regarding the fuel pressure, Lycoming fuel pumps on carb type
engines generally run in the 4-6 psi range. 30psi sounds like the fuel
pump is the type intended for fuel injected engines that run in that higher
range.
When you turn on the boost pump only before starting the engine
to you get a reading closer to 5 psi?
-Bob Newman
rv-10 40176
Glastar N99RN
www.tcwtech.com
khorton01(at)rogers.com Guest
Posted: Wed May 21, 2008 5:49 pm Post subject: Pre Flight Problems |
On 21 May 2008, at 20:40, rveighta wrote:
Which MP gauge do you have?
This appears to be a relatively common complaint with Van's MP
gauge. It seems that it picks up radio frequency energy. I haven't
seen a solution, other than not looking at the MP gauge when
transmitting.
| Quote: | - With the Batt Master On, before engine start, the fuel
Where in the fuel system are you measuring fuel pressure?
If you have an O-360, with a Facet (Marvel Schebler) MA-4 or HA-6
series carb, the fuel pressure at the inlet to the carb should be
between 0.5 and 8 psi. This info is from engine Type Certificate
Data Sheet E-286, available on the FAA web site.
Kevin Horton
RV-8 (FInal Assembly)
Ottawa, Canada
http://www.kilohotel.com/rv8
Gary.A.Sobek
Posted: Wed May 21, 2008 5:54 pm Post subject: Pre Flight Problems |
Going from memory, the minimum fuel pressure for a carb is 0.5 psi. (1/2 psi) Depending on the transducer, it may have a difficult time ready as low as 0.5 psi. Not sure what fuel pressure instrument you have. Is it programmable and possible that it has an incorrect calibration factor? It is possible that you have a bad gauge or a bad transducer. You will need to know about the meter movement to trouble shoot it.
Saw a Draganfly with VW engine that had the same problem with all its engine instruments as you do with MAP. The problem there was a BAD ground scheme. Ground loop and high resistance. The builder added a ground just for the transducer and his problem when away. Cannot say that is your problem but poor grounds are the source of a lot of instrument problems.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,096 + Flying Hours So. CA, USA
[quote] From: rnewman(at)tcwtech.com
To: rv-list(at)matronics.com
Subject: Re: Pre Flight Problems
Date: Wed, 21 May 2008 21:17:12 -0400
kinds of problems.
range.
-Bob Newman
rv-10 40176
Glastar N99RN
www.tcwtech.com
