jimh474(at)earthlink.net Guest
Posted: Sun Mar 05, 2006 3:06 pm Post subject: Leading edge failures |
Folks;
All this hysteria of failing leading edges, is blown way out in space.
I know of two, one I am very close to and the other I didn't know the
individual.
Both instances, the Firestars were flown hard and put away wet too many
times.
How many Firestars have been built and flying, thousands.
On the instance that I am close to, the cause was failure of the 5/16
diagonal leading edge braces, failure cause, more than likely failure from
vibration.
Once these diagonals are no longer attached, under the right conditions, the
leading edge of the wing more than likely shifts to outboard end of the
wing, causing the ribs to get out of column and once this starts the leading
edge folds back and creates an instant spoiler. The wing tip bow will not
keep the ribs in column in the stock configuration. It doesn't make any
difference whether it is a 5 rib or 7 rib wing. Once those diagonals go the
leading edge is free to move at some time. Then again it may not.
The best fix is to use 1/2 .058 wall aluminum tubing to replace the 5/16
braces. Do not flatten the attaching ends all the way, leave about an 1/8
inch opening in the ends of the tube. Add the aluminum angle to the outboard
rib along with replacing the bow tip tube braces with the 1/2 material and
place a 062 aluminum web connecting the two bow supports.
All you wizards that don't believe that vibration causes fatigue better take
a hand full of smart pills.
Jim Hauck
planecrazzzy Guest
Posted: Sun Mar 05, 2006 4:58 pm Post subject: Re: Leading edge failures |
Hi Jim,
So let me ask this.....The leading edge that almost "touch" each other in the wing gap area.....Should there be something that connects these two together for a little added support during flight ?
After reading your post....I think "it wouldn't hurt"
Gotta Fly...
Mike in MN
Posted: Sun Mar 05, 2006 5:13 pm Post subject: Leading edge failures |
That still won't solve the problem, as both leading edges would move
together. The only fix is making sure you have diagonal bracing on each
wing.
On 3/5/2006 7:58:53 PM, kolb-list(at)matronics.com wrote:
Hi Jim,
Gotta Fly...
Mike in MN
The more people I know....
The more I like MY DOG
.Do not archive
http://forums.matronics.com/viewtopic.php?p=19780#19780
Eugene Zimmerman
Posted: Sun Mar 05, 2006 6:37 pm Post subject: Leading edge failures |
On Mar 5, 2006, at 6:03 PM, JW Hauck wrote:
better take
Jim Hauck
Jim,
Whose Kolb airframe has more high stress hours on than brother John's?
How close to catastrophic failure is his plane today?
JetPilot
Posted: Sun Mar 05, 2006 7:46 pm Post subject: Re: Leading edge failures |
| jimh474(at)earthlink.net wrote: |
Jim Hauck |
Jim is very right about this. John Hauck recommended these modifications to me and I have all of these along with the rib streingthening on the wing of my MK-III... One just needs to look at the design to see that this made a lot of sense. I also read about some cases of wingtips buzzing at high speeds, its obviously an area that needed streingthening. All this only added a couple pounds of weight and I will not have any problems in these areas in the future.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
Eugene Zimmerman
Posted: Sun Mar 05, 2006 9:13 pm Post subject: Leading edge failures |
On Mar 5, 2006, at 8:12 PM, JW Hauck wrote:
each
wing.
Jim,
Let me run my perspective on the issue of Kolb rib failures.
I do not want to minimize the critical importance of the integrity of
the leading edge diagonal bracing to keep the ribs in column or to
get into an argument about what happened to John's wing, but I do
believe there is another scenario of failure that is much more likely
than the conclusion that the leading edge failure was initiated by
failure of the lateral diagonal braces.
Let me point out that properly installed and finished fabric
covering is itself an extremely strong medium resisting lateral
movement of the leading edge UNLESS for some reason it loses its
tension in one dimension or another but especially in the fore and
aft direction.
I submit that initial failure mode of the Kolb leading edge is much
more likely due to the compromise of the curved upper rib tube under
excessive compression load during a high speed, high wing loading
situation. As speed increases center of lift moves forward so that
much more of the load is carried by the front part of the rib. An
increased portion of the load is transferred to the spar by an
increased compression load carried through a tube that by design
and of necessity is already out of column it suddenly buckles and
breaks allowing the leading edge to move back and up into the already
excessive high speed air flow above the wing.
Such sudden failure would of course also destroys all diagonal
braces pulling the leading edge sideways as they fail.
Just picture what would happen to the ribs if a wing were loaded
with sand bags to 4 G all of them ahead of the spar??
In my opinion,,,,,,,,,,,,,,,,,,,, avoid excessive air speed and there
should be no worry about Kolb rib failure.
Kirk Smith
Posted: Mon Mar 06, 2006 12:21 am Post subject: Re: Leading edge failures |
"Once these diagonals are no longer attached, under the right conditions, the
wing,"
What would cause this shift?
"causing the ribs to get out of column and once this starts the leading
place a 062 aluminum web connecting the two bow supports. "
After removing the 5/16 braces one could test the leading edge for lateral strength. Would be interesting to see how much strength the fabric lends to lateral support of the leading edge.
ul15rhb(at)juno.com Guest
Posted: Mon Mar 06, 2006 5:56 am Post subject: Leading edge failures |
The Original Firestar had a 1.5" .028" leading edge tube with no diagonal bracing to the 5" spar except for a short 5/16" length near the root. The fabric kept the nose ribs from moving laterally. I built mine with 1.5" .035" and 3- 3/8" diagonals in the middle of the wing to the spar.
Ralph
Original Firestar
19 years flying it
each
wing.
Jim,
aft direction.
Try Juno Platinum for Free! Then, only $9.95/month!
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Tue Mar 07, 2006 1:08 am Post subject: Re: Leading edge failures |
Not to beat this topic to death, but.....
Another way to stiffen up the leading edge of the wing and to keep the ribs in column is to cover from the leading edge back to the high point of the airfoil with thin fiberglass sheet or aluminum. Rivet the thin sheet to each rib and false rib at about two inch intervals. It adds a couple of pounds to each wing, but really stiffens up the structure. It also eliminates the sag between ribs and makes for a cleaner airfoil. Do the fabric over the entire wing after the leading edge covering is intalled.
I built my FS2 wing this way, and I can guarantee that the ribs and leading edge are not going have any spanwise movement. I think this would be the most simple and structurally sound modification for a 5 rib wing. It does involve recovering the wing.
111.38 KB |
718 Time(s) |
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Tue Mar 07, 2006 6:52 am Post subject: Re: Leading edge failures |
| Eugene Zimmerman wrote: wrote: | I submit that initial failure mode of the Kolb leading edge is much more likely due to the compromise of the curved upper rib tube under excessive compression load during a high speed, high wing loading situation. As speed increases center of lift moves forward so that much more of the load is carried by the front part of the rib. An increased portion of the load is transferred to the spar by an increased compression load carried through a tube that by design and of necessity is already out of column it suddenly buckles and breaks allowing the leading edge to move back and up into the already excessive high speed air flow above the wing.
Such sudden failure would of course also destroys all diagonal braces pulling the leading edge sideways as they fail. |
Group,
Eugene's explaination makes the most sense to me. I have been trained as a mechanical engineer and I am a Kolb flyer and builder/rebuilder.
I do not mean to alarm anyone by comenting on possible wing failures. But I also would not suggest that the risk is not higher when someone flys over the gross weights set by Kolb. I flew my original Firestar at about 600 pounds when I carried extra gas and camping gear. I accepted the extra risk on those flights. If I had to fly every flight at a gross weight substancially higher than that, I would have sold the plane and bought a Firestar II. That's what I did, but for different reasons. Just my opinion. Everyone has there own tolerance for risk.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
herbgh
Posted: Tue Mar 07, 2006 6:54 am Post subject: Leading edge failures |
Dave
How did you keep the Glass/metal from puckering between ribs back
toward the maine spar? Did you attach it to the spar? I am building a
set of single lift strut wings for my Firefly and have thought about
using a leading edge d cell configuration. I will wrap .016 2024-t3
around my wings since I already have it.. Actually thinking about
metallizing the whole wing! Likely as cheap as fabric and the stitts
process.. Herb
On Tue, 7 Mar 2006 01:08:09 -0800 "Dave Bigelow"
<up_country(at)hotmail.com> writes:
Dave Bigelow
Kamuela, Hawaii
FS2, Rotax 503 DCDI
http://forums.matronics.com/viewtopic.php?p=20054#20054
http://forums.matronics.com//files/fs_with_fiberglass_le_covering_827.jpg
Its what we learn after we know everything that is the most important.
eagle1(at)commspeed.net Guest
Posted: Tue Mar 07, 2006 8:12 am Post subject: Leading edge failures |
I also built my FS II that way. I used thin roof flashing from the hardware
store. Makes a nice clean wing leading edge.
AZ. Bald Eagle.
Eugene Zimmerman
Posted: Tue Mar 07, 2006 9:23 am Post subject: Leading edge failures |
On Mar 7, 2006, at 11:11 AM, George E. Thompson wrote:
| Quote: | I also built my FS II that way. I used thin roof flashing from the
hardware
Until it get a dent or two.
herbgh
Posted: Tue Mar 07, 2006 3:17 pm Post subject: Leading edge failures |
Gene
One way to mask the dents is to overlay the aluminum with felt. The
dent is still there but the felt maintains the normal curve..
Lets see---Aluminum or Fiberglass sheet d cell and felt... By gosh I
think we have likely soothed everyones fears.. Herb
On Tue, 7 Mar 2006 12:22:00 -0500 Eugene Zimmerman
<etzim62(at)earthlink.net> writes:
> hardware
Dave Bigelow
Posted: Wed Mar 08, 2006 12:50 am Post subject: Re: Leading edge failures |
I used fiberglass rather than metal to avoid the dent problem. It takes some work to smooth the fiberglass sheeting over the ribs without wrinkles. The natural stiffness of the fiberglass prevents sagging between the ribs and false ribs. It is not attached to the main spar and does not act as a D-tube. It just stiffens up the leading edge structure and makes for a smooth sag free airfoil.
Kamuela, Hawaii
FS2, HKS 700E |
Kirk Smith
Posted: Wed Mar 08, 2006 7:54 am Post subject: Re: Leading edge failures |
"Another way to stiffen up the leading edge of the wing and to keep the ribs in column is to cover from the leading edge back to the high point of the airfoil with thin fiberglass sheet or aluminum. Rivet the thin sheet to each rib and false rib at about two inch intervals. It adds a couple of pounds to each wing, but really stiffens up the structure. It also eliminates the sag between ribs and makes for a cleaner airfoil. Do the fabric over the entire wing after the leading edge covering is intalled.
I built my FS2 wing this way, and I can guarantee that the ribs and leading edge are not going have any spanwise movement. I think this would be the most simple and structurally sound modification for a 5 rib wing"
Have you noticed any cracks forming in the ribs where the rivets are?
jbhart(at)onlyinternet.ne Guest
Posted: Wed Mar 08, 2006 11:18 am Post subject: Leading edge failures |
At 07:54 AM 3/8/06 -0800, you wrote:
Kirk, & Kolbers,
This thread has really been interesting. To stabilize the leading edge wing
tube, the FireFly uses one 5/16 OD 0.035 inch thick tube brace starting next
to the most inboard rib from the nose tube back to the center line of main
spar at about a 45 degree angle. Two other shorter braces using the same
size tubing attach to the upper and lower nose rib tubes of the inner most
rib to stabilize the nose rib against the pull of the shrunk fabric.
Addition nose rib column stabilization comes from the fabric.
I question the need for an increase in stiffening the wing leading edge.
Basically, where is the sideways load going to come from that will cause the
nose ribs to be forced out of column? During normal or abusive flight (high
g loads), how is the leading edge tube going to forced sideways to move the
ribs out column?
The only way I can see a leading edge tube diagonal bracing failure is if
the outer wing was to strike the ground or the leading edge tube struck some
fixed object. Then one should cut an inspection hole through the fabric
next to the inboard nose rib to view all three braces.
If I wanted to increase nose rib strength, I believe you would get more for
less weight by adding 1/2 by 1/2 aluminum angle to each nose rib to help
carry rib compressive loads.
Some musings on a cold wet day.
Jack B. Hart FF004
Winchester, IN
Kirk Smith
Posted: Wed Mar 08, 2006 1:52 pm Post subject: Leading edge failures |
Jack?Kolbers
| Quote: | This thread has really been interesting. To stabilize the leading edge
wing
I think so also Jack. The physics of how are little planes work is always
interesting.
jdm(at)wideworld.net Guest
If you exert pressure on the leading edge until it fails it won't break the
rib tubing. It has to bend. Since being "in column" is not an exacting
concept, it will fold up by swinging to one side or the other favoring the
easiest route to go since it's not built perfect. There are no external
forces to push it other than the LE collapsing and "swinging out of column
under the path of least resistance under the g force applied to it. Adding
cross braces will keep this from happening and under enough force the
leading edge would just crush upward. The question is at what point will it
fail? Out of column at 6 g's? If supported crush upward at 12g's I don't
know but I called BRS today and they e-mailed me pictures for installation
of the canister to the root tube. I generally fly at 1,000 AGL so I feel
safer now with the cute.
If you want to see how this will happen if you can't visualize it, go to the
hanger of the guy who is building one. Take three of your buddies along.
Assuming his plane is framed out and assembled but not covered, have
everyone line up on the leading edge with the wing achored to the ground by
tying the spar tube to the floor so it can't move. Now all at once push
straight up on the leading edge as hard as you can until the leading edge
fails. You will see that it has to swing one way or the other. It helps to
have a few beers first. Oh, don't forget to leave a note for the owner how
his sacrifice educated you and all the readers here!
Eugene Zimmerman
Posted: Wed Mar 08, 2006 4:56 pm Post subject: Leading edge failures |
On Mar 8, 2006, at 4:50 PM, John Murr wrote:
| Quote: | I generally fly at 1,000 AGL so I feel
Why ,,,,,,,,,,,,,,,,,,, is she a terrorist or somthin?
Who is this cute yer talking about?
