Engine & Propeller diameter
Iberplanes
PostPosted: Tue May 20, 2008 4:16 am    Post subject: Engine & Propeller diameter Reply with quote
Hi there,
I´m planning to build a 701, I´ve seen the R-2100 Turbo, 80 HP engine as a good alternative, and they´ ve recommended a 62´´ diameter propeller. Would it be ok such an engine/prop combination?
Thanks a lot !!
Alberto Martin
www.iberplanes.es
Igualada - Barcelona - Spain
Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
kmccune
PostPosted: Tue May 20, 2008 8:52 am    Post subject: Re: Engine & Propeller diameter Reply with quote
I've heard that a 701 with a Jab 2200 is a little weak on take off and climb. I don't know what an R-2100 is, but since it is spec ed at 80-hp and a 62" prop I guess it is direct drive, so pretty much a 2200 Jab.
Just my $.01 ( not worth the full $.02 Very Happy ) The prop speed and chord figure in too...so now the value of my post is down to $.05 Very Happy
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
