hammer408(at)comcast.net Guest
Posted: Sun May 18, 2008 10:35 am Post subject: S704-1 Relay Question |
Bob:
I'm going to install a "Heavy E-bus and use your architecture: Bat-bus
(14AWG) to 704-1 relay with S700-1-3(22AWG) switch coming off relay and 14
awg from relay to e-bus. I'm a little confused on how the Relay is wired.
I've printed the wiring picture of the Relay off the aeroelectric website
and it didn't help.
The diode, via fastabs is wired or jumps the - to + terminal and there are
also 2 wires crimped to the same fasttabs. I'm assuming the black goes to
ground, but where does the one wired to the + terminal go to ??
Also where does the "COM" wire and N.O. wire go?
OR...keeping the question simple ---how do you wire the Relay utilizing
Heavy E-Bus architecture?
nuckolls.bob(at)cox.net Guest
Posted: Sun May 18, 2008 7:36 pm Post subject: S704-1 Relay Question |
At 02:34 PM 5/18/2008 -0700, you wrote:
<hammer408(at)comcast.net>
Bob:
and it didn't help.
As shown in
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z32K.pdf
The picture at:
http://aeroelectric.com/Pictures/Relays/s704inst.jpg
shows how to get the diode leads into the same terminals
with the wires that go to ends of the relay coil . . . but
according to Z32K you'll need to drop two wires into the
COM terminal too.
( -Thomas Paine 1776- )
andrewbutler(at)ireland.c Guest
Posted: Mon May 19, 2008 5:14 am Post subject: S704-1 Relay Question |
Hello,
At what level of load does an E-Bus become "heavy duty"?
Also, what is the purpose of the diode? I know what a diode does, but what is its practical use in this instance?
Cheers,
Andrew.
[quote]---
rshannon
Posted: Mon May 19, 2008 6:11 am Post subject: S704-1 Relay Question |
On Mon, May 19, 2008 at 6:11 AM, Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)> wrote:
| Quote: | Hello,
Cheers,
Andrew.
The level at which an E-bus becomes "heavy duty" is not a precise point, but certainly occurs when the E-bus is expected to carry loads that would strain or exceed limits for a standalone toggle switch. Although the S700 series switches are rated to 15A, you should probably be seriously considering a separate relay whenever load approaches 10A, IMHO.
The diode keeps the E-bus from back feeding the Main bus when the E-bus alternate feed (direct from battery or battery bus) is ON. If the E-bus were allowed to back feed the Main bus, it would defeat the purpose of the E-bus, which is rapid, positive reduction of load upon alternator failure. Use of a diode instead of another switch eliminates the need to flip another switch (i.e., reduces chance for error, also, see "heavy duty" discussion above).
Ron
Posted: Mon May 19, 2008 7:19 am Post subject: S704-1 Relay Question |
Thanks Ron, though the diode I was referring is the 1N4001 across the coil of the S704 relay. There is something I don't know, cause I don't see it adding any functionality.......
Andrew.
[quote]---
etienne.phillips(at)gmail Guest
Posted: Mon May 19, 2008 7:44 am Post subject: S704-1 Relay Question |
It's called a fly-back diode.
The coil of a relay is a fairly sizeable inductor, which means that a step-change in current is not really possible. What happens when the current to the coil is removed, the "inertia" of the inductor will force a current to continue flowing for a short while, generating large voltages and arcing across switch contacts. The fly-back diode gives this current a path to flow without interfering with the rest of the electrical system, and only comes into play when the coil is de-energized.
For more info, go to http://en.wikipedia.org/wiki/Flyback_diode
Etienne
2008/5/19 Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)>:
[quote] Thanks Ron, though the diode I was referring is the 1N4001 across the coil of the S704 relay. There is something I don't know, cause I don't see it adding any functionality.......
Andrew.
[quote]---
rshannon
Posted: Mon May 19, 2008 7:46 am Post subject: S704-1 Relay Question |
On Mon, May 19, 2008 at 8:16 AM, Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)> wrote:
| Quote: | Thanks Ron, though the diode I was referring is the 1N4001 across the coil of the S704 relay. There is something I don't know, cause I don't see it adding any functionality.......
Andrew.
Ooops! So much for unwarranted assumptions.
As for the diode across the coil, see http://www.aeroelectric.com/articles/spikecatcher.pdf
Ron
Posted: Mon May 19, 2008 8:17 am Post subject: S704-1 Relay Question |
Perfect! Thanks.
[quote]---
Posted: Mon May 19, 2008 12:11 pm Post subject: S704-1 Relay Question |
At 01:11 PM 5/19/2008 +0000, you wrote:
| Quote: | Hello,
The e-bus was born of a time when many if not most
builders could plan on and implement an endurance
load of 5A or less. The rule-of-thumb for maximum
protection level of an always hot wire in TC aircraft
is 5A . . . so the idea of taking a 5A fused feeder
off the battery bus to supply an e-bus through a panel
mounted switch was well within the parameters of
accepted practice in TC aircraft.
As folks piled more stuff on the e-bus, 5A feeders
wouldn't cut it any more so it became a tribute
to accepted practice to add a mini battery contactor
at the battery bus to provide a local control point for
the e-bus alternate feed path.
From a reliability perspective I really like the
idea of staying with a toggle switch. Further,
given that a 7A fuse is on the order of 5-10 times
faster than a 5A breaker, it seems a reasonable
tribute to accepted practice to say that anything
over a 7A FUSED alternate feed path is "heavy duty"
and justifies the complexity of an additional
relay. 7A or less can be handled with a toggle
switch.
Posted: Tue May 20, 2008 1:11 am Post subject: S704-1 Relay Question |
Okay, I've read the Wikipedia and aeroelectric articles. So far so good.
So, in the absence of the diode, where is the "arc" likely to occur? If I have understood correctly I'm saying at the E-BUS feed switch rather than at the switch in the relay. Am I correct?
If not, why does the arc occur at the relay switch and not the feed switch. It has to do with the current flow path.........
Thanks for your help.
Andrew.
[quote]---
Posted: Tue May 20, 2008 5:35 am Post subject: S704-1 Relay Question |
That is correct, in the E-bus Alternate Feed Switch in this case, or in a more general case when dealing with inductor-like components, it'll arc across whatever component tries to remove power to the relay. In the case of a solid-state IC, this will normally be the silicon wafer, which would let out the smoke and kill the chip.
I know someone who lost a starter switch in his Cozy after about 15 engine starts because the fly-back diode was missing from the starter contactor, that's how marked the effect is... A new switch and one 50c fly-back diode later and no more problems.
Hope that helps
Etienne
2008/5/20 Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)>:
[quote] Okay, I've read the Wikipedia and aeroelectric articles. So far so good.
Andrew.
[quote]---
Posted: Tue May 20, 2008 6:10 am Post subject: S704-1 Relay Question |
At 09:01 AM 5/20/2008 +0000, you wrote:
| Quote: | Okay, I've read the Wikipedia and aeroelectric articles. So far so good.
Andrew.
Not sure what you're calling the "feed switch". With
respect to contactors and relays, there is potential for
effects of field collapse in an inductor to erode
the contacts of the device that controls that contactor
or relay. Hence, the long standing practice of adding
spike suppression across the coils of such devices as
illustrated in the Z-figures.
Now, ANY time you break a circuit with the opening
of hard contacts as in a switch, relay or contactor
(that is carrying any amount of current at any voltage)
there WILL be an arc formed in spreading gap between
opening contacts. There was a school of thought circulated
in the OBAM aircraft community a few years ago that
for voltages and/or currents below some low level
(I don't recall the numbers now) that no arcing would
occur.
So as an experiment, I took a miniature switch and
sanded out the side of it like this:
http://aeroelectric.com/Pictures/Switches/sm_switch_cutaway.jpg
I fixtured it under the microscope and caused the
NO contacts to carry 1 or 1/2 amp of current at 1.5
volts (alkaline d-cell). In a dark room I could clearly
observe a tiny but bright blue arc in the spreading
gap between the contacts when the circuit was broken.
THIS ARCING IS NOT the phenomenon of concern with
respect to noise or debilitating effects on controlling
or controlled devices. Hence we rarely see arc suppression
techniques applied to these effects. One exception
is the quest for achieving the Beech Aircraft ov relay
trip-life using relays some 30+ years ago as described
in the chapter on OV Protection in the 'Connection.
There is also a school of thought that suggests plain
vanilla diodes across relay and contactor coils will
cause a slowing of contact spreading velocity and is
therefore an inducement to prolonged arcing at the
opening contacts.
Experiments on my bench showed that while adding a
diode did indeed cause a DELAY IN OPENING of the
contacts . . .
http://www.aeroelectric.com/Pictures/Curves/704-1DelayNoDiode.gif
http://www.aeroelectric.com/Pictures/Curves/704-1DelayWithDiode.gif
. . . use of the plain vanilla diode produced no
significant slowing of contact spreading velocity
once they started to move.
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeNoDiode.gif
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeWithDiode.gif
In any case, the arcing produced either at controlling
switches -OR- contacts of the controlled devices IS
NOT a widespread threat for damage to other components
in the system. The strongest effect you'll experience
from the behavior of an unsuppressed relay or contactor
coil is a transient interference event. A few years ago
I helped a builder track down why opening his avionics
bus relay on an off-the-shelf integrated power distribution
system caused his ov protection to trip. A diode
across the relay coil fixed the problem.
Posted: Tue May 20, 2008 6:48 am Post subject: S704-1 Relay Question |
All I ever wanted to know about that particular component on the Z-figures and then some.
I very much appreciate this valuable resource (all things Aeroelectric) and your attention to detail Bob. I wired up my first harness last weekend and attached it to my TruTrak servo. I did so with a relative amount of confidence in what I was doing, how I was doing it, why I was doing it and how I would continue doing it for the rest of the electrical system. Fantastic!
Without this resource, I can honestly say that I would have been groping in the dark ending up with a low quality piecemeal whole rather than a high quality coherent one.
Very many thanks for this and for the answers to my future questions. Andrew.
[quote]---
longg(at)pjm.com Guest
Posted: Tue May 20, 2008 9:26 am Post subject: S704-1 Relay Question |
Great thread...
In our world it seems like we take relays for granted. They are amazing gadgets and I wanted to find more information on them. Below is a great link with detail on the very popular Bosch relay. It should be very clear as to their great benefit. There is no reason to stress a switch with a few of these in-line.
http://www.bcae1.com/relays.htm#demo
Posted: Tue May 20, 2008 4:40 pm Post subject: S704-1 Relay Question |
At 02:45 PM 5/20/2008 +0000, you wrote:
| Quote: | All I ever wanted to know about that particular component on the Z-figures
and then some.
You're most welcome my friend. I'm pleased that you've
found the work so useful.
