DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu May 22, 2008 6:19 am Post subject: Angle for Useable Fuel and Flow Check |
I am to the point in my final assembly where I would like to demonstrate the useable fuel quantity and fuel flow checks. Per the FAA guidelines, they suggest performing this test with the aircraft set to a deck angle of "5 degrees above the highest anticipated climb angle." I e-mailed ZAC for their suggested angle at which to perform this test. I got back a disappointing catch-22 like non-answer. They said the highest angle I am likely to see is the power on stall angle. "Which you will have to find in your flight testing." That was the entire answer, not even a suggestion considering that I cannot do one before the other. Thanks for nothing.
Does anybody who is flying an XL with a Jabiru 3300 have any insight on an appropriate angle to use for this test? At least until I can fly and determine my own results.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ David Gallagher
Cincinnati, OH area |
planejim(at)bellsouth.net Guest
Posted: Thu May 22, 2008 6:32 am Post subject: Angle for Useable Fuel and Flow Check |
David,
I don't have an exact angle to suggest for the fuel system flow check, but I
do highly recommend you do it. Let's hope a XL owner can give you a real
number. As a EAA Tech Counselor I urge every builder I work with to do this
check. It can be a life saver. My guess is to get the nose up to about 25
degrees.
I suggest actually running the engine at take-off power ( not just a fuel
flow check into a container ) for at least a minute or two with minimum fuel
in the tanks with the selector in each position. Just be carefull how you do
this. Don't want anyone to get hurt.
Jim Hoak - 601 HD
tonyplane(at)bellsouth.ne Guest
Posted: Thu May 22, 2008 7:20 am Post subject: Angle for Useable Fuel and Flow Check |
Dave,
If you hold the tail on the ground, it should be suffice, in my opinion. I
believe any difference between this and a higher angle would be minimal. I
have never heard of any problems with the XL/Jab fuel system design.
With the Jab 3300 you have a very high nose attitude at full power at
stall - in fact on my XL/Jab I can never get it to break before my CHTs go
to redline; the airplane just hangs in a stall shudder and I keep the wings
level with rudder.
Also, I have run my tanks dry during Phase I testing to see what would
happen and to check restart of the Jab. On my XL the engine just suddenly
quits, and the engine windmills. Restarts are a non event. I hit the boost
pump, change tanks to one with fuel, and within a few seconds the engine is
again purring.
I believe you will really enjoy flying the XL/Jab. Watch your CHTs.
Tony Graziano
XL/Jab N493TG; 378 hrs
